Joel McElrath
I have a NEW 1 h.p., 230 volt, 2-wire, 20 GPM pump. It is connected to a sprinkler system through 300 feet of 2" PVC. When the pump comes on, it cranks out about 20 GPM. After 3 or 4 minutes, it shuts off. I'm not sure if it is completely off because a trickle keeps running for awhile. I think the trickle might just be residual water draining from the pipe because the last 150 feet slopes down gently.
There are no pressure tanks or switches in the circuit, just a wire running from the breaker to the pump. The electrical wire was already buried when I bought the place. It is about 370' from the breaker box to the pump, but the wire probably does not go straight to the pump because of obstructions. It could possibly be over 450' from the breaker to the pump. Would this distance be enough so the resulting under voltage would cause the thermal overload protectors to shut off the pump?
