View Full Version : Remodel Forum
Pages : 1 2 3 4 5 6 7 [8] 9
  1. Wood stair tread over concrete
  2. Old house basement staircase delima...
  3. Refinishing hard wood floors w/ stains
  4. Range Vent ??
  5. Basement Bathroom Tiling Installation Questions
  6. Kitchen Window Opinion??
  7. Basement Bathroom Flooring options
  8. Header Question
  9. Self Leveling compound question
  10. Gas Dryer Won't Get Hot
  11. Bathroom exhaust fan vent flashing
  12. Framing inside basement glass block windows
  13. Vapor Barrier needed for basement bathroom wall?
  14. Garage Floor Raise Questions...
  15. Mini Disaster in Scarsdale, NY
  16. attic insulatiom
  17. hollow sound under self level compound
  18. Drywall Question
  19. May not be a good question to ask but...
  20. Is "dry" mold a problem?
  21. Refinishing cherry wood kitchen cabinets?
  22. Proper way to vent bathroom fans in Las Vegas
  23. To insulate or not to insulate a basement bathroom??
  24. Finish half of the basement
  25. subfloor in basement which is correct
  26. How to insulate the exterior walls under a 3 season room.
  27. Drywall and radiant heat
  28. Finding the right tub help?
  29. 9-year-old Belltown high-rise too flawed to fix
  30. Can you hide plumbing for a pedestal lav installation behind the sink column?
  31. Tile first or cupboards first???
  32. sub-floor
  33. Unpleasant surprise between siding and interior walls.
  34. Heat Detector in attic
  35. final sub floor over concrete plan (I hope)
  36. Ensuite reno, adding shower, moving toilet
  37. Door measurement question
  38. Ponding on new flat roof
  39. looking for info on laundry room floor drain
  40. Single-Basin Kitchen Sink better than Double?
  41. Panasonic Vent Fan Installation
  42. Flooring
  43. Dryer Duct
  44. was'nt sure where to put this one - architectural plumbing or archbing
  45. need help with bathroom sink and bath tub drain and vent
  46. loose tiles in bathroom
  47. Baseboard Radiator and Tub Platform
  48. Pipe Route Question
  49. What is the right way to remove moss on composition roofing?
  50. Bathroom remodel - Looking for advice on drywall and vapor barriers.
  51. creosote
  52. painting new drywall
  53. adding a basement bathroom to a 3 story house
  54. Water forming behind vapor barrier
  55. Subfloor thickness
  56. Remodel with popcorn and orange peel
  57. Aluminum Gutters
  58. Sound mitigation.
  59. Widening an exterior door
  60. relocating drain in a slab floor - concerned about floor
  61. Replace copper lines with PEX?
  62. Replacing bath vent fan - No overhead access
  63. Recipricating saw blades for plaster
  64. Sealaing material around a dryer duct
  65. Putting holes in second story floor joists
  66. Removing marble tile floor for wood floor
  67. cement floor paint, etec.
  68. Need advice with countertop backsplash and bathroom subfloor
  69. MOEN Design and DIY Videos
  70. Kohler Design Video
  71. Replacing undercoating on stainless sink?
  72. Kerdi board
  73. salt on concrete
  74. Basement Leveling Help!
  75. Uncle Knackers Demonstrates the Perfect Caulking Method
  76. Bathroom Tiling
  77. Help with deep but skinny pantry space
  78. insulating floor over crawlspace
  79. Tile Job Gone Wrong?!?
  80. What Kind Of Nails For My Carport?
  81. Brasscraft Gas Flow-safe valve
  82. What to put on the window ledge??
  83. How Do I Fix This Drywall Hole?
  84. Heat Lamp and Fan in Bathroom Help
  85. Siding help on building needed
  86. spalling concrete
  87. Need opinion on mounting bathroom sink
  88. 5/8" plywood subfloor for engineered hardwood--thick enough? and for a tile entry?
  89. replacing cast iron radiator supplys
  90. Zinc or Copper flashing to prevent roof algae
  91. Room for a shower seat??
  92. plumbing slope in sink
  93. Basement Insulation Options
  94. Composit Granite kitchen versus Stainless Steel kitchen sink?
  95. Definitive bathroom primer and paint discussion
  96. shower remodel -- trouble leveling the shower surround -- help!
  97. Air tight trim for recess lights
  98. Floor Tile and Chalk Lines
  99. Cover to hide wire?
  100. Screws in Durock...tool late?
  101. tuck pointing question
  102. Bathroom Fan Recommendations
  103. New wood vanity got damaged. Called plumber
  104. Hey! I never woudla thought of that: your ideas for plumbing EXTRAS in a remodel
  105. Kitchen Faucet
  106. Lock for Bathroom Pocket Door
  107. Slab Foundation Question ??
  108. Overhead Insulation - Tape?
  109. pvc paint question
  110. How to prep a laundry room floor with floor drain for tiling?
  111. flooring options for basement
  112. Gutter guards
  113. Water-stained basement wall
  114. notches and holes in floor joist
  115. Medicine Cabinet Hinge
  116. Drainage dilema
  117. New bathroom sink is off center and up from the exiting P-trap
  118. Load Bearing?
  119. 1970's Wood Strips on Wall
  120. Galvanized Steel Duct for Dryer Ducting
  121. Remodeling bathroom.. Running drain pipes
  122. textured ceiling made smooth
  123. bathroom floor
  124. Tile floor with particleboard subfloor and hardibacker... am I hosed?
  125. sink/vanitiy installations
  126. Decorative imitation fireplace using hot water for heat
  127. is this plaster or asbestos on my blueboard?
