View Full Version : Toilet flange spacers?
DaveB
01-01-2007, 09:35 AM
Small bath remodel, changing from vinyl to tile w\ electric heat mat...Existing closet flange is mounted on the subfloor (recessed beneath the 1/2" underlayment & vinyl (which has been demo'd). Will be floating about 3/8" to 1/4" of Self Leveling Cement over the top of Warmly Yours heat mat... then DITRA (1/8")... then 5/16" tile (Ceramic DalTile French Quarter)... So the flange "should" be an inch higher than original.
The bath is above a nice crawl space, the plumbing is all abs... "if" the flange will simply re-position @ the new height by lifting it, are there any pre made two-piece spacers that I can bolt through (under the flange), then re-adjust support below?
Dave
srdenny
01-01-2007, 10:09 AM
http://www.siouxchief.com/Resource_/Product_Image/324//Regular/C886ER.jpg
Try cutting this in half.
http://www.siouxchief.com/Drainage/ResidentialDrainage/Closet-Flanges/Quick-Spacer.NHYLH
DaveB
01-01-2007, 04:35 PM
I decided to pick up (3) Oatey 1/4" closet flange spacers to raise the 3/4" needed...the problem is the (4) screw holes in the spacers do not line up w/ the original closet flange holes (blue metal ring)...Is it ok to line up the spacer holes & pre-drill (4) through the blue ring where necessary to screw into floor? Or do I need to different spacers...I can't replace existing flange very easily because of HVAC duct work limits access. By the way, installing TOTO Drake thanks to Terry.
Dave
jadnashua
01-02-2007, 06:22 PM
Adding holes to the flange should not be a big problem.
rdtompki
01-02-2007, 09:02 PM
I just used one of the same Oatey spacers. Drilled through the existing flange and into the surround slab. Worked like a charm.
