View Full Version : Electrical Forum discussions
Pages : 1 2 [3] 4 5 6 7
  1. Garage door safety circuits
  2. Wiring Question about an air conditioner
  3. Does 12-2 copper carry same current as 10-2 aluminum
  4. 8-3 Romex in PVC conduit
  5. wiring a three way switch....
  6. Installing 220v circuit
  7. AFCI Circuit trips when I turn on lights
  8. Tracing a 110v outlet circuit fault
  9. Wall insulation around cabling - OK?
  10. Lighted switch on switch loop?
  11. Recessed Light 1 to 6?
  12. Is this switch ok for a 15A circuit?
  13. Temp Power Panel
  14. Long flex metal conduit instead of rigid pipe?
  15. kitchen peninsula outlet
  16. Recessed Lighting And Fire Rated Ceiling
  17. Mogul-base photoelectric socket?
  18. Connecting low-voltage conduit to electrical boxes
  19. In-Home Electric Meters
  20. AFCI breakers tripping every 7 days
  21. Adding new ground rod
  22. ked
  23. 208v Disconnect Grounding
  24. Running circuits along roof?
  25. Speaker wires
  26. Breakers: criteria for selection?
  27. Outlet replacement in Old Work
  28. Ground Bus in old panel?
  29. Advice on wiring external lighting
  30. Florecent light question
  31. triple switch and bath exhaust
  32. improperly grounded panel?
  33. Lost power to 2nd floor on siding installation
  34. Finding Hot disconnect
  35. 3-Way Switch help
  36. 4 way switch problems
  37. Sub Panel
  38. Ticking ceiling fan
  39. need some help
  40. Backstabbing (push ins) or screw terminals?
  41. reset GFI
  42. hot switch plate
  43. appliance grounds and two-pronged outlets
  44. 3 Way Switch power fails at Light
  45. choosing a disconnect for heat pump...
  46. Two visibly identical conductors, 1940s house, which is hot?
  47. Our dishwasher overflowed and now the 220 breaker on stove keeps going off, when we t
  48. Wiring New Cooktop
  49. breaker size for 12 gauge wire
  50. Wacked out outlet
  51. Service Panel Problem Bryant Breaker Fried
  52. What is the name of the tool??
  53. junction box and code
  54. Faulty Wiring - Electrical Fire
  55. Service Entrance Conduit Body Size
  56. Which holes in weatherhead?
  57. GFCI Trips when Light Switch is Turned Off
  58. Air Conditioning Energy Saver Switch
  59. Exposed Wiring
  60. Ceiling fan question
  61. Embedding conduit/raceway in Plaster wall
  62. Lead Acid Batteries
  63. Suggestions for wiring/breaker for dedicated A/V outlets?
  64. water heater whip
  65. Great Idea For Switches
  66. New circuit added via rear knockout in service panel?
  67. Wire size question
  68. Rewiring a house
  69. Bad Breaker?
  70. Ground Wires Only Twisted
  71. Electrical Troubles
  72. electrical plan for Kitchen remodel
  73. Wiring Plan - Do I need a subpanel??
  74. Upgrade to 120 amp service without rewiring?
  75. Online wire fill table for PVC?
  76. Tree Touching Wires
  77. Basic Wiring Question
  78. Replacing old sub panel 1950's
  79. Help reconnecting a 4-way switch
  80. Video projector
  81. Magnet Question
  82. Box make up
  83. Transitioning Conduit material types
  84. Running a ground wire in conduit to plumbing
  85. Circuit Breaker Trips same time every night
  86. Mountain Electric
  87. Code Question for UF cable
  88. Intermixing wire size
  89. Loop of wire outside of boxes. Is this normal?
  90. Electrical Outlet For Welding
  91. How many neutral conductors do I need?
  92. The load center game
  93. Help with an electrical debate...
  94. Need suggestions
  95. Install Lighting From Fan Source
  96. Light Dimmer ?????
  97. Phantom voltage
  98. I am confused
  99. Interpreting labels in Load Center
  100. Is This Up To Code?
  101. Wiring a new Kohler Whirlpool...
  102. Electric Stove Works but Oven Doesn't?
  103. How to Choose Outdoor Light
  104. shocking bath tub fixtures - literally
  105. Radon Fan Installation
  106. gfci - can i feed multiple receptacles?
  107. Internal cable clamps and old wiring
  108. Any NEC collectors out there?
  109. 15 amp to 20 amp
  110. To avoid any fruther confusion....
  111. Box Fill Calc?
  112. PVC conduit for residential install
  113. tester prongs not long enough?