  128. Wall Vented Range Hood
  129. masonry sealant
  130. In Honolulu Drywall Finishing Of Pocorn Ceilings HELP
  131. DIY Bathroom Remodel questions
  132. Banging air damper
  133. door opening
  134. Remove a brick? Or drill holes through the brick?
  135. Sloped ceiling insulation
  136. Paint / Moisture in Bathroom
  137. Drain question for adding second bathroom sink
  138. Mold containment
  139. Granite backsplash to granite counter help
  140. Want to add more attic insulation
  141. mudset tile floor
  142. Light fixture for above a bathroom shower
  143. Drilling through four 2x8s? Can it be done to run a drain line
  144. Insulatiing an exterior wall - will this work?
  145. shed roof needs a new hat!
  146. How to use two air compressors to increase CFM
  147. Dark register for toe kick
  148. Dual saw
  149. update fireplace
  150. Tile patterns with different thickness of tile
  151. Protecting new tile floor?
  152. Best Subfloor option?
  153. stair case hand rail
  154. Which Cutoff Tool Should I Purchase for...
  155. Will a Gfci breaker solve my problem?
  156. Bathroom Remodel/Drop In Tub Installation
  157. basement bathroom ventilation
  158. Please give a look at this diagram. THX!
  159. kitchen "thru the wall" fan
  160. Oatey vs. Guy gray vs. Water tite
  161. How to prevent Mold from even starting to grow in your home.
  162. Bath/Powder Rm addition -- drain/plumbing issues
  163. i need a 4 inch subfloor
  164. Venting Saniflo (or similar) Macerator From Basement
  165. Enlarging Existing Hole in Granite? for K-6227-C11
  166. Hardwood over concrete?
  167. soundproof walls
  168. Help! Wall space is an inch short...
  169. Attn: Dana
  170. recirculation of hot water
  171. Hardwood over OSB?
  172. Paint primer, can it be mixed?
  173. Insulating top of dormer
  174. Drywall At Joist Transition
  175. Exterior Door Requirement - Numbers of Doors?
  176. Granite Countertops...
  177. galvanized steel downspout inside wall cavity is wet
  178. replacement wood siding
  179. How to remove cultured marble bathroom vanity countertop?
  180. Proper Sub-straits for this tile installation
  181. aluminumm gutter upgrade to use hangers
  182. yellow spots under linoleum
  183. Question On How To Adjust Velux Door/ Window Catch
  184. Self-Leveling Concrete Help - Will this work? (**Pictures**)
  185. Quarry tile
  186. Easy Out Fail
  187. Quiet Bathroom Fan
  188. Need advice on what to do regarding 60 year old basement & problems...
  189. Lights in bathroom
  190. insulation questions and help for my basement
  191. Bathroom remodel (sheetrock wall question)
  192. Paint for garage question
  193. Flooring question.
  194. tuckpointing under window
  195. Reconnecting bathroom fan exhuast duct
  196. Dishwasher does not roll-out
  197. 1/2 to3/4 bath remodel
  198. attaching wood railing and posts to tiled concrete
  199. Proper moving of stove, fridge and DW to not damage vinyl floor?
  200. Bathroom Shower, Gut and Replace
  201. Dow Super Tuff-R
  202. Aluminum or vinyl siding
  203. Replacing Basement Windows
  204. If you don't need a permit, do you need a license?
  205. Hot water baseboard questions
  206. Ecological and green building methods and materials
  207. An overseas challenge: Cement Board on Ceiling?
  208. Flat Roof Options / Advice...
  209. Buildidng a Detached Garage...questions I should ask from contractor?
  210. Best exterior paint options?
  211. Skylights... Grr!
  212. Steam Vacuum Cleaners
  213. Moldy Wood Door--Paint or Replace
  214. HVAC duct through a fire rated wall
  215. Building extra room in attached garage.
  216. Curious about insulating walls
  217. Stinky particleboard
  218. which side of osb faces up
  219. Replacing door latch mechanism on sliding door
  220. What are the consequences of a well insulated basement?
  221. Merging Room moldings french door with new laminate flooring types
  222. Triming Exterior Fiberglass Door
  223. Silicone Base Waterproofing Sealant
  224. Fixing someones mess!
  225. Flat Roof...TPO or Dura-Last
  226. vanity clearance
  227. FLAT Roof - Ice and Water Shield (I&WS)
  228. Ceramic Floor tile adhesive cure time
  229. Completely confused about vapor barriers for bathroom
  230. Best Attic Ventalator for South Texas ?
  231. Building a decorative fence
  232. Which tool---did i use to get this hole??????????
  233. Remodeling...subbing help?
  234. Remodeling bathroom with custom vanity question.
  235. 2nd floor shower drain
  236. Faqs on home security systems
  237. Will waterproofing fix this outdoor stairs problem?
  238. Exhaust fan .. 6 inch duct redcucing to 4 ?
  239. Gannet1
  240. Hiding cables behind a brick wall
  241. Exhaust Fan and H2O..
  242. Solatube with a fan
  243. Need some advice in my renovation
  244. Cost to tile bathroom walls with tile.
  245. Silverline Windows by Anderson
  246. Basement Insulation
  247. Basement Leak from small hole in concrete foundation floor.
  248. soap dispenser
  249. 2 electrical question re: deck renovation
  250. Installing tile in bathroom - Any tips?
