View Full Version : Replacing tub with tiled shower walls & floor
Troy Bieger
01-16-2007, 02:33 PM
OK, I am posting here for the first time. I have been reading from this forum for a while and have seen some related posts - unfortunately lost all my history in a computer crash. :(
We have a fiberglass tub that is old, ugly and impossible to get truly clean. Its out of here!
The tub spans the full width of a small bathroom (5'). The wall above the tub has a window in the middle about 5 above the floor. I would like to tear out the old tub. Build a small wall extension cutting the space from 5' down to about 3' 8" (at the edge of the window opening or just past it. This would leave a small "linen" shelf opposite of the shower head side.
The idea then is to build up a small (4") or so ledge and install a shower pan or liner and tile the enclosure. The this would leave a shower stall just a little longer than it is wide.
Trying to keep costs down, I would rather leave the drain where it is and shape the pan/liner to it even if it means a bit of an odd drainage slope on the floors.
I'm thinking of doing the tub removal/demo, wall and ledge build up myself then having a plumbing contractor install the pan and prep for the tile which I would also do myself. Alternatively, if I can get the right instructions and materials to do the pan/liner myself, I may do the whole thing.
Am I crazy to be thinking of this? - I am usually pretty handy when I have the right tools and instructions. This site has been a wealth of knowledge already.
I would appreciate any advise and or suggestions...
~Troy
markts30
01-16-2007, 03:06 PM
Not crazy...
Some links to check out:
Great info on tiling
http://www.johnbridge.com/vbulletin/index.php?
Info on membrane lined showers...
http://www.johnbridge.com/kerdi_shower.htm
Good luck in your project...
geniescience
01-16-2007, 08:29 PM
and congratulations, you already know a lot !! There are many ways to plan a sloped floor without putting your drain in the center. Post your ideas.
david
indyjps
06-07-2008, 09:01 AM
couldnt you pour a concrete shower pan, slope it to your existing drain and tile the floor also?
Redwood
06-08-2008, 08:42 AM
You may need to replace the drain anyway. Tub drains are usually 1 1/2" while shower drains are 2".
