- Ungrounded light fixture
- single pole double circuit breaker
- Best option for spa wiring
- Another gfci question.
- Wiring Diagram for Bathroom
- Hot fuse box
- Box extension
- Panel Rough-in
- Laundry Room Wiring - Did I goof
- No room on busbar
- weather tight 3/4" plug for a plastic timer box
- Stove circuit sleeve question
- New three way switch and cable
- Water Line/Electrical/Gas in Same Channel
- AFCI Vs. GFCI
- Wet Bar Wiring
- Plastic boxes?
- tip(s) for replacing a meter panel
- 4 Wire cable?
- Cable connectors necessary?
- Cable TV Transfer Unit
- Electric Out on One Side of House ????
- Telephone junction box ground wire?
- What Leads For A Digital Multimeter?
- Pigtail, forced air heater
- GFCI outlet AND breaker?
- meter Breaker Panel Configuration
- No idea when to use conduit
- nuheat floor mats wire hookup
- Supporting MC/AC/BX
- Size of service entrance cable?
- FYI Saving energy using small lights?
- Getting zapped by DC Voltage
- Bye Bye Thomas Edison!
- Placement Of Service Entrance Panel
- Load calculation?
- Square D panel?
- wiring 2 way switch
- max number of branch circuits
- Anyone know if there are new ARC FAULT requirements in NEC 2008?
- Christmas
- 2 wire upgrade
- Laundry in bathroom, GFI required?
- Electricity is out in a bathroom
- running new cables
- Smoke Alarm Goes Off When Battery put in
- GFCI Breaker vs. Receptacles
- Alittle Electrical Help
- Whole house surge . . .
- Scrollsaw toast? Plugged into 220V!?
- Trying to pass a Tech. IV test!
- Conduit for Ethernet
- GFCI outlet / 2 lights / switch at end of run
- crazy high electrical bill
- Table Lamp
- Swithching 240 Volt, 2 leg circuit
- Toggle switch help[automotive]
- 100A Main Panel…..100A Branch Circuit?
- No Idea how to do a load calculation.
- installing a sub panel
- Power fizziling out
- update on panel install
- I Need More Power Scotty!
- hole making for recessed lighting
- Door Clearance?
- Outlet Tester has all 3 lights on
- carbon monoxide and smoke detector placement
- Running wire between studs
- Heating vent
- Wiring in air shaft
- Badly rusted outdoor junction box
- Main lug as a primary service panel
- Can loose connections overload a fuse?
- Which brand of electrical panel?
- Any reason this can't be done:
- Electrical outlet question
- Where in the NEC does it say "This is really dumb"?
- Becoming an Electrician?
- wiring path for lights
- Motor setup advice
- Light bulb laws
- 1-1/2" deep multi-gang electrical boxes
- Strange architectural lighting wiring
- Tempory fix for outdoor panel
- finishing 1500 sq ft basement, wiring from scratch to subpanel
- Best Drill Bit for Electrical Wiring
- Advice on How to Itemize Electricity Usage
- In Floor heating system's Thermostat
- Outdoor wiring of Christmas lights
- Two F4T5/CW bulbs failed
- temporary power pole
- GFCI will not reset.
- Surge Protection
- Power cord for plama TV
- Floor outlets
- Lighting
- Number of Outlets/lights
- range hood
- Load Center Wiring Questions
- ground electrical boxes
- Cool DIY Project...Needs your "Approval"
- Basement Layout
- Grounding cold water pipe
- Could i wire this way?
- Capping off light switch.
- bathroom vent/heat lamp combo
- Bonding ground rod to water pipe to nuetral bus
- Incandecent Buzzing
- Switch problem
- Vanity Light
- electrical voltage converters
- Newbie from Utah needs some advice with 4" recessed lighting
- Knob and Tube in attic / insulation
- Light Socket
- Monitoring power consumption?
- Receptacle question
- flourescent disconnect
- Can Lights
- Arc fault testing
- Electrician Services
- No lights
- "retainers" for breakers?
- Why did I get zapped?
