PEX And Freezing Winter Temperatures
Master Plumber Mark
www.weilhammerplumbing.com
Everyone has been soo keen on all the PEX pipe
systems for years and years now.......
the damn stuff just works wonderful dont it???
The best thing to come along since sliced bread!!
but their is a funny thing about all thaqt plastic PEX.....
when it gets as cold as hell out there like about -10
with the wind blowing at 25 mph ----
it ALL FREEZES UP.....just like that shitty copper stuff.
the copper pipes I can thaw out with a electiical pipe thawer,
and perhaps get the people out of troubles
but the PEX cant be thawed out that way!!!!
Its pretty hard and nearly impossible to carry a
250 lb salamander full of kerosine down a flight
of stairs with the hopes of heating a cellar area
hot enough to thaw out WIRSBO PEX pipe...
plus all the other situatioins that simply cannot be
heated properly....
it has not been this cold in INDY since 1989
and I am pretty sure about half of this city
will be calling me before the weekend.....
When they call the first thing I ask them is
do you have copper or plastic pipes......
if they have plastic,
I tell them that I cant help them
and maybe their water will
come back on sometime next week
when it gets above 30
we have some very, very expensive homes built in
this area over that last 15 years
that used all of the fun PEX stuff and they
simply CANNOT be thawed out
so what else can a plumber do???
Now that copper prices are dropping tell them you can rip out all that plastic and put in copper :D .
The homes should be plumbed in a way that the pipes shouldn't freeze to begin with.
I live in SE North Carolina...not that big a problem here but I do have to work underneath a piling house on the beachfront this morning:eek:
actually never had to try to thaw out pipes for a customer, I feel for you guys dealing with all that bitter cold
What shoule be and wat is.....
A builder should insualte the homes he builds much better.....
A homeowner should have enough common sense
NOT to leave the garage door open all night long......
I called a lady a moron yesterday when she asked me if
that might have frozen up her water softener and water heater...
leaveing the door open all night long....LOL
A homeowner should have the common sense to close the
vents on the outside of his crawl space home and pack them with
towells or insualtion to keep this bitter
weather from attacking his pipies....
A home owner should have the common sense to see if the
crawl space door is closed up good and tight....
A home owner should have the sense to leave the faucets
dripping throughout his home too......
NOT .....to all of the above....
they are not going to peek out of their caves and inspect
their homes in this weather,
but they DO seem to know how to hand me their master card.......
when I charge them the min of $250
I do not own an electric thawing machine but found this on a site that sells them. I wonder how many plumbers follow these directions.
Warnings
The ************ requires either a 15 amp 115 volt AC outlet when on the "Low" setting, and a 20 amp outlet when on the "High" setting.
Be sure the unit is plugged into a properly grounded receptacle. If in doubt, check receptacle before plugging in unit.
If the power cord supplied with the unit is not long enough, be sure to use a grounded heavy duty extension cord that is in good condition. Using lighter cords can result in severe power loss and overheating.
There is a possibility that the output current of the unit may be transferred into the electrical service, either at the house being thawed, or at a remote location. Therefore, all grounds (i.e. electric service, telephone, and cable TV grounds) must be disconnected, both at the house being thawed and all houses on the same distribution transformer.
Do not leave unit unattended while thawing. Do not leave unit operating overnight.
HJ how true, that is hilarious.
Mark I'm located 70 miles west of you. This last week I sold out of every type of pipe heating material that I had in stock. Then last Sun. after all was gone I had a guy come in and give me heck because I was out, and he had driven 52 miles. I just looked at him and told him he should have called 1st.
Another guy called me wanting an water heater element, I asked what wattage he had, he said 208 - 240, I told him that was the voltage, not the wattage. I explained to him what the difference was, he called me a dumb ass and hung up. Unfortunately he didn't give me a chance to tell him I could replace my heater element and who's the dumb ass now!!:D
directions are for wimps.....
I have a hot shot pipe thawer and used it 4 times today
to the tune of 250 per job.....
they do sort of scare me when the pipes spark, smoke and crackle a little.....
and after about 5 minutes you almost cant hold onto the
copper cables cause they start to over heat....
thats when you know its time to turn off the machine....
but I have not burnt one down yet.....LOL
Ok. We get it. You don't like PEX.
Hey, how'dya feel about indoor plumbing. Crazy idea ain't it? And that motorized wagon.
