beng
01-25-2005, 11:24 AM
i installed a pegasus 5000 series shower valve in a new shower. soon after knocking was heard after shutting off any valve in the house. the sound was clearly coming from the shower. i opened the wall behind and installed 16" risers to both hot and cold lines. knock disappeared. a few months later the knock is back. i drained the system and recharged, but the knock is persistent. the shower valve has internal shutoffs. i shut them off and the knock was gone. if one side (hot or cold) is off and the other open still no knock. with both open i get the knock immediately. i am starting to think the pressure balancing device is to blame. on this model there is a bore just left of the cold shutoff. it has a washer and a bolt in it. the spec sheets show picture of the valve and this extra bore. they show a "cartridge" in this hole.
ok, to the point...i'm wondering if this extra cartridge is something i need to take a look at, or if it's one of the shutoffs that is to blame, or if it's the central valve.
phew!
thanks
beng
phew!
thanks
beng
