View Full Version : Remodel Forum
Pages : [1] 2 3 4 5 6 7
  1. dwv system for new 2 sink installation
  2. shower base installation
  3. Laundry room remodle
  4. subfloor -- toilet
  5. extending galvanized piping under a vanity
  6. concrete shower base removal
  7. copper tubing for propane
  8. Bathroom remodel DWV Venting
  9. replace tub with shower
  10. How much green board or cement board for shower
  11. Installing laminate flooring in the bathroom
  12. Ideas needed For Basement Flooring
  13. Dual Sink Drain Problem
  14. New 2nd Floor Bath above 1st
  15. Installing below grade Basement bathroom and kithenette must break concrete floor.
  16. Water dripping from bathroom into dining room. Help!
  17. Short move of toilet in slab floor
  18. Cutting Corian-type product
  19. Swapping tub and toilet--how much work?
  20. Second Story Bathroom Addition
  21. re Plumb
  22. 1/2" compression to 1/2" compression shutoff
  23. Delta handle installation on PP stem?
  24. Condensation (?) inside kitchen vent
  25. Swap toilet and sink...and then some
  26. Bath Remodel
  27. bath addition
  28. Offset flange
  29. Hot Water Recirculation
  30. Kitchen Remodel - No previous dishwasher
  31. basement bathroom
  32. Cememt Laundry Tub
  33. Ataching a basement partition wall
  34. What does the ceiling edge attach to when the wall is between joists?
  35. Rough in dimensions?
  36. house trap
  37. Who to call to cut marble for sink
  38. tile surround for whirlpool tub
  39. Fresh air for furnace
  40. Want to move washing machine - vent question
  41. diverters and showers
  42. adding floor drain for second floor laundry room
  43. laying tile floor - what is proper subfloor?
  44. cast iron tub - refinishing exterior - suggestions?
  45. stained marble sink top - how to clean?
  46. Sewerage pump install
  47. sewage ejector
  48. Remodeled Bathroom Venting
  49. Special Fitting?
  50. dual sink connections?
  51. 3" PVC stack into Cast iron cleanout
  52. Install Jacuzzi on Cement Surface
  53. new shower
  54. Reroute Soil & Waste line?
  55. Wall mounted lavatory faucest-good,bad,ugly?
  56. Fireblocking and speaker wire conduit
  57. Remodel has drain problems
  58. Dishwasher replacement
  59. Need help with rough-in
  60. Kitchen Sink Venting
  61. Underlayment for vinyl flooring - screw vs nail
  62. Main stack venting
  63. Block off main drain lines in basement
  64. Bathroom vent fan discharge options
  65. Ripping WonderBoard...
  66. To tile or not to tile, That is
  67. Rerouting vent for Pedestal Sink Installation
  68. dumb thinset question
  69. Basement rough-in
  70. underground toilet rough in
  71. q on rebuilding tub surround
  72. venting sink
  73. Lav vent as trap arm?
  74. Connecting backyard drain to slab house
  75. 3" ABS to 4" Cast Bell Hub
  76. Replace tub/shower valve with 11 1/4 inch spread
  77. Installing Shower Base
  78. Tool question- Nail guns
  79. Something doesn't seem right here....
  80. Need air inlet in laundry room?
  81. Remodeling bathroom: part 1 of PVC piping complete (see pic)
  82. Remodeling Help
  83. Proposed Layout, Please comment
  84. waste, vent questions please ...
