- Propane to electric
- Bathroom Fan - No Vent?
- clean windows
- pond water bathroom
- Bend In Bathroom Venting
- Gas Line sizing and bottleneck issue
- Setting mosaic floor tile
- dryer vent
- Straw Bale Homes
- whole house/attic fan
- How to / should I insulate an old house?
- Cord control for over the fireplace TV mounting
- Covering bathroom fan with insulation
- Stud Finder
- painting walls
- room center marks for peel and stick tile
- Creating Flat Ceilings
- Breaking concrete?
- How to get a refrigerator in the kitchen
- How to repair this wall
- Installed Bath Tub Question
- Staircase remodel
- patching walls
- best paint
- Roughing it - 12" or 12.5"?
- Fixing dryer vent by drilling hole in a beam
- bathroom light heater fan combo
- Help Please!!! Deck post questions
- Toilet R/O is too small
- Indoor hot tub
- How to replace this door? *pics*
- Removing veneer?
- Move a basement bathroom rough-in?
- Bathroom Remodel
- Exterior repair/paint question on stucco
- plastic dust door
- Resurfacing concrete driveway
- How to Bleach Wood
- Advantage Lumber?
- Canterwood Estates in Woodinville
- Fire damage
- Shed roof 2x8's?
- Paint
- Old house - sweet smell after rain
- Basement flooding: saved by the floor drain, but only just
- How to fill drywall gap?
- bath room remodel ran into a problem with a tub drain
- new second floor bathroom
- Idea for small bathroom spaces
- can a wall that's only upstairs be load bearing?
- Tile over or attempt to tape these seams?
- Brick & morter & How to clean off morter???
- Taping uneven butt joints!
- Ozone Generator
- HELP- Sealing Grout
- Kitchen Planning from Water Cooler Advice
- Will this drain system work?
- Garage door in RO less than door width?
- Handicap Ramps for Dogs
- Patching dry wall at a high place
- Fixing a bowing ceiling
- Crawl Space Beam and Joist Support Questions
- Space saving storage..High quality bath cabinet recommendations?
- Bathroom door rough-in
- Sealing IC rated recessed housings
- Ductless bathroom exhaust fan
- Large Utility Sink
- Basement Flooring options
- potable water heat exchanger
- What material to replace fascia boards with ?
- Moving toilet location in concrete slab.
- Vinyl floor/carpet tile removal
- Bamboo Flooring
- Bathroom framing question
- Wood Floor Repair
- Drywalling - sand once, or after each coat?
- Sealing the driveway - any advice
- Bath remodel...moving toilet and vanity
- Bathroom lighting plan
- Brick pulling away from structure?
- Won't stop cracking.
- Automatic Garage Door Spring
- HELP! He did not hot mop!
- Silestone Installed Right
- one vented fixture in whole house?
- Top plate over header?
- Drywallin'
- Home Inspection Nightmares
- Squaring up structures / planning layout ... shortcut?
- Siding/sheathing - ran into a doozie
- Basement stairs
- Garage Door Opening Wall 2x4 or 2x6?
- Sill plate location ... in or out?
- Garage Progress ... pictures!
- Space saving Staggered Wall?
- Duct for a Kitchen hood
- For DIY'ers
- Tiger Foam Insulation ?
- help please...I'm out of ideas
- tying re-bar
- 15 year old Fridge, repair or replace?
- Redoing bathroom plumbing
- Building an entire shower in a bump out..
- building a arch way
- Garage Conversion/Property Tax issues
- Issue with Corian counter top
- Roof leaks at chimney flashing
- Home Depot, did this really happen?
- Waterproof a Laundry Room?
- window in shower waterproofing
- lake/ice rink in driveway
- Tin roof questions
- fence
- Spraying texture onto FRP
- Copper Naphthenate - How long before you paint?
- lally columns
- Bath exhaust fan venting
- Dumb question about stud walls
- Toilet will be a bit tight
- storm door lock set
- 4 inch riser clamp
- Plastic Support Insulation on open Ceiling
- Foundation cracks
- Mold in the attic
- 1/2 round gutters
- Please Help! How to Install a Drop-in Tub!
- BOSSLER Roofing Company Takes Off Wrong Roof!
- attic ventilation
- Remodeling bathroom...will this drain setup work?
