Abandoning line
It should be totally fine to abandon the line if you don't want to use it. My husband said, "Shut the gas off at the meter. Make sure there is no source of ignition. Electrical box, smoking, starting up cars, etc. You can bleed the line out from the T outside at the meter, so the gas doesn't bleed into an enclosed area. This may take a couple minutes because you are bleeding the whole house. (This means you will have to have all pilots relit-call the Gas Co. and schedule them to come out and relight unless you know what you're doing). looks like there is no union, so cut that piece about 12 inches from the T if there is room to hacksaw it, (at this point all the gas should be out of the system and shouldn't be blowing when you open up the pipe). Take that piece out and put a plug in the T. Turn the gas back on and soap it to make sure there are no leaks in your plug.