- Two Garbage Disposals 1 Switch
- Your opinions
- Can someone explain what's going on in this panel? (Pic included)
- Secondary (supply) line question
- Do I need a building permit/inspection
- subpanel
- Conduit recommendation for spa
- Ceiling Fan Motor Wiring
- Question on Ceiling Boxes
- New Breaker Box
- Conduit Fill Question
- Joining solid and stranded wires
- Old Knob and tube removal
- Hum and Delay in garbage disposal
- Hot box
- How to tap off a receptacle
- My water pump circut breaker
- Power disconnect panel for spa...
- electrical supply proximity to propane line?
- electrical wiring deficiency?
- whirlpool tub with accessories
- Fan Issues
- Circuit still has voltage?
- Outlet will not accept load
- hood height
- Wiring a 6-20R Plug
- Need to find old light switch stuff (circa mid 50's)
- fewest splices possible?
- Outlet Depth
- 2-12gauge and a 14 gauge for ground?
- Can this happen?
- Backup power DC/inverter approach
- What did I do wrong?
- Copper ain't the only thing going up!!!!!!
- Distance of Telephone (POTS) wring?
- Maybe some Electricians can help with this...
- Power Sags
- wall sconce rough-in height?
- Electrical Box in 2x6 T&G ceiling
- Compact flourescent bulbs
- Re wiring to to 12-2 /14-2
- Adding a 3rd wire to switch (neutral)
- New 220 4 wire stove and old 220 three wire plug
- Wire Nuts
- bit of confusion now...
- Question about stacked switch
- Question about junction box for exterior
- Circulation Pump Operating Cost
- flexible metal conduit/greenfield
- Another question
- CAFI and GFCI Breakers
- Wire protection
- Re/Moving a light switch
- Ceiling fan
- 240 to 120 outlet conversion
- moved pad mounted transformer
- Light And Fan Switch In Bath
- redoing dryer 220
- heavy gauge bare copper wire
- 20 amp rated fan timer on 15 amp circuit?
- Right controller???
- Fuse blown after plugging in heater now light dims when another is turned on.
- Ceiling Fan Wiring
- Route question,Light question
- romex wire and breaker to use
- Wiring above ground
- some grounding questions
- Timer for Water Heater (Pictures)
- Refrigerator problem: freezer keeps defrosting
- dishwasher won't stop running
- wanting to add a 100A service to my garage
- Buying electricity from a neighbor....issues?
- Generator .... any good?
- Changing receptacle
- What the?
- Main house wiring
- direcTV Sattelite dish mount
- Making a safer circuit i am told anyone of these do
- Bit of trouble - splice wire in exterior conduit LB?
- Installed new low voltage recessed lights - now switch hums
- Whirlpool Wiring
- from one box to the other
- Media Panel Height
- Dishwasher and disposal same box
- Protecting MC wires in PT framing
- Simple - easy question
- Cell Phone Battery
- Don't use extension cord for freezer?
- My Bathroom Light Went Kaput, Help!
- Bath Electric Code
- how to determine number of recessed lights
- photocell + CFL don't play well with DSL
- Whirlpool GFI -- Stumper
- strange power loss
- Two lights on Two 3 way Switches...Only one comes on?
- 3 phase vs. 2 phase?
- Replacing Main Panel
- Jet Tub wireing
- Conflicting info, RG 6 & ROMEX®
- power flickering
- Water pipe used as electrical ground?
- DIY Inspection
- Electrical breaker
- need help identifying a tool
- GFI in series?
- Outdoor spa wiring questions
- Broan Bath Vent Model 655
- replacing range unit with seperate peices
- wireless remote to a whole house fan
- Pool Wiring
- Wiring and CB overkill
- Please help; what this Question meaning
- does this make any sense
- In Trouble Again
- fluorescent light bulb's don't work with Timer's?
- flourescent ballast ???
- Wiring question
- What's the difference between 240 volts and 220 volts?
- New Service Panel Question
- Spa GFI Location
- Replace weatherhead without turning off service?
- location of service entrance
- halogen recessed lighting calculations
- Heavy Duty Electrical Plub/Outlet question...
- Can overhead service wire be run inside conduit?
- Do I have a problem?
- Dedicated Plasma TV circuit
