- turning off a lamp
- Pole transformer exploded - danger from burning transformer oil w/ pcbs?
- panel box in a walk in closet
- Connecting a 3/0 Splice
- Are my "semi-shared neutrals" a problem?
- More than one hot lead to an outlet
- More DIY electrical
- decreasing xmas lights lenght
- Light Switch Behind Plumbing
- Water Heater w/ no heat
- Do It Yourself Book
- Recessed cans flickering off/on
- DIY gone wild...
- No Pigtail, Interesting Wiring,
- common trip breakers
- Subpanel Grounding
- Got a decent Shock! Ouch.
- 3 way with a dimmer
- Replacing recessed thermal overload devices
- exterior subpanel - mount as semi-flush?
- DIY Again
- Installing a dusk til dawn sensor
- 200amp service ground
- media panel needed
- plastic or metal junction boxes
- need second opinion- safe elec. heater install
- wire gauge change mid circuit
- Simple security system install
- Main Breaker Tripping
- 230-240 volt electronic ballast: info & proper use
- Electric Heater
- moving breakers and a power source question
- Cold cathode CF bulbs?
- Service Disconnect Fuse Contacts
- Combo fan/light above shower & GFCI
- Garage door opener
- Buzz Noise from Breaker
- Kitchen Remodel Circuit ?'s
- california master electrician????
- Lincoln Power Mig 140C Wiring
- electrical service anamoly
- Receptical Surge protector
- Main Disconnect Question
- Splitting vanity light into two
- Smoke Alarms, do they ALL work WITHOUT AC Power?[/
- Connectors for sockets for a Linear T5
- 2 GFCI receptacle ?'s
- Fan control for receptacle within fireplace - to code?
- 4-way old wiring question
- Ceiling Fan Options
- undercounter lighting
- Electrical Surges/Light dimming
- wiring ceiling fan
- Nice Electrical Photos Blog
- Replace or Not?
- low voltage wiring?
- Landscape LIghting Brands
- causes of electrical fires??
- Definition of mA
- pigtail or screws in receptacles
- circuit breaker question
- Misc Residentual Code Questions
- AC Cable to NM (ROMEX®)
- Recessed light in bath
- Can't figure this out! Need some elec. know-how
- 33 amp, 3-phase Clothes Dryer
- Extension cord for treadmill, ok?
- knob & tube question
- Electric Meter
- what is the best grounding option
- Some pics to talk about
- A few more
- Adding Circuits using ROMEX® vs. AC cable
- monitoring power usage
- Has anyone used or heard of the powershaver?
- Outdoor Conduit Conductors
- GFCI in bedrooms per 2009 NEC?
- Steam generator wire size check
- ceiling fan blades for outdoors
- Junk science or truth?
- Fan on non-fan rated box
- Help - guidance on recessed lighting
- Wiring and Insulation
- Attic wiring
- Double poll switch
- Flex Conduit as ground
- Got a Toughy! Electrical Box Cover
- why is this not attached?
- Light switch outside Bathroom and more..
- Breaker Won't Trip, Is It Bad?
- Xantrex DR 2412
- power saver magic??
- Electrical Engineer allowed to do Electrical work?
- 3 way dimmer question
- jobsite fan question
- Water questions for the electrical experts!!!
- Can I use 10/2 cable on a regular 12 or 20amp circuit?
- Leviton 6696 Anywhere Switch
- combining circuits
- The picture says it all!
- break up the walls or not
- gfci won't reset, dead line wires, lights on breaker still work
- Halo recessed light and shower trim......
- Why does light bulb blow?
- 4 way switch
- Ridged conduit
- partial rewire
- Static interference from flourescent lights.
- non ic rated recessed light
- Plugs off, Breaker On
- energy efficient lights
- Another GFCI question ..
- Garbage disposal on/off switch
- Antenna installation
- Ok to extend bathroom circuit to power tv on adjacent wall
- Well Pump Wireing
- Basement finish
- Change single receptacle to a duplex?
- Circuit breaker keeps tripping
- New Bathroom Fan Timer Switch
- outbuilding with 3 wire subpanel...I'm still confused...help?
- Arc fault circuit breakers
- what wire to use
- Hot Tub Installation
- Anyone an electrician or know a good electrical forum?
