just flush it
pressure testing pVC pipes is a total pain
and is sometimes literally impossible to do
unles syou have thought ahead and installed
as access plug down stream of the system you want to test
Why are you worried about it anyway???
does it look bad , or look only half way into the socket???....
if you are really worried about it, just climb back up
into the hole and apply some extra glue to the joint
a couple of times, let it dry and do it again...
99% or most pvc plumbing will never, ever leak once put together
and glued....that is why pressure testing is such a total waste of time and
a complete joke......to simply make work and give the inspectors something to do..
if you read the printing on sch40 pvc pipe it claims to
be able to hold pressure of something like 250psi once it is
glued together.... so what are you worried about...
go ahead and flush it a couple of times and forget about it...
