MaggieQuest
01-28-2007, 07:13 AM
Hello - I'm a newbie to the homeowner world and we've found issues with almost all of our major appliances since we moved in 18 months ago.
Today's issue: the well pump switches on every three minutes or so. In reading threads I'm learning this could cause future problems so I'd like to fix it fast and cheap (yeah, right, huh?). Anyway, we haven't had any problems with water pressure at the faucet. The cut-in pressure seems to be around 40, and the cut-out at 60. But as soon as it hits 60 and turns off, the pressure gauge rapidly loses pressure to take it to 40. There are no visible leaks anywhere in the house, and we have the outside faucets turned off and open for the winter (we're in Michigan). The tank is a big A.O. Smith Aqua-Air.
I've read as much as I can on the subject, but am having trouble identifying the a) problem and b) most of the "pressure switches" and "valves" mentioned in former threads.
I'm sure this is a common issue that you've all address in the past. Sorry to ask you to retype a solution (or even some hints) but any advice would be GREATLY appreciated! Thank you!
-M.Q.
-M.Q.
