OldPete
01-02-2007, 05:24 AM
Hi,
I have had a new Andersen Frenchwood Sliding (Slider) door professionally installed. When it rains water collects in the threshold about 1/2". I removed the sliding panel and compared everything to the directions that came with the door, and the stationary panel. I noted that the weather seal that screws vertically to the stationary panel was centered on the stationary panel and did not touch the foam at the base (threshold) or at the top. I then removed the vertical stationary panel seal, filled the holes properly and seated it toward the bottom more so that it would be touching the foam that is there. I did not smash it into the foam since that would have not allowed it to touch the foam above, instead I butted it up against the foam at the base and then gave it a gently push into the foam, so it would still be touching the foam at the top. I did add a tiny bit of silicone sealant to "hedge the bet".
Today it is raining and heavy winds. The threshold is once again full of water.
Is this just the "way it is" with these doors? Or is there something else wrong?
Thank you for any tips, hints, or idea.
Pete
Pete