- compressor air lines
- MW SIngle Pane Window Question
- Vinyl siding repair
- Use concrete floor paint on foundation?
- Clapboard siding and old house insulation
- gas oven question
- Shingles prove to be gold mine for thieves
- Terminating a Fence at a Building
- Wood working power tools
- Should I get a permit for a basement bathroom?
- Green Remodel
- Pine Floor Install
- Slab floor breaking up around perimeter
- Cellulose in a basement
- Light at the end of the tunnel
- Demolition Advice
- Wondering about insulation
- What sealant for window well?
- Water Problem
- How does the layman drill a 2" hole in concrete block?
- Question about insulating garage (framing issue)
- Replacing subfloors, lots of questions
- Increase the height of base cabinets/countertop
- So, I want to to insulate my garage too...plastic supporting fiberglass.
- Spray Foam Insulation for Vented Porch Crawlspace??
- Replacing Cinder Blocks
- Bathroom paint
- Matching Old Ceramic Tile
- Patio Cover Rebuild
- sink hole cutout mistake
- Missing Drywall under sink and other issues
- slab under box out
- how to attach and tape rigid foam
- Ideal location for 14"x12" hole in basement wall
- R-38...how thin can you get
- heated flooring system -w/ tile
- Hanging drywall on 8'-4.375" wall ...
- Re keying question
- Replace ceramic tile flooring
- overhead waher drain
- Insulation question
- New Exterior Wall - No existing anchor bolts
- Advice: Gutter Protection / Gutter Guards
- Good dishwasher?
- Walls or floor first ?
- Smaller sheets of drywall
- basement bath height issues...
- Vinyl PVC Trim
- Granite issue
- Back entry door install
- "Normal" spacing from wall for recessed lighting?
- outdoor fence ideas
- laminated pine panels
- bathroom exhaust vent sizing
- Attic space finishing/insulating
- I Discovered A Great Way To Go Through Concrete Walls (Air Chisel)
- Bathroom tub
- What is a shop vac?
- Noisy Staircase
- Rebuilding Bathroom, got a closet question
- Need help with this exhaust problem
- 10 Immutable Laws of Home Repair
- What do you do if you have a 26ft roof and only a 24ft ladder?
- Planning a basement bathroom from scratch
- Faucet install slightly off by Plumber should he fix it?
- Moen Bathroom Accessories - Poor Quality?
- Want to move Washer and Dryer...but I'm on a concrete slab
- Cutting Marble Tile
- Powder actuated nailer caliber
- fasteners
- any comments on these pics
- Razor blade depository!
- Insulation behind HardiBacker?
- Door at bottom of stairs
- Cap Plate Question
- Bedding for PVC sewer line in basement
- load bearing
- studs 2 ft center
- Bathroom Remodel:
- clearance for vanity and top
- Advice needed to soundproof brown stone wall with metal plated wood door in front!
- Cutting door in foundation block wall
- Vinyl tile installation
- Converting Shed roof to gable?
- Gap filing tile floor
- Drywall Sanding
- A-Frame heat improvements
- Back dating permits
- Erosion of concrete floor at vinyl tile seams.
- Grout Problem
- Basement insulation -- XPS on just exterior walls?
- Need to Move Tub/Shower 1" - Dont see anyway around it
- Ash doors
- waterproofing before tile
- paintbrush cleaning
- URGENT - need advice on natural slate tile selection
- windows and water
- Travertine over 3/4 inch osb
- Inset cabinet in outside wall?
- How to refinish bathroom cabinetry?
- Basement floor redo
- Best way to build stud wall where joists run parallel?
- Kitchen remodels, cabinets and solid surface counters. Bilinda Design, Bill McKenzie
- Built-in timers
- Laundry Room Drain Set-Up - is it okay?
- Electric vs Manual Skylights
- Storm on inside??
- Gutter repair Question
- Tile layout
- fixing wall that bows out past door frame
- Sound deadening between floors
- More tile layout
- Installing Pergo laminate flooring
- 1.5" or 2" nails for hardwood install? Or staples?
- Drywall Mud - What type?
- Weepy copper joint
- Dryer vent/ducting
- smoke alarms going nuts!!!
- Moving sinks = replumbing?
- Wolmanized (pressure-treated) Plywood inside residential areas?
- Laundry Remodel - Dry Fit - Help?!
