Problem after installing vanity sink
Klamity
HI there,
I just installed an all-in-one vanity top/sink. 49x22"
When I was ready to hook up the p-trap to the pipe into the wall, there was a difference in the placement of the tail piece. I went to Home Depot and got a couple of pieces of pvc that shortened the distance. I was able to get the ptrap hooked up, though there is a tiny bit of stress on the tailpipe.
Now I have a leak from the where the drain meets the sink on the underside. It is tightened well I think, but still leaking. What to do next?
Please help! Thanks!
I'm in Ontario.
Klamity
thank you
Thank you for your speedy replies. I will try this tomorrow and see if that helps.
Sincerely,
K
Not knowing what you mean by "a tiny bit of stress" if hj and RUGGEDs solutions don't work you will have to eliminate the "stress" to stop the leak.
