Hi, this is my first time on this site. I am pretty sure that this has been asked prior. I want to tile my bathtub walls. The house was built in 1948. The walls had a three piece plastic surround that I removed. There was some glue on the wall. The walls look like concrete walls. I can see wire mesh near the bottom of the wall after removing some older tile sections.
My question is this: Can I just tile right on to the concrete walls with morter first or do I need to prep the wall first? How should I fill in the space between the bottom of the concrete wall and the top of the tub. The area to be filled is about 4" high around the entire length of the tub.
Also, I want to re-plumb the supply hot and cold pipes. I think the pipes are copper but they may be galvanize. Whats the best way to plumb through and repair the concrete wall? Presuming that what I see are concrete walls.
Thanks for any help given.
REH
REH
