View Full Version : Current thoughts on Plumbers Putty vs Silicon Caulk
racine
01-30-2007, 11:19 PM
I'm sorry to have to bring this up again but I've already done a search and read all the discussions. Problem is I'm new in this small town, the plumber who put in my plumbing (5 faucets/ sinks, showers, etc...) lost his wife to Cancer halfway through his job on my house. Since then all faucets, sinks have leaked partially damaging cabinets. He didn't even use teflon tape on the shower heads and all 3 leaked.
I disassembled my kitchen sink today and the putty disintegrated. I'm wanting to install this myself as the last 2 plumbers I called didn't even return my calls? Now I'm leaning towards using silicon caulk for the kitchen sink and wondered what your thoughts were and what brand and type you've recommend. I know I'll have to let it dry for 2 days or so but please share some of your quick thoughts- I'd be very grateful and thank you in advance.
Hanging out in Lower Mississippi,
Racine
PS. Should I use the rubber washer on top instead of on the bottom or get another one for both top and bottom?
Norcal
01-30-2007, 11:34 PM
I never use silicon on basket strainers, I only use plumber's putty...never had a problem with leaking.
No, don't use a rubber gasket under the basket strainer, that goes under the sink.
Also, I don't use teflon tape on showerhead installs. They have rubber washers that are supposed to create a seal with the shower arm.
Gary Swart
01-30-2007, 11:59 PM
Ditto what Norcal said.
Racer814
01-31-2007, 04:05 AM
I use putty...some people view it as an archaic method and silicone as the modern way but it works as well as silicone does and I like the ease of disassembly.....those basket strainers won't leak either way if done correctly but you will thank yourself down the road for using putty when you decide to change them out ....
01-31-2007, 05:35 AM
What leaked on the faucets? Many faucets, these days, have built in, or added, seal so that neither putty or silicone is needed. Most shower heads gave a rubber flow restrictor that also acts as the seal so they do not need a joint compound or tape to seal them either. As far as the putty that disintegrated, where was it used? Plumber's putty stays soft and pliable for a long time after it is installed.
Cass
01-31-2007, 06:11 AM
Improper instaltion of putty, by using to much will cause it to wash out over time. I have seen many installs that the plumber used to much and did not comperss it enough and eventualy it washed out. Again the most common problem I run into is using to much putty.
Some bathroom sinks come with a warning not to use putty because the oil in the putty can cause them to crack and discolor.
racine
01-31-2007, 07:11 AM
Thanks for your opinions and replies. As far as the shower heads go all of them leaked around the threads. I used teflon tape on all and the leaks stopped-was there a better method?
As far as the faucets went, they all leaked from the plastic tubes/water source leading up to the metal faucets(every last one of them Moens). I simply tightened all of them up and that fixed it?.
Everyone so far has recommended putty. Should I use 10 yr old stuff or get new putty( hardware store help said 'putty is putty, I know my dads a plumber.')? I appreciate all of your responses very much and thank you for sharing your experience...
Racine
plumber1
01-31-2007, 07:23 AM
Use plumbers putty, it's not expensive.
racine
01-31-2007, 10:06 PM
I chose the putty simply from all the comments and suggestions. I put this together in 5 min. and hope not to look back for a long time. Your many inputs have be helpful for someone who has never done this. Thanks Again.
Racine
