View Full Version : Remodel Forum
Pages : 1 2 3 4 5 [6] 7 8 9
  1. Silestone install problem/question
  2. Delta Diamond Seal Technology
  3. How to remove vinyl underlayment (paper stuff) on concrete bathroom floor?
  4. under counter white lav. mounting
  5. Gable roof help
  6. Unlevel tub with tub enclosure
  7. How to sequence closet flange install vs. CBU
  8. kitchen countertop remodel
  9. Granite....radon
  10. Rhino Shield?
  11. Resheathing garage what type of nails
  12. Wood: Varnish & paint outside will it last
  13. Outside hot water fawcet
  14. Kitchen sink replacement questions...
  15. plumbing in a cold zone
  16. Garage floor repair question
  17. Moving back in..
  18. Breaking out a 4-inch thick boiler in basement
  19. Bathroom- Converting single vanity to double
  20. Adding a sink
  21. Roof structural issue
  22. 32mm system Questions
  23. Paint Recomendation
  24. Advice for PEX/Plumbing Newbie
  25. Finishing basement bathroom walls
  26. What would you do?
  27. best "roto Zip"
  28. Question about a basement leak
  29. Insulating Finished Basement
  30. swap laundry room to half bath
  31. Cinderblock Wall - Drywall sheet or "mudding"?
  32. framing garage door
  33. HELP! Major price differences in remodel quotes
  34. Vanity install
  35. Widespread vs mini widespread
  36. How much forced hot water baseboard for room
  37. Pros and Cons of copper sinks
  38. Cistern masonry repair/resealing
  39. garage loft
  40. New Kitchen Sink Installation
  41. bathroom remodel quote
  42. Relocation shower drain problem
  43. expansion joints
  44. how much 2 charge for hanging drywall?
  45. Bulb for bathroom
  46. undermount sink with tile countertop
  47. adding attic bathroom. cast iron stack questions
  48. AZ drywall bid, How much to bid?
  49. condo w/ no water shutoff
  50. building commission/permit questions
  51. sub floor prep for laminate
  52. Hanging Joists in Treehouse
  53. bathroom wiring; one circuit?
  54. Wooden Frame in Shower area.. How to Seal... HELP
  55. Bathroom Exhaust Vent Size?
  56. Gas Pipe Inside Cabinet
  57. 1st Floor Bathroom remodel
  58. What a Mess, How to Repair?
  59. tub/shower surround
  60. Underlayment Sound Protection
  61. Vanity Install Question
  62. Different depths of drywall
  63. Bath Fan Exhaust Location
  64. Bathroom Project
  65. Fire Rated Ceiling- Condo
  66. Covering up an ugly basement floor
  67. 24" On Center Deck Joists, Code?
