clt1dxd
01-06-2007, 05:41 PM
I have been fighting a leaking TPR valve on my hot water heater all day. I must say that I have learned alot about plumbing today.
I replaced the TPR valve because it seemd to begin to leak after I tripped it during the routine draining of the HW heater to remove setiment. After replacing the TPR, it still leaks... alot.
I noticed that it would stop after a faucet was run anywhere in the house. Hmmm, seemed like a pressure issue. I purchased a pressure gauge and I am pushing 150 PSI, probably more, but the tpr is tripping and keeping the system at 150.
I adjusted the pressure reduction valve located where the main enters under my foundation. I lowered it to the point that I only get a strong trickle at any faucet, but the pressure builds back to 150 PSI when all faucets are closed. I strongly suspect a faulty pressure regulator, but before I go digging to get to it, I would like someone elses opinion.
Another clue - the leaking TPR seemed to start when I recently replaced a leaking toilet. I suspect that the leaking tiolet served as a pressure release, which caused the system to stay below 150 PSI and therefor keeping the TPR on the WH from tripping.
Thanks a million,
Dan
Thanks a million,
Dan
