- More tile questions
- Subfloor question for tiling a bathroom floor with heat mat under the tiles
- Paint
- Granite tile countertops
- Quickest/best way to paint cabinet doors?
- Acrylic over oil-based - How badly did I screw up?
- Dealing with Mold.....Irene Flood
- 2 layers of insulation
- Remodeling with Mold - To Live with it or Not
- What kind of wall construction is this?
- Uni-strut question!!!!!!!!
- recessed lighting for suspended ceiling?
- Bathroom venting out of new siding
- Finished Basements - Rebuilding her back
- Give some for Home Renovation
- What whites best match Kohler white?
- Finished wall needs insulation
- Panasonic Vent Fans
- ErgonoMIX Concept - A revolutionary invention in the field of single handle mixer fau
- Old house renovation or new build house?
- Regrouting tile bathroom wall
- The World's Ugliest Buildings
- Outdoor carpet adhesive question
- Costs for our house construction
- Leaving the Drywall Short - Baseboard shall cover it
- how to reduce the moisture issue on my basemenet?
- Indoor Clerestories (Frosted High Window Above Eye Level)?
- basement soffit - should I worry about sag?
- Difference between Panasonic bathroom fans?
- Tiling a laundry/furnace room
- OT: The demise of another brand
- Vapor barrier with new shower
- Tub surround question
- Screws for door hinge
- Vintage Tiles - Any Good Sources? PIC
- Kitchen sink
- Any professional tilesetters in here - Ditra Mortar Coverge
- Basement remodel begins this week, any feedback will be greatly appreciated
- New Laundry Room
- interesting neutral plane concept
- Testing Foundation Leak - Just curious....
- Leaks in wall
- Brown Constuction Paper --- Builders Paper
- Carpenter's Pencil and level in one. Not only that it has a magnet and ruler
- Bathroom Vent Fans
- Feng Shui and Light: Use Light Energy for Good Feng Shui in Your Home or Office
- Drain and Vent question in small bathroom
- Tavy Thin skin membrane
- Disposal dischage / wall drain stub
- basement bathroom and utility room floor insulation
- winter vent for house with wood stove
- Ceiling Lights ?
- Attn: Dana, Clever Solution
- Permanently Remove Cast Iron Baseboard Radiator
- Shower and Toilet Venting Question
- Under Cabinet Xenon Lighting
- Overhead garage door repair - frustration
- NuTone door chime problems
- Basement Insulation
- Insulation in attic
- Basement Tile
- Open Ended Question - Epoxy Grout Labor
- Alside Patio Doors
- Just wanted to share......new flooring finished
- roman tub remodel
- Tub/shower surround
- The ART of laying it out
- basement remodel vent routing question
- Bathtub troubles...
- Shower drain re-venting question
- Attic insulation
- Finishing My Basement - Insulation Questions
- Subfloor type? Thickness? Drywall?
- High tech bath solutions
- Why R10 but not R20 for Basement Wall in MA
- Basement stairs issue
- Attic Blown In Insulation Remove Or Blow More Over It ?
- To Seal or Not to Seal the Stair Landing
- Which is a good Rotary hammer drill to buy for my remodel job?
- Remodeling Forums ?
- Window Well Escape Ladders
- Is there a big differance in a SDS MAX shank and a spline shank on quality?
- Window Condensation 101
- Interior costs calculated correctly?
- Soundproofing around a shower?
- Moving W/D and floor drain
- Want to Convert Attic in 1920's Colonial to Closet
- How would you insulate this
- Slab top-side vapor control — Airspace approach
- basement doors requirments?
- Basement refinishing- how to keep mold away
- basement floor XPS foam
- tape for foam and sealant for plastic sheeting
- Pre slope and water leak test
- plywood for subfloor questions
- questions about installation detail
- New bathroom install help! Rough-in Plumbing
- how to handle internal concrete walls?
- grean board and pink board
- Sheffield Fusion-Welded Vinyl Windows
- Roofing Question
- Mildew inhibitor for indoor latex paint?
- New vanity install - P trap issue
- plumbing for new vanity
- Code for an exhaust vent next to a window
- Adding an attic bathroom
- Radiant Barrier Insulation vs Fiberglass
- Electrical Wiring Capacity / HEAT
- Roof
- Crawl Space
- Hit a brick wall...could really use some advice
- how to figure wall and ceiling space
- Bay and Bow Windows
- what's AdvanTech subfloor?
- 2x4 frame bottom plates issue
- Cathedral ceiling insulating
- New Bath In Basement...Ejector Pump/Pit tie in
- Vinyl Siding?
- Broken Waste Pipe - Repairing it and looking for answers in Vancouver
- Garage Door Opener Spring/Trolley Nut
- Excalibur II Fusion-Welded residential Vinyl Windows
- project progress and electric panel issue
- add subfloor in basement bathroom
- Effloresence in Basement
- Laminate Countertop Replacement
- Fairfield 80 Series Residential Vinyl Windows
- קרמיקה
- 70's Raised Ranch....Unvented Attic
- Garage Door Opener The Saga Continues
- Basement window wells
