BryanL
01-28-2005, 04:11 PM
I need to replace a water system, and I'm interested in advice about suitable pipe materials. Basically, I live on a hill with a steep rise. Water comes from the city to the base of the hill, and then I (and my neighbors) each have systems to pump the water up the hill (pressure tank and reservior tank). Length of the run is about 1,000 ft, and the vertical rise is unknown, at least a couple hundred feet.
The easement for the water runs right next to a private road that we use for access. The road is only a single car width, creating the possibility that cars may drive off it and find themselves driving on top of where the pipe is buried. Whatever we build needs to be able to handle this possibility.
We plan to dig a trench and bury our pipes, maybe 3-4 ft down. Because it is so hard to find leaks in this long a run, with a hill, we're interested in a system which will just work, with a long life and low likelihood of breaking. I'm wondering what the best pipe material is for this application.
Cost is not a primary factor. Even expensive pipe costs less than having people search for leaks and dig holes, as I've recently found out the hard way.
I'm attracted by copper and PEX, for their durability and flexibility, but it's not clear that they're available in sufficiently large sizes. My plumber recommends a 2" diameter, to minimize friction in the line.
Any recommendations on my best course of action?
Thanks
Thanks
