Very Slow Leak at Shower Valve
  • Thread starter Thread starter HR
  • Start date Start date
HR
Hello,
Just finished installing a new 4 way shower valve. Used copper all around with Brass fitting screwed onto the valve assembly with teflon tape. Have not done that much soldering but that worked out perfectly.
Trouble is at the threaded hot water supply fitting at the valve. I tighted these fittings up about as much as I could , but a very slow leak was apparent later the day of installation. Not a big one, at about 2 drops a day. Trying to figure out a plan.
Couple things I have considered. Thinking of heating up the the copper piping at a joint to loosen up the fitting and tighten the bolt, but I don't want to compramize that joint.
Or cold I heat up the brass fitting at the valve and apply some solder to the threaded fitting. I am concerned this may be too much heat close to the valve.
Or should I just cut the pipe and start from scratch on this one fitting?
Any ideas would be much appreciated.
Thanks.
Rob
Cut the pipe, but put back together with a coupling (no stop, if nesessary)...don't start from scratch.
My non-pro approach is to use a generous application of teflon pipe dope on those connections that "have to" be right the first time.
Thanks Ted.
That is probably the best bet. Little tight on space , but it will probably work.
Also read on another post (search on leak) that if there is a slow leak on a brass fitting it may sort itself out.
Cheers,
Rob
I don't like to rely on it "sorting itself out" because it is just as likely to "unsort" itself later!
Metal threads should go hand tight plus 2 to 3 turns with a wrench. Tape,or dope, and lots of guys recommend both. Mainly, I suggest not TOO MUCH tape. Just 3 to 4 turns of the paper thin white tape, or just 2 turns of the heavy tape (like the yellow gas tape).
Thanks Jimbo...Sounds like it's cutting time!
Cheers
Soldering close to a male adapter can cause it to leak. It's best to make the nipple as long as possible, sweat it up and let it cool before screwing it in to the valve. Then wrap a wet rag around the the adapter before soldering the next joint.
Thanks much. This is a wealth of information for the DIYer.
I installed a Price Pfister customer supplied tub/shower valve today. Since it was bought at a BigBox, it had the female threaded sockets. I sanded the sockets and male adapters then wrenched them tight and soldered them. That way I don't worry about that joint leaking from the heat.
