Need advice on new kitchen sink drains...
Kansasteacher
Kansas
I am building a new home- house was roughed in and I am finishing it. There are two drains for the double sink, both on the same horizontal plane.
Do I have to use them both?
Can I cap one with a removable cap to use as a clean-out?
Do I use a "T" to connect the sink drain, and the drain pipe from the disposal?
Many thanks in advance!!!:) :) :)
Go here
https://terrylove.com/forums/showthread.php?t=11014&page=4
to post #69
Click on the right pic and you will see a drawing of how it should be set up. You can put the disposal on any side you want. You can go to Low*s and find the drain tubeing to set it up that way and you can add a Fem. Adp. with C/O cap for the side you want to make a C/O.
