View Full Version : troubleshooting a electric water heater
Peevee
01-03-2007, 05:32 PM
On a electric 240 volt water heater how can you tell if a element is burned out or if it's a thermostat. Also what should the voltage check at the elements? Thanks:)
01-03-2007, 09:02 PM
Are you competent to work on it with the power on? If so, then a voltmeter to the terminals to see if it has power to the element, and then a clamp around ammeter to see if it is drawing any power.
