View Full Version : Electrical Forum discussions
Pages : [1] 2 3 4 5 6 7
  1. Hello
  2. Proper termination of unused circuit
  3. Who is Joe Tedesco?
  4. How to check transformer operational
  5. Bathroom Vent Wiring
  6. A quick hello
  7. Transition from conduit to romex.
  8. How do I apply AIC or Interrupting Rating?
  9. weather proof electrical box
  10. Dryer wiring = no heat.
  11. Six Flaggs
  12. AC Blown Fuses at outdoor disconnect
  13. Rheostat for swamp cooler?
  14. My garage is electrically charged w/120v!!
  15. 12 volt transformer
  16. Screw vs. Backstab Receptacles
  17. Earthquake in nuclear power plant
  18. Pool Pump / Grid bonding?
  19. Battery
  20. What Fuses?
  21. Danger Zone ??
  22. Terminology question?
  23. Gfci/light
  24. The mysterious voltage transformer
  25. Auto re-set and wiring diagrams.
  26. Troubleshooting Ceiling Fan
  27. built in microwave outlet
  28. 15.6V Showing on Circuit - Why??
  29. momentarily dimming lights
  30. Another ceiling fan problem
  31. Why are 4" IC remodel housings so hard to find?
  32. Smoke Alarms - Hardwired & Interconnecting
  33. battery charger problem ... help please
  34. Outlets on Opposite Sides of Wall/Partition
  35. power generation
  36. Kitchen: Photoelectric Smoke or Heat Alarm
  37. running quick disconnect to central AC
  38. 240v single pole?
  39. Mounting Ceiling Fan to Exposed Beam
  40. Capacity of 1/.2 Flex
  41. Rewiring 2nd floor
  42. Residential Wiring & Crimp Fittings
  43. electrical Box fill
  44. "Best" Smoke Alarm Brand
  45. Oven/Microwave installed on same wall as service panel
  46. New Kitchen Circuits Using 12-3
  47. old wiring, any ideas?
  48. Fastening Wire In Walls
  49. Should mains be 110v or 120v?
  50. Placement of 2nd floor CO/Smoke Alarm
  51. Sub panel confirmation
  52. rain gutter conduit
  53. Code for Installing Wired Smoke Detectors
  54. Breaker Box Help
  55. Three way wiring
  56. table or chart for AWG
  57. wood paneling and outlet boxes
  58. Ceiling fan + switch help
  59. Remote control load switch?
  60. Straps for 1/2" Flex
  61. Tingling sensation in my in-ground pool
  62. Kitchen GFCI Problem
  63. 2nd floor subpanel
  64. Removing Unwanted Electrical Box
  65. knob and tube wiring
  66. Power to a double switch
  67. Wiring Flood Lights
  68. Electrical Switch Problems?
  69. off-center electrical box and light
  70. heated 120v floor and thermostat wiring
  71. Q about grounding
  72. switches
  73. Breaker questions
  74. Low Voltatge Lighting Issue
  75. Electric Hot Water Tank Trips Breaker
  76. Three Questions About 10-2
  77. ENT Bushings - Are they required?
  78. Lighting
  79. Weird Switch wiring
  80. Built in microwave needs dedicated circuit?
  81. Gfci
  82. Electrical code on Busway to a water line
  83. Installing Ceiling Fan On Vaulted Wood Ceiling
  84. A/C condenser hook-up
  85. Neutral/ground at sub breaker panel
  86. Wire or socket?
  87. Tightening Wire nuts /nut sizes
  88. GFCI Brands
  89. How to make light switch/outlet connection.
  90. Silicon in Wire Nuts
  91. How Many Outlets Can Be On One Circuit
  92. Wire Size / Fixture Attachment
  93. Phone Line Voltage?
  94. Questions about going to 200amp service
  95. light switch question
  96. Disconnect for water heater??
  97. Arc Detect Breakers
  98. Grounding, bonding, potential??
  99. complicating-updating new box for client, electrician F***** it up-pics included
  100. Idaho Electrical Board
  101. Stepping up/down voltage from incoming feed???
  102. Exhaust Fan Replacement Timer
  103. Engineer
  104. Question about moving stove line to dryer.
  105. Rewiring Knob and Tube in Attic
  106. Flickering?
  107. House Hunting Electrical Questions
  108. Generator Transfer Switch
  109. enlighten me on breaker
  110. Simple Workings of a Transformer
  111. Electrical Advice?
  112. Can I ground a 10/3 ungrounded wire?
  113. Ground Leak?
  114. Heated pet bowl question
  115. Shock from wall switch. Help!
  116. How many ground rods to install?
  117. gfi not reseting
  118. Voltage readings
  119. Junction box is a fortress
  120. Conduit size vs. number of wires
  121. Hot adapters?
  122. Subpanel
  123. Light above the shower..
  124. short light bulb life
  125. Where can I buy 10/2 Al wire?
  126. Lantern Style lights outside. Work box?
  127. Guidance needed: Power transmission and management concepts
  128. question on conduit fill limitations
  129. grounding question
  130. Electric box behind shower wall
  131. Wall Switch Off Power to light still on
  132. Stripping Romex Sheathing
  133. When Staples Won't Work...
  134. 3 way switch help needed
  135. Subpanel Circuit Question
  136. photoelectric eyes and CFL bulbs
  137. To bond or not to bond neutral
  138. Do all metal boxes need screw-in clamps?
  139. Rough in
  140. NRTL requirements for user devices ???
  141. Fuse amperage
  142. Concordia Sprecher
  143. why is cable tray no good for res.
