View Full Version : Plastic inserts in my new WH
Laneman
01-05-2007, 07:05 AM
Bought a new electric Whirlpool WH. At the top where the nipples screw in is a plastic disc in each hole. The hot side has a blue plastic ring with a one way rubber flapper. The cold side has a rubber disc with star shaped slits. I think these would restrict flow, so I would like to remove them. Are they necessary?
Cass
01-05-2007, 07:12 AM
No they are not necessary. They can be removed. They are heat trap nipples. They keep the heat in the heater when it is not being used by preventing thermal heat transfer. I am not sure how much heat they save but I doubt it is much. I would replace them with dialetric nipples. The ID is slightly larger giving better flow than if you remove the flap from the installed ones.
jimbo
01-05-2007, 07:47 AM
A few years ago, dont remember if it was '03 or '04, the govt slightly increased the minumum energy efficiency required in WH. One of the methods use to get an extra point or two on the rating was to install the heat trap nipples.
vaplumber
01-06-2007, 02:43 AM
In most cases these things are a waste of effort however if you do not have heat trap loops, ie your pipes run straight up towards the cieling from your heater then yes, leave these devices in or you will regret it. If your pipes run horizontal with a slight dip or trap as they exit the heater then you wont notice any energy differance without these plastic traps, and you will notoce better flow from your hot water.
Cal
01-06-2007, 04:18 AM
If you look inside these nipples you will see that they are diaelectric nipples.
Nice feature ,, you don't have to by them seperate.
master plumber mark
01-06-2007, 05:29 AM
Which electric Wh heater did you buy,
if it is the one with the controll box on the
top of the unit, it is not too good a brand..
its very hard to make future repairs to
Laneman
01-08-2007, 06:17 PM
vaplumber- The 3/4 copper supply pipes rise from the slab, up inside the wall, then go horizontal into the WH. I added Tee fittings at the top of the WH supplies in the wall and continued with 3/4 pex up into the attic, then down to the tub. The WH pipes exit the wall horizontally and go to the heater, but there is no dip. Will there still be a heat loss issue? If so, can I buy a longer flex line and just put a dip or a loop in it?
Mark,I avoided the one with the electronic control box, seemed like something else to go wrong.