Well that's just plain silly. It could run a person over or something.
:rolleyes:
Sometimes when you don't have a good connection with the clamps the cables get hot.
Pete, just try thawing plastic pipes. Builders don't do a good job with insulation, especially with multi level houses. Some subdivisions build that into the houses and it's just carelessness. So when the wind blows from the right direction, plumbers go like crazy thawing pipes.
That happens when you are heating too much pipe, have a poor connection to the pipe or have bad cable-to-clamp connections. I find that the thermal overload in the machine gives out long before the cables get too hot.
I'm not afraid of drywall in some of these overfinished basements. A return air grille or two can do wonders to keep the pipes from freezing.
Pete: don't be an @ss.
Cpvc
made me $450 today.
Split longways from joint to joint, cold water line feeding the toilet over a garage.
It broke because the insulation was installed backwards with the kraft-faced side opposite of the living space, along with a few gaps.
Of course, I replaced with copper as I won't even consider a glue connection in 3 degree weather.
Today was the first time I used a sharkbite, 1/2" straight coupling to transition from CPVC to copper. I didn't want to use a compression joint as it is not legal but anyone want to tell me if that sharkbite was even legal?
It's getting covered up, I'm feeling bad about it.
MPM read my follow-up on the delta dilemma thread.
The Sharkbite spec sheet says they are legal to bury behind the wall - has all of the approvals. Watts has a coupling, similar in concept, but the execution is all plastics, and it is made in China. I passed on those.
I checked on big local distributor around here (S-NH) for them - they had heard of them, but didn't carry them. Other than on-line, where do you suggest I look for these?
None are approved by code, as of yet. They may be installed as a 'alternate material' if approved by your AHJ.
We have a couple guys at work, service plumbers. One is lazy, and it's a stretch to call him a plumber; the other is a master who wants to make it cheaper on the customer (yet never has enough money cause he never gets enough hours). Both have been bit by the shark.
The lazy one replaced a tub/shower faucet with nothing but sharkbites- 10 of them! 4) 1/2" male adpts, 3) coups and 3) 90's. The customer complained that their new tub diverter was loose, and would spin to any direction. Took another plumber 3 hours more to remedy the issue, removing all the sharkbites. Cost to customer, the original $450 plus being pissed off; cost to company~$650+ and loss of face.
The master uses them a bit more prudently, but likes to brag that he can replace a wh without a torch.
Just another tool for the lazy and mis-informed. Takes the skill out of the job, IMO. We'll just see how they hold up for the next 5,10,15,20,30,50 years. My guess--they won't.
Can't wait for Pete to chime back in....
I don't claim to know all of the applicable codes or specs. This is from their spec sheet:
CERTIFICATIONS
The
SharkBite Push-Fit® fittings have been design certified to IGC 188.The SharkBite Push-Fit® fittings are
listed by
IAPMO and are certified for potable and hydronic heating water distribution (note: Glycol mixture for
hydronics should not exceed 50% concentration).The
SharkBite Push-Fit® fittings have been certified for
underground applications and as a manufactured joint without access panels and they meet
UPC, IPC and
cUPC requirements.The SharkBite Push-Fit® fittings are design certified ANSI/NSF Standard 61.
They're in a grey area until the next codes come out---happens all the time with new stuff.
What's amazing was the fact that the connection swivels so easily but doesn't leak.
Like I stated, it was an emergency situation, no way in hell was a glue joint going to hold in this scenario whatsoever.
Naturally if this was all copper I would of never even thought of using one.
I paid out the nose for them at Ace Hardware. Supply houses in your area will have better pricing jadnashua.
I'm from the old school of plumbers line of thinking even though I'm 37; I believe that simplicity (sharkbites) take away from the true profession and it seems that when something is too easy, it has drawbacks.
shark bites are a god-send
I used them today.. they work great
and in these parts they are ok to install undergournd...
I dont see what the difference is anyway....
you can "half ass" throw in
crimp type pex fittings all day long
in million dollar homes and hope that they hold up
for a few years and then let someone else worry about it
"down the road "
I have used them quite a bit and they work just fine..
they are jsut as sturdy as any plastic wirsbo fitting I have seen
and look much more professional than any crappy Kitech job .
So now we can all sit back and see if the shark bite fittings gives out
before the chlorine in the water starts to break apart the pex
fittings and pipe...
so my opinion is
if it is good for the goose , then its good for the gander...... .
