skd
01-27-2007, 10:33 AM
As part of a master bath remodel I'm putting in a new stand alone shower. The house is slab on grade and the decision at hand is whether to bust through the concrete to run the drain lines or install them on top of the slab and raise the shower.
The original plan was to run the lines on top of the slab as the thought of breaking up the concrete was more than I wanted to get into. The new shower butts up to another bath and the vent stack is accessible. While running lines for the laundry room remodel portion of this project the plumber stubbed in the water lines and installed a T to attach the shower drain to.
I have been revisiting this plan and am considering running the drain under the slab. If I go this route I will break up the slab myself and have the new drain installed by a plumber. I have serious concerns about the potential damage the vibration from a jackhammer could do to nearby plumbing.
How can I get through the slab without a jackhammer? How much of an area do I need to take out? The shower is 36x36 so I'm thinking 1.5' (plus some working room) from the wall and 6-8" wide. Will I need to remove concrete from the other bath or should everthing be accessible from the shower side?
I've not completely abandoned the original plan, but am exploring other options so any thoughts on either plan- or a third- are welcome.
Thanks in advance.
Thanks in advance.
