Solvent Weld vs No Caulk
Blaze
Ontario, Canada
I was wondering which solution would be best for my situations.
I am installing an acrylic corner shower (base and walls) from Maxx. The bathroom is on the second floor above my family room.
Should I use a solvent weld shower drain or a no-caulk shower drain, and why?
Thanks
Mark
If you have access from a ceiling below, I prefer a solvent weld. If this is on a slab or otherwise does not have access, then you will need the no-caulk.
I prefer a glue drain in either instance...just MAKE SURE you get one that you can unscrew the drain after installation in case you have a leak...then tyou can screw it out...re putty and re install...
actually this is one of the few times I might use silicone over putty.....:eek:
