V
vaplumber
Guest
I just got back from a service call. Lady had no water, and suspected a frozen pipe. Wanted it fixed before it ruptured. I knew better. Its chilly here but is still 35 degree, yet took the call anyway. Found an 100++ year old small 2 story farm house, supplied by 2 cisterns as water source. Lady fills both cisterns with 1600 gallon each about once each 6 weeks. Went to dirt floor and rock wall cellar, and discovered an old Montgomery Ward piston driven pump and tank. Cement pad that pump sets on was ingraved in finger print July 8 1958. Owners guide and tag were still attached to pump unit. Glanced through book and read tag which were faded and hard as rock. Confirmed that pump and tank both was installed July 11 1958!!!! Pump was piston type pump and for you younger guys who havent seen one it looked like a portable air compressor and was driven by a 1/3 horsepower motor through a belt and pulley. Confirmed that pump had a broken drive belt, which by date still visible on outer band of belt I determined the belt was made in 1978!!! I replaced the belt, checked water pressure, confirmed that there were no leaks, and all checked out fine. I just thought that you would all find this un believable!!! Why cant some one still make pumps and tanks this durable?