  114. Bathroom over fuse box
  115. Switch Wiring Nightmare Pictures
  116. Code Question
  117. Code Question
  118. HPS light problem
  119. LED cabinet lighting
  120. External Outlet requirement
  121. Wiring issue with motion detector
  122. Joe T. is Now Logging?
  123. Generator Transfer Switch
  124. Main Service Panels separate neutrals but multiple grounds in bus bar
  125. Pre-wired office furnature
  126. electrical recirculating pump
  127. What is this copper wire under the kitchen sink?
  128. Using ROMEX® to feed subpanel, do I have to derate from Table 310.15(B)(6)
  129. Making an automatic transfer switch
  130. switching 15-amp to 20-amp (basic Q's)
  131. Encountering cut panel ground wires
  132. Double Lugging
  133. Panel box location
  134. VERY odd problem... HALF a power outage??
  135. Similar Odd Power Outage problem too....
  136. Electrical Mistakes Video?
  137. Hot tub question
  138. What would magnetize a receptacle?
  139. Old house wiring...
  140. Medicine Cabinet with 15 amp receptacle
  141. using a 15amp switch for disposal
  142. Mystery components
  143. Pole Vault
  144. Branch Circuit Partial Run in Conduit
  145. circuit selector switch
  146. Bulbs are humming
  147. whole house surge supression recommendations
  148. outlet issues
  149. Oven Tripping Breaker
  150. code compliance - GFCI and tamper resistant
  151. Adjusting receptacles due to new tile
  152. Aluminum wire and plastic conduit or copper and metal?
  153. GFCI / GFI recommendation
  154. Thank you for your help!
  155. Gfci: Co/alr
  156. Touch Switch Controller for LEDs
  157. interesting GFCI issue...
  158. Where Do I Begin? Fan Motor Squealing
  159. ceiling fan runs, but slowly
  160. Ground wire
  161. is it safe - light switch question
  162. Fixture malfunction?
  163. How to replace a candelabra socket in an outdoor light
  164. opinion about running co-ax
  165. Shared neutral
  166. Bathroom Exhaust Fan/Light w/ Damper??
  167. Some thoughts, please
  168. Recessed lights burning out
  169. LED outdoor lighting requirements
  170. GFI weird issue
  171. Insulation color
  172. 120V to 12V AC Transformer Wiring Question
  173. Code Question: MC cable touching copper water pipe in ceiling. Problem?
  174. Basement subpanel issues
  175. Bathroom wiring circuit question
  176. New bathroom medicine cabinet & sconce--old walls & AC
  177. 30A Fusible Disconnect Switch w/ Copper Pipe used as fuses
  178. Breaker did not trip
  179. No warm air in the dryer
  180. 3-way switch configuration advice
  181. rewiring electric heater
  182. 100 amp sub panel load question
  183. sub panel?
  184. Led Landscape light kits
  185. 15 AMP switches
  186. Oven Range hookup
  187. Outside Light
  188. Three wire 220 to 110 VAC
  189. Transfer switch conduit in framing
  190. request for opinions - wallplate and receptacle colors
  191. outside spot light
  192. Installing a wall sconce
  193. Basement - Can light vs Other
  194. Hidden electrical boxes in ceiling.
  195. Flickering lights
  196. a trip curve for a plain-vanilla resi
  197. Pulling wire through existing conduit
  198. Resi Circuit Breaker test plan, comments please
  199. Well Pump Wiring
  200. reduced voltage at outlets, and ground test question
  201. Working length of wire
  202. Oven Blew Up at Connector with Element
  203. Medicine cabinet install
  204. Outlet ground prong orientation
  205. wire nuts and electrical tape
  206. 30 amps through #12 wire?
  207. Help with electric heater connection!!
  208. A/C Condenser and Air Handler
  209. DIY Electrical
  210. Questions for the Electrical Guru
  211. More DIY
  212. Code for Ethernet / AV wires
  213. 25v on my neutrals
  214. a simple question
  215. Servers tripping GFCI
  216. main panel humming
  217. Replacing Flourescent Ballast
  218. Celing Fan wiring
  219. Main Circuit Breaker Panel Humms
  220. Smoke Alarms and Outlets
  221. profiles
  222. really simple plug/receptacle question
  223. Humming Dimmers
  224. Electrician starter kit with toolbelt
  225. Jacuzzi, GFI, receptical, butter knife...
  226. Common Wire
  227. dressing a panel
  228. wiring two switches for a gas fireplace
  229. Christmas light question
  230. New pool wiring
  231. one smoke detector or two
  232. 240 v install
  233. Is this safe/compliant/doable?
  234. Under Cabinet Lighting with Transformer
  235. Component wiring
  236. Recessed Lighting Help Needed
  237. Tree wiring
  238. Lights flicker and Voltage Drop Question
  239. Leyden Jar
  240. An exception for NEC Table 310.16, is it possible? Comment please
  241. Electric motor wiring ?
  242. Lightning Facts
  243. Ground resistance
  244. Chrismas Lights And Moisture
  245. Why a small shock through a switch that was off?
  246. Advice needed, problem with short wires in box
  247. embedding panel into drywall
  248. Electrical Code Violations
  249. What things not to do during an Electrical storm
  250. Recessed light over shower
