View Full Version : Connecting metal drain to copper waste pipe
jlongo08889
12-27-2006, 03:48 PM
Hi .. I am pretty new to do it yourself plumbing. I am re-doing a half bath & when removing the sink, the metal drain pipe was so corroded, it broke a few inches beyond the copper waste pipe. How do I get the rest of the metal drain out & subsequently, how do I re-attached the new metal drain to the copper waste pipe? Looks like it is just soldered in?? Does that sound correct?
Randyj
12-27-2006, 05:08 PM
Got any pictures?
Mike Swearingen
12-27-2006, 06:18 PM
Pictures will help.
If it is straight piece of 1.25" chromed drain pipe, you can hacksaw off the corroded section and connect it to a similar piece of pipe from the trap with a rubber coupling with stainless steel hose clamps made for the purpose and acceptable to code (aka Fernco brand name coupling).
OR saw it off and use a compression slip joint connection on it.
Mike
12-27-2006, 06:33 PM
The Fernco with a rubber sleeve and two clamps is not accepted by codes. It is also a poor way to make the repair. The proper way is to cut the piece out of the drain and then put a new trap onto it. How to do it would require a picture so we know exactly what he is working with.
jlongo08889
12-28-2006, 08:07 AM
Thanks for the replys ... I will try to get a picture out here ... basically just a 3 - 4 "" peice of chrome pipe straight sticking out of the copper pipe. The chrome pipe ends just where the curve downward begins to start the P trap. The ens are a jagged mess because of how it snapped.
thanks -- Jlongo08889
Randyj
12-28-2006, 09:26 PM
Hmmm... trap adapter with appropriate nut & washer (male adapter with nut for 1 1/4" drain pipe)... cut tail piece and add tail piece extension with its appropriate nut and washer. To get the old piece out use something like a punch, chisel, etc. to drive in between the tube & pipe and try to get a bite on it with pliers or vice grips to pull it out... may have to heat pipe with propane torch.