  68. Pre-Remodel Advice Sought
  69. House stack - move and enclose
  70. Sherwin Williams or Ben Moore
  71. Suggestions on bathroom model
  72. Insulation/Vapor Barrier
  73. Bathroom Remodel - shower fixture
  74. Best way to add 2nd vanity
  75. Name the mystery tile!
  76. Sliding glass door giving me fits
  77. Sheetrock or Mold-Tough on bathroom ceiling and how thick?
  78. Installing suspended ceiling grid
  79. Sanitary Tee Height
  80. New medicine cabinet install--old walls!
  81. Dishwasher Height and New Hardwood Floor
  82. Retro fitting a victorian tub with safey rails
  83. Allergens in Upholstery
  84. Clay roof tile - "Spanish clay"
  85. Pricing for the plumbing part of a bathroom remodel not the carpentry
  86. Replacing subfloor around cast iron toilet flange.....
  87. Replacing a small wall mount sink
  88. Don't use paper backed wallboard?
  89. Relocating drain! Look good?
  90. Backerboard Question
  91. Cosmetic Question
  92. Adding Soffits and Insulation
  93. Digging crawlspace deeper
  94. How to hide a cleanout
  95. Wall mount toilet to sheetrock??
  96. Sayco shower diverter - removal
  97. Palmer Floor Stripper
  98. My New Bar/Kitchenette
  99. stainless tiles for backsplash
  100. Medicine cabinet width for 30" vanity....
  101. Remove plaster and lathe or leave it?
  102. Bathroom layout
  103. Recessed Lights and Insulation
  104. Vapor Barrier questions
  105. Ceiling spots
  106. Recessed light trim will not stay tight to ceiling
  107. Pro Green Paint
  108. Condensation on new replacement windows, Why?
  109. insulating a bsement ceiling
  110. Tile subfloor
  111. Remodeling a 70s Kitchen, Tiling Advice
  112. Does this price seem a little high for a small kitchen?
  113. Attic Bathroom
  114. Who to call for code?
  115. Our new bathroom, almost cooked
  116. Insulating Basement Walls
  117. Remodeling a stairway 'planter' area
  118. Kitchen Counter Sink Hole Standards
  119. zees bathroom remodel
  120. Running DWV through framing in an old house
  121. Drywall - Paper Tape vs. Self Adhesive Mesh
  122. Suspended ceiling: anyone used ACP CeilingMax?
  123. Seeking 14 1/2" wide fluorescent fixture to fit up between joists
  124. mounting stone tops on custom vanties
  125. Pex Manifold ???'s
  126. venting a double vanity with windows above
  127. Tiling a fireplace surround
  128. insulating recessed lights
  129. How do i hook up drain to my lift station
  130. Metal studs
  131. New Shower Install
  132. Order of Bathroom Remodel/Rebuild?
  133. Adding Rafters?
  134. Pantry to half bath Transformation
  135. Insulating Basement Floors
  136. Rock Countertops
  137. Which drywall?
  138. Drilling into Granite Countertops
  139. Window Film to Seal Out Draft
  140. Is this Wall Load Bearing
  141. Subfloor build up order?
  142. Staining oak cabinets
  143. Help Please-Build My Own Metal Console Legs?
  144. Countertop Support Framing?
  145. Metal Roofing Question ?
  146. Basement shower
  147. Major Remodel - Adding Bathrooms - Please help
  148. 12 Inch Spread Tub and Shower Valve
  149. How many walls do I vapor barrier in tub alcove?
  150. Hairline cracks in joint compound
  151. Insulating old house
  152. Installer said grout does not need to be sealed (is this correct)
  153. vinal floor
  154. Help Updating Basement Plumbing Drains
  155. Bathroom addition
  156. Drilling concrete slab
  157. Supporting sagging floor
  158. Remove cinder blocks from foundation
  159. need help with installation of undermount kitchen sink
  160. Wall Mount Toto Promenade 27" Sink
  161. Staircase question
  162. DIY Legally
  163. Main Beam Splitting
  164. New bath tie in
  165. draft from baseboard
  166. 1/4" underlayment over concrete?
  167. Should I insulate attic first or install vinyl siding
  168. What type of home insulation should I purchase?
  169. Outside Deck - Hand rail for stairs
  170. Polyethylene Pipe under slab?
  171. Range Gas Line Remodel Box?
  172. How do I trim an acylic tub surround?
  173. Another 4-Inch versus 8-Inch Sink Drill Question
  174. Overcoming Water in the Basement (a bit wordy)
  175. plaster wall cracks? help!
  176. Gutted living room - Electrical/Insulation question
  177. mold testing
  178. PEX Brands and Tools
  179. Joist missing due to stack placement, redoing floor & plumbing
  180. Adding new bath - need help with DWV please
  181. Basement Design Software
  182. Fixing a crack in poured foundation....
  183. Basement bathroom remodel
  184. Remodeling Assistance
  185. hardwood floor repair?
  186. Client wants "custom"
  187. How to level a basement floor
  188. Help - installing a basement bathroom vent
  189. Bathroom tile less than a week, popping loose?
  190. vynal siding
  191. Moving and Converting tub drain to shower drain
  192. Another vent thread : How far to vent for sink...
  193. Ceiling Trim Problem
  194. DWV for new bathroom questions
  195. kitchen redo / removing tile
  196. Drain Heat Recovery Unit?
  197. uneven marble mosaic tile
  198. Sizing a beam
  199. Rewiring setup question.
  200. position of marble threshold
  201. Fireplace Mantel ?
  202. Foundation Repair Question
  203. How to Remove Bypass Door Hardware
  204. Help: how to insulate an attic door
  205. Wood floor orientation
  206. New Drywall Joined with Old Drywall
  207. vapor barrier back to back?
  208. Remodeling cost
  209. Faucets, Tubs & Shower Walls/Enclosures
  210. slide in range swap out with free standing
  211. Ceramic Tile - thinset and tile gaps
  212. siding
  213. Coax question.
  214. Chimney Repair
  215. kitchen appliances
  216. Toto ultramax, ADA or not. Rough in ? also.
  217. adding shower
  218. stainless steel
  219. Pedestal Sink
  220. What do I need to do?
  221. Help for leaking porch roof
  222. Tile setting - use of premix grout to level surface?
  223. tile cutter guide fence isn't square.
  224. Opening a Kitchen and Living room wall
  225. Big Problem / 50,000 Homes
  226. Bathroom Remodel (again)
  227. bearing length of joist on wall
  228. Drywall Questions
  229. What should I do with this ceiling.
  230. metal studs
  231. New to Power Tools
  232. contractor's markup
  233. Replacing old metal basement windows
  234. Zinsser B-I-N and Venetian Plaster
  235. Dishwasher install
  236. Vinyl siding---should I remove the old shingles first?
  237. Ballpark figure for new siding and roof, anyone?
  238. Popcorn ceiling
  239. Got contractors estimates, but will they charge extra to remove shingles?
  240. Dryer vent
  241. Sawzall
  242. OSB for Subfloor?
  243. hoppers or sliders?
  244. For new roof and siding, Do I hire two separate contractors?
  245. Vikrell vs Swanstone vs Americast
  246. laying down vinyl tile on painted cement basement floor
  247. Gas and water in a kitched remodel
  248. Thinset depth?
  249. kohler flow restrictors?
  250. repair bad PVC union