  85. Washer Drain requirements....
  86. Proposed layout please comment, This is try #3 :-)
  87. Yet another Drain vent pattern :-) Please comment
  88. Harizontal vent, how far
  89. installing new vinyl floor
  90. stack pipe
  91. moving shower drain
  92. Drywalling around fiberglass shower
  93. Refinishing?
  94. Going vertical from a horizontal waste line
  95. Remodeling problem - floor
  96. Floor Tile Question
  97. Bathroom tile installation.
  98. Not a weekend project anymore...subfloor questions...
  99. tile on wall
  100. Grout Lines on Bathtub surround
  101. sewer gas smell from ejector pump *also in 'pumps'*
  102. Kitchen Remodel
  103. What do I need to straighten the floors?
  104. help with jetted tub
  105. Gap between tile and lead bend
  106. Best laser level
  107. Tiling under a toilet flange
  108. Know anything about Copper Sinks??
  109. Replacing sink undermounted in granite slab
  110. Buy a compound miter saw or keep the one I have?
  111. foundation opening for plumbing
  112. Air Conditioning
  113. Bath remodel - venting questions
  114. Best laser level under $400
  115. Cast Iron: Cutting and joining to PVC
  116. Finding Studs
  117. basement rough-in questions
  118. Resilient channel/soundproofing
  119. Subcontractor damage during remodel
  120. kitchen sink disposal
  121. COPPER or ABS for drain replacement?
  122. faucet set in deep well
  123. Waterproofing
  124. Cut the door?
  125. Plumbing Remodel Configuration: advice/feedback needed
  126. Installing new washer/dryer connections
  127. Demolition Advice
  128. P trap not into wall?
  129. drain layout
  130. Mystery Drain Pipe - how to connect?
  131. Replacing interior doors.
  132. Sealing a concrete basement floor before tiling
  133. burring cast to abs connectors
  134. Starting a major project
  135. Rerouting supply lines?
  136. Washing machine & ice maker boxes by IPS
  137. Shifting to the right?
  138. kitchen faucet
  139. window in shower: remove frame or not (advice needed ASAP)
  140. recessed bathroom cabinet
  141. Moulded shower base over exisiting shower base
  142. bathroom remodel / resale question
  143. Tiling over mosaic bathroom floor query
  144. Dryer vent pipe does not go all the way to the roof in attic
  145. Would appreciate professional critique before inspection time
  146. More critique wanted
  147. Replacement Kitchen Sink
  148. No Ceiling Joist available for wall???
  149. How to determine what length faucet I need
  150. How much can a 3 inch drain tolerate?
  151. Subfloor cut-out for toilet flange and other questions.
  152. Distance to stack
  153. Questions on replacing tub/shower with shower
  154. Removing drain & plug (Delta) from bathtub
  155. Help Identify PVC Pipe & BR arrangement
  156. Problem with PL Premium not sticking
  157. Help needed!PLEASE!
  158. Floating wood floors?
  159. Vent pipe length
  160. tub to switch length...
  161. Framing question - potential sagging soffit
  162. Bathroom Remodel - Toilet Drain Lines
  163. Venting toilet
  164. Relocate Toilet - Solid Slab Foundation
  165. greenboard or cement board?
  166. Washer Dryer Connections
  167. Many Many Thanks To All Of You
  168. What brand of faucet?
  169. retro fit corian countertop
  170. Do faucets with ceramic valve worth the price?
  171. Non-removeable lavatory drain popup
  172. under pressure
  173. Break Old Plumbers Putty Bond?
  174. Basement's raised bathroom pipes leaking under the raised concrete.
  175. Refinish acrylic shower pan
  176. Nailer for Framing
  177. Rough-In Move?
  178. Vikrell material tub by Sterling
  179. Raw edge of laminate countertop
  180. Cleanout On Existing Vent?
  181. Task order on 2nd fl remodel
  182. Removing shower recepticle
  183. Sewage pump basin
  184. Anyone know anything about concrete?
  185. is 1 1/2" DWV large enough for new toilet?
  186. New Upstair Bath: Vent Ques?
  187. Upstairs bathroom
  188. Toto sinks w/sanagloss
  189. ABS to Cast Iron Hub
  190. Lower tiles in shower popping
  191. How feasable are these bathroom remodel ideas?
  192. Drilling into ceramic tile, bathroom...
  193. cpvc vs aquapex
  194. towel warmer
  195. Moving Kitchen Sink Drain
  196. how high up for new basement shower/toilet?
  197. Replacing galvanized in a tight space
  198. Cast iron DWV
  199. use of plastic or felt paper behind cbu
  200. Concrete slab repair question
  201. where to start?
  202. need advise
  203. What is your favorite interior latex paint?
  204. Self-vented electric dryer
  205. Pipe Sizing for Half Bath
  206. Plaster Cutting 101
  207. Furnace Efficiency
  208. glue on plaster walls four feet up ...
  209. Connecting PEX to Galvanized
  210. what's the best way to demo part of a lath-and-plaster wall?
  211. cutting rsi solid surface vanity top
  212. help needed finding odd size copper fittings
  213. iron pipe wet vent okay?
  214. Common venting
  215. Repair damaged door jamb
  216. Bathroom vanity replacement issues..
  217. bathtub p trap and drain
  218. Stack Support?
  219. Out of square door and bowed
  220. add-on construction
  221. Natural Gas Supply Line
  222. Tiling around a copper sink
  223. New Bath in Existing Garage
  224. Running new copper
  225. Pocket Door
  226. Second floor bath tub issues
  227. Fire Blocking Garage Attic Stairs
  228. U-Build Machine & Power Tools Catalog
  229. Pipe Size for new Bathroom
  230. be careful out there!
  231. Advice on running waste pipe
  232. oil tank location question
  233. shower remodel on slab
  234. kitchen sink/counter top replacement
  235. please assist dwv setup.....
  236. Finish Nailer for trim/molding?
  237. Rusty Oil Tank
  238. Are Glass Tiles The Trend Of This Year?
  239. Cracks in plaster ceiling - cover w/drywall or tear out?
  240. GardeningVoice.Com
  241. how to seal downspout joint
  242. plumbing wall
  243. replacing bath fan
  244. location of bath ventilation fan
  245. basement bathroom on slab
  246. any incentives to upgrade hvac system?
  247. Kitchen Sink Replacement
  248. remodeling to accommodate elderly with cane/ low vision
  249. undermount kitchen sink
  250. Basement framing proximity to floor drain
