After repairing a leak in my water softener, the T&P valve on the water heater began dripping. I replaced the T&P but it still leaked. I put a pressure gauge on the water heater drain and it showed 150 psi. There is a pressure regulator that was already installed in the system when I bought the house 15 years ago. I have an expansion tank that was installed when the water heater was replaced 5 or 6 years ago. If I run water anywhere in the house, the pressure quickly drops to about 60 psi but just as quickly builds back up to 150 as soon as the water is turned off. Right now the pressure regulator is my chief suspect, but I don't want to go through all the work of replacing it until I am fairly sure that is the problem. My understanding is that the regulator only has an effect while water is flowing. I've been told that since the pressure builds up after the water is turned off it is a thermal expansion problem (BTW, the pressure goes to 150 psi regardless of whether the heater is heating or not. It is a gas heater) but I already have a thermal expansion tank. Any suggestions or advice would be greatly appreciated.
