steveg91
01-31-2007, 08:24 AM
Hey folks, Couple of questions.........
1. I'm going to install a ball valve and water pressure regulator outside in the front of the house. The 3/4" supply line is 24" between ground and 90 degree fitting going into wall, it runs vertically.
I've done a fair amount of sweating on 1/2" pipe, still I'm a little leary of sweating these cuz I don't want to damage anything inside the valve or especially the WPR. Is this a valid concern?
It seems that an alternative is to go with threaded WPR ( Watts N55B-M1 ) http://www.watts.com/pro/_productsFull_tree.asp?catId=64&parCat=285&pid=3431&ref=2
and use a 2" brass nipple between the pieces. To connect to supply line ( on each side ), pre-sweat a screw fitting to about a 5" length of pipe, screw that into threads, wrap it with wet rags and on other end using no stop coupling to sweat into supply line.
Is this a good way to go??? The question is will the screwed in connection hold as will the wet rag trick work and do screwed in connections hold in the long term, ( this is in San Francisco Bay Area, not too cold )----also this may look a little too hoky, or do I just sweat and be careful not to get it too hot??? If I sweat what spacing ( between both parts and between conections to supply lines ) should I use given entire length I have to work with is 24".
Thanks so much everyone,
Steve
ps, yes, I'll install an expansion tank at water heater.
Steve
