View Full Version : Dual sinks wont drain
alex1000
01-28-2007, 07:32 PM
Hello,
While I'm pretty handy around the house, plumbing is pretty new to me.
I replaced a 60" single sink vanity, with two 25" vanities. Now after everything is hooked up, neither sink will drain the water at all it seems. My configuration is as follows:
-One 1 1/2" P trap right in between the two vanities, leading into the wall.
-Above the P trap I put a center split waste pipe (looks like a "T"). The top of the T sits about 4-5" higher than the pipe coming out of the wall.
-From the T split, there are about 18" to each sink drain pipe. There's not a big pitch from the sinks to the center waste, just a very slight one.
Any ideas on what I can do to fix this? I was reading that some people put a p trap under each sink. Is this the better solution?
Thanks.
Alex
plumber1
01-28-2007, 08:18 PM
Clean the drain to the vent pipe.
If one sink drains into the other, then you have a drain stoppage and you have to clean the drain all the way to the stoppage, not just to the vent.
plumber1
01-29-2007, 07:05 AM
OK.............follow your nose.............
casman
01-29-2007, 07:28 AM
I read another similar post last week and it seems to obvious that everytime someone changes to a double sink configuration and neither sink drains that its a clog. Wouldn't this mean it was blocked before the change, or is any partial blockage magnified by adding another sink? Of course I get it that it's most likely a blockage cause otherwise the water would drain but are there any other possibilities besides the obvious?
ddmoit
01-29-2007, 07:41 AM
With only one P trap, is it possible that each sink acts like a misplaced vent for the other? It might explain why one sink can manage to get past an obstruction, but two sinks cannot.
alex1000
01-29-2007, 12:28 PM
with one sink it drained fine. So Im assuming its not a clogged drain issue. But I'll check that...hopefully ill find the drain is to the vent pipe :)
What about trying two p traps, one under each one?
plumber1
01-29-2007, 03:52 PM
You almost always should clean the drain when you do work like that before you connect every thing back up. And it's a good idea to put a clean out in there while redoing the piping so you can do a good job of cleaning the drain line. It saves a mess too..........
alex1000
01-29-2007, 07:53 PM
ok, well...it is definitely clogged. I removed the PVC piping, stuck a 20 dollar snake into the metal pipe in the wall, and the snake goes about 20 inches and is blocked by some muddy/sandy substance. The metal pipe also makes a 90 degree left turn right where I believe it is clogged. But Im having a very tough time breaking thru it. Is there a better tool i should get (assuming the problem is only a couple of feet from the wall)?
I then connected the standard wall pvc pipe, attached to a 10" PVC pipe directed upward. Filled it with about half a gallon of water before i could see the water stuck in the pvc pipe...which confirms the clog.
Will pouring boiling water (very carefully! :) ) down the pipe do anything to help?
Thanks for the suggestions/comments.
A $20.00 snake is probably about useless.
alex1000
01-29-2007, 08:04 PM
that it is, other than identifying where my clog is ;)
i'll probably take it back. Are the more expensive snakes any better? The metal "cord" didnt seem much weaker than more expensive alternatives.
plumber1
01-30-2007, 10:47 AM
Your snake is almost useless, but I bet some of these guys could make it work in a real pinch. It's got to be cable and not a steel tape.
You need a snake that is a little bigger diameter, a little stiffer, and just keep practicing till you get around all those corners.
leejosepho
01-30-2007, 02:24 PM
I have occasionally used water pressure to clear drains, and once they are clear, I sometimes alternate back and forth between cold and hot water to try to help loosen sticky stuff on the walls. There are many ways to get water pressure into a drain line, and those ways might be limited only by imagination! Here are a couple of devices I have used ...
