View Full Version : Shower Pan Installation
elgato
01-26-2007, 10:41 PM
I just received my 54x34 Swanstone pan. I am surprised at how lightweight it is. I cannot see how it could be installed without a mortar bed.
http://i38.photobucket.com/albums/e146/haiptyg/P1010098.jpg
The grid ranges from approx 1/2" at the edge to o" at the center. It looks like a challenge to spread the mortar so that it evenly fills most pockets.
Second Question.
These photos are of the 8"x 16" hole in the slab for plumbing. Originally it was filled with dirt but it did not provide adequate support in the center. The old pan cracked near the drain.
http://i38.photobucket.com/albums/e146/haiptyg/P1010097.jpg
http://i38.photobucket.com/albums/e146/haiptyg/P1010096.jpg
Any recommendations on how to approach this? The Swanstone pan looks like it should have support as close to the center as possible.
Thanks
Tom
markts30
01-27-2007, 04:38 AM
Wrap the pipe in a bit of foam where it comes through the slab or sleeve it with a piece of 3" PVC/ABS...
Back fill the hole with dirt to 4" from the surface...
Repour around the tailpiece to give your pan support.
elgato
01-27-2007, 11:46 PM
Would you suggest repouring with something easier to remove than concrete?
If so, what?
Also, would it be acceptable to backfill with sand?
Thank You
Tom
