View Full Version : radiator won't heat up
fast pasquale
02-05-2007, 03:02 PM
I removed my radiator (one pipe system) in the bathroom as I remodled it. When i put it back it no longer gets hot. Wondering what went wrong. Im aware that it should be pitched toward the pipe.. which it is. The pipe isn't warm at all... any ideas?? thanks so much
plumber1
02-05-2007, 03:33 PM
You must have a vent on the end of the rad. It's one that vents to atmosphere and draws air when the steam pressure stops to allow condensate to drain back.........
fast pasquale
02-05-2007, 07:27 PM
yes. It has a vent. I took it off and....um.. man it's been a while. I either soaked it in vinegar over nite... or i may have boiled it.. not sure... but i was given the advice to check the vent from a plumber friend of mine a few months ago. i reapplied pipe dope and put it back on. still doesn't work.
fast pasquale
02-09-2007, 07:40 AM
any ideas guys?
geniescience
02-09-2007, 10:27 AM
more info a little or a lot
that'll help make your thread hot.
fast pasquale
02-09-2007, 01:55 PM
I Fixed It!!...
plumber1
02-09-2007, 02:26 PM
Please tell us what you had to do...............
fast pasquale
02-09-2007, 02:45 PM
umm... well ...uh... ok...Don't laugh.... The handle had broke off years ago.... but i was still able to manipulate the screw that was left there. I had opened (turned) the screw and assumed that this was opening the valve.. it wasn't. i took some slip joint pliers to the piece that the screw was attached to an opened it up.. THIS actually controlled the valve. The pipe got hot instantly and started to fill up the radiator.. AHHHH... nice warm bathroom when it's 2 degrees outside.. I know.. I know... Hey.. I refinish hardwood floors for a living... Plumbing is something i do to save $....hehe...
plumber1
02-09-2007, 03:14 PM
Glad for you.........
fast pasquale
02-09-2007, 06:28 PM
thank you my friend
fast pasquale
now i have a small leak... i was using pipe dope (teflon paste).. is this good enough.. I know some use rector seal.. what would you guys recommend?
fast pasquale
02-10-2007, 04:57 PM
pipe dope fixed it