  144. Conduit Question
  145. New fan installed has one very dim halogen bulb
  146. To pigtail or not to pigtail?
  147. Square D well pressure switch
  148. The House That Didn't Burn Down
  149. Wiring Problem
  150. How to Trouble shoot this???
  151. spliced 10 -3 wire question
  152. Dual sensor Dual head motion light?
  153. Box for Lantern style lights?
  154. Disconnecting power
  155. The new 2008 nec.
  156. Lowes Fixture Issues
  157. Electrical Questions
  158. GU10 type bulb dimmer
  159. Electrician Tool Belt
  160. Greenlee EMT Cutter
  161. Duo Styld Dimmer ?
  162. Ac/dc?
  163. Copper clad
  164. Running a wire through a header
  165. Two Fans--One Hum
  166. switched outlet with 3 way switches
  167. Exterior junction box?
  168. Subpanel Location
  169. J-box location
  170. Auto-Electrical Question
  171. Garage remodel questions
  172. Odd readings replacing an outlet.
  173. Can I use dryer plug for my steam generator?
  174. where to get NEC code?
  175. Seperate Electric Hot Water Tank Meter
  176. whirlpool tub motor grounding
  177. Who is KCPL trying to protect?
  178. 14-2 and 12-2 color diff at breaker neutral
  179. #12 or #14 wire
  180. 800a service
  181. Main panel breakers
  182. Basic Electrical Diagram
  183. Seperated Lighting and Plug Circuits
  184. sub panel info
  185. Riser
  186. 3 way switch.. I'm puzzled
  187. subpanel ground rod location and installation
  188. RV generator circuit protection
  189. Receptacle Wiring, stumped
  190. Split 240 line?
  191. minimum distance from walls/ceilings for lighting fixtures
  192. Breaker keeps tripping
  193. Anyone have any experience with Black Box Network Services' products?
  194. Electric Motor Question
  195. Low and high voltage in the same conduit
  196. Identifying Knob & Tube Wiring
  197. Aluminum pigtails from certain fixtures
  198. perm. removed light. what do i do with wires?
  199. Grounding outlet
  200. Kemore elite washer adivse
  201. Switch Placement Advice for Bath Refurb
  202. load demand for new water heater
  203. Assessing existing wiring?
  204. First Rough In - Basic Question
  205. Problem with circuit breaker. HELP!
  206. I want to know about adjustable speed machine (ASM). Can anyone help me, plz?
  207. Wiring a Spa. Do I use #8 awg or 6/3 romex slimpull ?
  208. Running wire through header
  209. Testing 220V with multimeter. What should the meter read?
  210. Electric Water Heater Timer
  211. Square D Circuit Breaker Recall
  212. Portable Generator Grounding
  213. Who's problem is this?
  214. 1 pole, 2 wire or 2 pole 3 wire switch for water heater?
  215. master bath electrical, how to do it...
  216. Lighting Near Tub ?
  217. In Box Indicator Light
  218. Circuit Planning Basics
  219. light in shower
  220. Bathroom and Closet Wiring
  221. Trailer Light Switch
  222. Double-Tapping?
  223. Garage & Exterior wiring questions
  224. Electrical Options For Garbage Disposal Install
  225. Grounding a portable generator
  226. Box capacity exceeded, need advice
  227. Extending ungrounded circuit
  228. Bath Fan in Shower
  229. 4" recessed lighting remodeling versions...
  230. Wiring Trouble
  231. Failed GFCI?
  232. Damp Area Confusion - Switches and Fixtures
  233. help with new wire basement
  234. NEC Cycle question for GFCI..
  235. How do you like your power plant, Well done?
  236. Wiring size for upgraded hot tub
  237. Surface mounted box
  238. I need to pull a new circuit for a hot tub.
  239. alumiconn
  240. Electrical box mess/questions
  241. Metal framing
  242. Outdoor 3-way switch and timer
  243. 240V electric water heater on 120v circuit
  244. Adding a light to a bathroom vent fan circuit
  245. Distance from main panel to subpanel (plus)
  246. Entire home rewire by non-pro..
  247. code question
  248. Double neutrals
  249. Connecting Motion Activated to Non Motion activated Flood Light
  250. GFCI Trip on cloths Washer
