View Full Version : Problem with old shower faucett/parts
Jkeyler
02-09-2007, 11:24 AM
Background: About 25 years ago, we updated our bathroom and installed a Sears Single Control Tub and Shower Valve. In recent years, in obtaining replacement rebuild kits from Sears and installing the parts, the shower would almost immediately start leaking through the spout and would gradually get worse. After inspecting the rubbber inlet seals, it is obvious that they are getting sliced up during use. That makes me think that the rebuild kits are not the best or correct partsfor this particular valve assy. There are no markings on the valve assemby to identify the brand, nor in the Sears owner manual (which I still have after all these years). I took the parts to a local plumbing supply firm and they could not determine what manufacture that were from. I don't want to replace this shower assy as it would require tearing into adjacent walls, etc. Is it possible that anyone may be familiar with the Sears Combination tub and shower valve assy of that era (who manufactured them for Sears)?, and where might be able to obtain the correct parts for same?
Any help would be greatly appreciated.
TedL
02-09-2007, 11:51 AM
So, you're getting the specified parts from Sears, but whatever you're replacing is not fixing the problem? And you're looking to buy the same parts from a different source?
If that's it, I think you're making a mistake. Most likely it's that you're not replacing what's really worn out/broken.
If you want t make it easier for someone to help you, post a link to the exploded parts diagram for your model at the Sears parts web site. If you don't know how, at least give the full model # so someone can find it...it's on that owners manual you have.
Jkeyler
02-09-2007, 12:37 PM
I understand what you are saying, however, a previous repair kit I ordered from sear was incorrect in that it was keyed differently and required the knob to be installed upside down. The repair kit I have installed now is from Sears. At any rate, the model number of the Sears Single Control Combination Tub and Shower Valve I have is 702.20760. Their current repair kit(s) numbers are 31502S and 80688. You don't get all the parts in one kit now, so you have to order separately. I don't remember which is which, however one of those numbers were for the springs and inlet seals (2 each) only. The last time I ordered these parts (Nov, 06), I could not find the manual on the Sears website, so had to talk to a Sears rep via phone.
Thanks for your help.
Lancaster
02-09-2007, 03:46 PM
Valley Faucet was the manufacturer of that valve.Since they are defunct,original equipment parts will not be available and by definition,any replacement parts will be "aftermarket" parts.
I have never bought these parts from Sears,most any good hardware store has them hanging on the wall marked "seals and springs for Valley faucets".Some plumbing supply houses have them too.I have never had any problem with them.Its true that sand and grit in the water will tear up the seals.Not much you can do about that.
TedL
02-09-2007, 04:09 PM
The exploded parts diagram and list are there now.
Jkeyler
02-10-2007, 06:16 AM
Lancaster, Thanks for the information regarding the manufacturer. That is just what I was interested in. To go a little farther regarding the repair parts I received from Sears, it seems that the holes in the plastic item that mates with the rubber seals is larger than necessary, and the edges of the circumference are very sharp, thereby cutting into the rubber seals as the handle is moved to turn the water flow on/off. I think I will remove that part and by sanding, break that sharp edge to see if that helps. I will also pursue getting replacement parts that are for the "Valley" manufactured faucett that you identified.
jimbo
02-10-2007, 08:09 AM
The parts will often be labeled "Valley..Sears..Aquadyne"/
It sounds like you should change the stem, as well as the seals. Most of the single and two handle stems are still also available.
02-10-2007, 02:05 PM
It is indeed a Valley faucet, and one thing not shown in the breakdown are the two white plastic sleeves that go in the bottom of the springs, opposite the rubber seals. HD and others have both the seat/spring repair kit and the new control unit. Replace them all.
Jkeyler
02-20-2007, 09:19 AM
Thanks to all who have contributed to my concern. I've been snowed in and have to gotten to HD yet to get parts. Thanks to all.