- Under cabinet outlets?
- Grounding Issue with PG&E
- Transitioning from 1/2" EMT to 3/4" RNMC
- TR Surge Receptacle
- Replacing recessed cans
- Wiring GFIs together, is this code?
- Was the right knockout hole used in this case
- how to fix a bad diswasher rough in
- To plug or not to plug into a GFCI outlet
- Wiring Tytewadd Power Filter into Panel
- Old light switch swap
- 240v 2 pole grounding switch to receptacle
- New Member
- mixing 12AWT and 14AWT wire
- New subpanel?
- Dishwasher + Disposer wiring help needed
- 50 year old electrical service enterance
- Connecting the dimmer switch to the nuetral line?
- Grounding gas line to panel...
- What's up with these configurations
- Help buying a generator for power outages
- Adding 4-way switches to a 3-way lighting circuit
- Wrong Way Breaker
- Burried Residentual Power Line
- Why are all my outlets GFCIs in my kitchen?
- GFCI Troubleshooting Help Needed
- box fill ?
- Basement finishing questions
- Oven outlet next to Bathroom Plumbing
- Single receptacle to a double receptacle
- Number of lights allowed on a circuit
- Kitchen electrical
- DPST switch question
- I'm a bonehead - three way switch help
- Issues changing to Florescent Bulbs
- bathroom light/fan operate separately
- help with subpannel
- How many amps can this panel handle?
- New GFCI
- Where to ground after installing pex
- Second floor, no ground
- Troubleshooting two 3-way switch setups
- FWIW, Checking a 4-way switch
- Fire Hazard? Expanding Foam - Electric Boxes
- 2008 nec question.
- Is this possible?
- Portable generator and generator panel incompatibility
- 3 wayconduit
- Ground Rod Dryer
- I need help please
- Wire question on bathroom fan/light combo
- Spa Wiring
- Handle generator 50W
- problems with house electricty, solutions sought
- Surge Protector Trips Breaker
- 220/240v from basement to kitchen.
- which is more efficient?
- 120V walkway lights linstallation
- Light Fixture w/Fiberglass in Junction Box
- Outdoor sub-panel for pool
- electrical wires near shower
- Main Disconnect Seperate from panel?
- Dimming Low Volt Undercabinet
- Wiring In Concrete Ceiling & Covering Junction Box
- Bonding
- Low voltage light flicker problem
- hot tub install, NEC 2005
- Number of circuits in living room
- Subpanel Neutral & Ground On Same Bar?
- Lights out
- Why are these voltage readings normal?
- Splicing feed to sub panel
- GFCI Outlet Trips with Lights or Fan Switch
- Connecting Second Load Center To Meter Base
- New User Hello - Old panel rebuild - photos coming? Some help old timer.
- Main breaker box clearance
- Question about subpanel
- under cabinet lights
- Open Hot
- Heat Detector
- Cooktop
- Receptacles
- How Many 2-Pin Base Configurations?
- Tabs on plastic electrical box
- wiring up the pond
- Stumped by 3 way switching
- Changing Bath Exhaust Fan
- Low voltage transformer help
- voltage question
- UL rating for bathroom lights?
- Correct screw orientation ?
- 230 volt question
- Outside switches
- Roof Mounted Attic Fan on a Dimmer Switch?
- Is there enough power here
- New Ceiling Fan Spark Out
- Inetrconnecting FireEX smoke detectors
- Wire to Subpanel - through basement
- 220v/50amp to Shop
- Sine wave monitor
- SPA Disconnect Feeder Ground
- Pot Lights - Insulation
- How can I tell if my wires are live?
- GFCI installation question
- Wiring baseboard heaters
- GFCI Problem
- PVC boxes
- electric outlet
- Gv
- Open Ground after change to GFCI
- Wires in electrical box
- wiring in bathroom
- Xfer switch question
- Taping Can lights
- Do I need conduit?
- Pool tripping GFCI breaker
- Test - can you spot a code violation?
- ceiling fan install question
- Does this seem high? Can I do this by myself?
- Tightening Can Lights
- Additional sub panel
- Wall Heater Wiring
- flourescent lights won't work together
- Running low voltage in high voltage boxes
- Grounding questions: Gas, plumbing, appliances
