- Cat 5e
- Overhead aerial lines crossing my property
- Are LED Lights ready for Home Use?
- Service entrance cable size & voltage drop
- Load center replacement
- Xfer switch hookup question
- Customizable Decora Switches
- Motion Sensor and compact fluorescent bulbs
- Basic electrical questions
- Is it ok to use two of the three existing 12/3 wire?
- outdoor security light
- Pulling low voltage wires through metal studs
- GFCI for Whirlpool Tub
- Breaker question
- Flickering Bulbs On Dimmer Switch
- House wiring question
- Broken swith at ceiling fan???
- GFCI in bathroom
- Double lugging
- Wiring light switches.
- Electrical Base Board Heaters from Home Depot-REVIEWS?
- This box fail to pass inspection
- Electronic equipment
- No 6 AWG Cable
- Confused on GFCI, AFCI or just status quo in the kitchen
- clue less
- No Ground for Outdoor Lights
- When they come to replace my panel...
- Self-grounding receptacle
- Whole house surge protectors
- Installing a Dryer 30 Amp power cord, 120/240 volt. what gauge wire?
- MN-B, 12-3/GRD inside 2" PVC conduit
- Forward, Reverse, Motor, 3 Locations
- Pushmatic circuit breaker
- 2 questions
- 2 Space Heaters 1500watts flipping breakers
- Bonding a surge protector to the eletrical system ground
- Does a ground wire nut need to be in a box?
- Disconnects:
- GFCI Outlet change
- Installing outside light
- Wiring Help for 2 Outlets (One on a Switch)
- Moving main panel to detached garage
- Floor warming... 120V mat vs. 240V thermostat
- Installing a Ceiling Fan
- Wiring new Panasonic bathroom exhaust vent
- FPE panel removel
- Installing a Big Box Store Electric Base Board Heater
- Best undercabinet lighting
- Can I install conduit underneath a baeboard heater
- Discovered a 10 AWG Cable
- Drilling holes in joists to run cable
- Advice for troubleshooting a bad circuit
- Baseboard Heater and misc wiring ???
- arc fault protectors
- Problem with GE RR7 low voltage relay.
- Smoke Alarms & CO2 detectors
- wires going in breaker box
- 3-way switch wiring
- Rewiring a 200 Amp electrical panel
- Timers switches
- Remote repeater
- 4 Wire Cable in a 3 Wire Connector Setup
- Outlet - 4 screws
- Copper Bus Bars Humm
- Installed 240v Dryer, used 10 gauge wire, 20 amp breaker-breakers flicking off
- Outdoor light flickering when use with CFL's
- Sizing a generator.
- new kitchen circuits
- Federal Pacific Panels
- Long distance outdoor lighting
- Electric Meter
- capacitor burn out
- 220v dryer out conversion to 110v?
- Adding a Single Pole switch coming drawing power from 3 way switch
- Running two power cables in same conduit
- CFL's
- closet lighting ?
- Convert 220 circuit to 110 circuit to be run to new subpanel
- J-type halogen light fixtures
- Proud DIY A day in pictures
- Couple of quick questions....
- HELP, outside light has gone crazy
- pex repipe
- Battery Powered Motion Lights?
- Reactor in a portable Miller Big 40 welder?
- Dryer Hookup
- Switched receptacle and overhead light??
- Leaky well pipe (PICS attached)
- Adding a motion detector to 2 garage carriage lights
- Thermostat Help
- Need to add ground wire
- New range - 3 wire connection
- lights on GFI protected circuit
- Opening Up and Electrical Panel
- Rewiring
- Receptacles far back from the wall
- Need Help Finding 0.75 mfd capacitor
- test your circuit before connecting to breaker
- Proper install of power lead cable for suntouch mat
- Shoddy Electrical work
- Sub Pump wiring
- What is wrong with this bathroom
- Converting 240 circuit to 2 120 circuits
- Circuit short help
- Pond heater...shorting out????
- Power on Circuit Off then On Again
- Want to run new feed to garage
- 3-way dimmer problem
- Is it wise to install service panel on outside of house?
- Flickering Light
- Light in crawl space
- a/c adapter?
- lighting needs
- Converting Surface Mount Panel to Recessed?
- Where should doorbell transformers be mounted
- Lamp post photocell hook up
- steam generator - wiring 8kw on 30amp break
- copper tubing wall thickness in propane application
- Exterior HID hums loudly when switch added
- More DIY electrical installations
- safest baseboard heating?
- GFCIs in the service panel? How many circuits?
- DIY - Split receptacle to light switch and light fixture with 14/2?
- Old Existing G.E. Circuit Breaker Panel
- Can THW wire be used underground in conduit?
