cburkenn
01-31-2005, 11:30 AM
I have a new home <1 year old. There are 2 bathrooms and both have the exact same 1.6gpf toilet installed. However, the performaces of the toilets are quite different.
Toilet #1 (guest bathroom) has no clogging issues. It has been put to the test several times and not once have I ever had to unclog it.
Toilet #2 (master bathroom) clogs about 2 - 3 times a week, depending on use. I have actually seen it clog on 1 strip of toilet paper. All clogs can be cleared with a plunger. I have attemted to snake the toilet as well, but no improvement. There are no gurgling effects on other fixures in the house.
The only visible difference between the two toilets is that toilet #2 is further from the wall than toilet #1. Could this be the cause? :confused:
I am in the process of requesting warranty work, but I would like to have some support for the builder to fix this issue.
Does anyone know possible reasons for the extreme difference in performance?
Thank you.
Thank you.