- gfi problem
- Installing Overhead light, have question.
- receptacle piggy backing
- Porch Lighting
- grounding ?
- loss of power
- Outlet with 10-3 Romex
- This home is ready for inspection...
- Reverse connections @ GFCI receptacle
- How a phone center office still generate power to rj-11 port when breakdown?
- electric baseboard heat
- Two scary wiring mistakes in my garage
- Porch ceiling lighting
- 3-Way Switch Problem
- X10 switch
- Split 110v off a 230v branch circuit?
- Outlets stopped working
- Adding an outlet outdoors
- Sub-Panel Neutral and Ground Bonded
- Proximity of washer & dryer outlets to washer valves & tub?
- Ductbooster installation questions
- Retrofit underfloor radiant heating?
- Exterior 30a power inlet
- Gas water heater ground
- ROMEX® to dryer outlet - insulated ground?
- Recessed lighting and vent fan in shower
- 12/2 with ground but outlet ungrounded
- Why is a ground wire required from a generator?
- Light Switch - Not sure what to do
- NC Electrical Code - 20A GFCI Circuit in bathroom
- Thermostat - Where to insert wires?
- Generator sizing for submersible pump
- Dec. 25
- Code question on multi-location dimmers ( lutron / maestro )
- Can "any" schedule 80 PVC be used as electrical conduit...
- Any reason not to ground every light switch
- Adjusting wall plates - Moving switches & receptacle outward so wall plate looks good
- Tandem Breakers
- Loud hum from doorbell transformer
- "Clean" Romex installs...
- 2 way switch not working right
- Will two Taco timers work in parallel?
- 220V 3-wire ground install
- Not enough amps for Toto Neorest/Now what?
- #10/3 for single wall oven?
- drier electrical plug
- electric heater
- Above Range Microwaves
- Keep Buying DIY Books
- Upgrading house wiring
- Replace or is it ok?
- Premature lamp burnout
- adding outdoor outlet under deck
- New Basement Bath - Occupancy Sensors
- Wiring Bathroom/GFCI Circuit
- Proper Wiring in Attic
- GFCI receptacle install
- Replacing Washer outlet with dual receptacle
- Crimping ground wires in an outlet box
- Kitchen wiring and code
- 3-way Light Switch setup for 2 lights - can't get it to work.
- 220 V well timer. Where can I find one?
- Dusk dawn lights are constantly on!
- Short Circuit but Breaker does not trip
- New exterior receptacle in old brick wall
- electrial for new disposal hookup
- Ground fault interupter question
- Indentify Cable Outlet
- Bonding two sections of copper pipe with PEX between them?
- Light Switch to turn on wall outlet
- 60-cycle vibration from heating pad?
- Heat pump auxilary heat
- service riser needs for an electrical service upgrade?
- Wiring for boat lift motor
- Two hot and one neutral
- New GFCI installation not working.
- Whole House Surge Protect Sub Panel
- Correct wiring of GFCI Breaker
- 20A vs 15A GFCI for Bathroom?
- Will this circuit work?
- Derating for number of conductors in conduit
- Do I need conduit?
- Certain towns in Massachusetts can require a Licensed Electrician to do work?
- Electrical hook up of tub with jets and heater.
- Installing a 4 gang new work box--install another stud to support it?
- Bathroom heat question
- Grounding question
- Range outlet
- Wiring my shed with 10-3
- Smoke alarms: what brand should I buy?
- Multiple White and Ground Wires in Bus Bar.
- Old work boxes and mounting to studs
- Under cabinet lighting junction box
- 200 amp upgrade confusion
- Another grounding question...
- Under Cabinet Lighting Suggestions
- How many lights on a 15 amp breaker
- 12/2 with no ground into 12/2 with ground?
- ciircuit breaker test
- Radiant floor heat question.
- Explain Out of Phase Amperage?
- ??? Need some transformer help!!!
- Shady electrical work?
- strange occurance
- Underground conduit
- Best way to GFI protect can lights above a shower?
- 3 phase plugs
- "Thin" Breaker AFCI's?
- Suggestions for becoming an Electrician? Would like advice from current electricians.
- momentary switch
- Two GFCI Breakers in one circuit?
- Random light and appliance 'dimming'
- laundry: washing-machine clearance from switches
- Current on Phone Line?
- Can someone double check my wiring diagram?
- Wiring a shed
- phase converter wire size
- Supplying ground to old subpanel
- A very strange wire in the control panel (NEED HELP PLEASE)
- Stove Hood feed....
- Adding switched receptacle
- Dawn to Dusk sensor
- burnt smell
- Replaced two regular lights with fluorescents = Now they flicker - HELP
