View Full Version : Remodel Forum
- Best caulk for acrylic window?
- Proper way to finish basement walls
- What can paneling support?
- Nail Sizing
- Pex bath re-do
- removing undermount sink from granite
- Foam board insulating sheating?
- finishing basement???
- What kind of flooring on slab
- 08 Ca. Code Change Railings Ect.
- Leak proofing conrete utility room
- min spacing hot cold copper lines...
- hot cold shut off valves...
- Where do I get sink hole caps?
- Wood SubFloor Flattening
- Steam Unit
- vent pipe with off set design - permitted?
- Adding shower to Laundry Trap
- over-the-range microwave ovens. Yeah or Nay?
- Undercutting baseboard?
- Cast Iron Porcelain flat rim
- Danze Faucets
- Floor preparation of bathroom
- Roofing
- Addition - Connect slabs
- Silgranit Sink
- Self Leveling Compound
- Faucet choices for a Duravit sink
- how to get manufacturer to honor warranty
- remodel bathroom. HElp on insulation. FL
- Flange on a Tile-in sink
- wood windows-- alum vs vinyl exterior
- adding kitchen in basement - oven/stove top limitation?
- Need help finding a bathtub
- Attic Insulation - vapor barrier
- Before I can remodel
- Vermiculite?
- Fix or repair fireplace damper?
- Quick easy subfloor question
- Laundry room plumbing question
- Bathroom Remodel - Thanks everyone
- DWV Questions
- position of tub filler relative to claw foot tub
- Leveling a low spot AFTER laying HardieBacker Board
- Order of things, tile, vanity, baseboards, etc.
- What is the best tub material?
- Insulating a narrow depth
- In Wall/Ceiling Speakers?
- Squaring an entry door in an un-square house.
- Mold - Vapor Barrier Question for the Experts.
- Fan for New 1/2 Bathroom
- Stabilizing a Knee Wall
- Venting Skylights?
- insulation in shower. help
- UGGGH A floor joist is in my way!
- nesssary to tape joints on drywall?
- stone base boards in master bath
- mounting stone base boards using adhesive...
- Ryobi One+battery charger used for lithium?
- I need to price an interior door installation.
- Heres pic of my insulation. No go or go?
- Fitting Door Slabs in Existing Jambs.
- Roof Ice and water damage
- new toilet drain question
- remodel 1941 bathroom
- buying a home, need another bathroom
- Sliding glass door removal
- ceiling insulation
- Exhaust fan in basement for
- Dekor Arietta Glass Hood
- Countertop support options
- roof vent
- Adhesive
- Replacement Windows?
- Door handleset
- Street of Dreams fires, possible Terrorism
- Tapping into sewer & Water lines of our home. Help!
- Question on sewage ejector?
- Question about my slab.
- help on corner custom shower
- rotary hammer newb
- Bifold Closet Door
- dryer vent between joists?
- Rough plumbing = sewer gas
- buying 90-year-old home
- Polishing marble spot to original shine
- can one deepen a basement (don't LOL)
- Need Easyboard And Redgard Help
- installing joist header
- Installing a 4 inch mini widespread faucet
- 1924...
- Order of Operations - Doors
- Repairing/refinishing a leaked-on ceiling
- Polishing a stainless steel sink?
- 1st floor/basement shower addition
- Garage construction for room in attic
- Venting an upstairs toliet
- did i screw the pooch? (painting problem)
- How to properly hang joist hangers? Tips and Tricks?
- question about rebar
- Best Deck Screws
- mixing deck mud question
- Filling Nails on Trim
- Hairline crack in Bathroom Ceiling....HELP
- Sink and Toilet dry for 2 years...advice on install please.
- Bath Fan
- White or stainless steel sink?
- suggestions for fitting vanity top
- Salvaging Brick
- Relocate bathroom
- TruSlate roof??
- Crack isolation membrane?
- Blending Old and New Texture
- Tiling over Tile
- Trimming a hole in drywall
- 1810 bathroom floor tile trouble
- Replace or repair windows?
- Fiberglass exterior door paint issue
- Door From Garage to Outside - Code Question
- Deck Questions
- basement bathroom drain venting
- Bathroom Diag. vent layout
- Vanity Top
- Pouring new basement floor ... how to get concrete?
- Which ladder is better?
- Plumbing vent flashing
- Bath remodel
- Basement: 4" Double WYE a bad idea?
- Trim Gaps
- Acrlyic sinks?
- Laminate Floor in Bathroom
- Washer/Dryer install in second floor
- sink supply line leak fix question
- Double sink garbage disposal, which side?
- Question on drywall.
- DRICORE subfloor
- 14.4 volts vs 18 volt for homeowner
- Sensco duraspin collalated dry wall gun
- underlayment under new tub
- laundry install question
- Copper naphthenate -- where to get?
- Bumblebees drilling holes in my shop frame
- Old-fashioned open-caged elevator
- Insulation question
- vapor barrier basement in Northeast
- Pocket door gap
- Bathroom roof vent
- Fire-rated pull-down stairs into attic above garage
- Gapping Deck Boards
- Bath sink - vitreous china or acrylic???
- Is this price good?
- mounting floating style mirrors...
- Question on new cement sealer?
- Leveling concrete clearance problems.
- Adding radiant heating to basement bath. Need advice.
- Extruded Polystyrene Insulation
- Another question re load-bearing wall (w/ pics)
- subfloor replacement questions
- Adding Racking Resistance to an existing house?
- Basement Drainage System Idea--NEED SERIOUS INPUT!!!
- tie into clay
- table saw question
- Outdoor Motion Detecting Lights switch location
- Dryer Vent
- Green Mold Spores on Roof
- Cutting tile on backsplash
- Anyone used this dryer vent?
- Adding Vent lines
- Basement Bathroom Venting Questions
- Removing Compound
- subfloor question
- Ideal Sump Crock Location?
- limitations of wood epoxy?
- basement bathroom
- Post your Pics, We would love to see your projects!
- Drilling thru Rock and Cement
- Bathroom Options
- Can anyone help me find a timer that will work in the color gray?
- Vanity tops for cheap...
- charging a 3/4" to a 1" water meter
- Maximum "void" under cement under layment
- window replacement
- skylight tubes by Solatube
- Cermic tile direction?
- Changing textured ceiling finish to smooth finish.
- Best Driveway Sealer??
- One-way mirrors
- New Garage Door Installation
- discontinued Cabinet doors
- Need help with Moen roman faucet rough-in
- Change in DWV System shared by shower & lavatory: Is this okay?
- Exterior Paint
- What is ceramic tile caliber?
- Adding a bathroom on a slab
- Black Gas Pipe --Insert T :how is it done?
- Ladder question
- The cost of efficiency
- Best Wood Floor finish?
- Recommended Suppliers in SoCal?
- What to do?????
- Installing a pedestal sink. Help needed.
- Vinyl Fence Installation
- Screened In Porch Questions
- bath tub faucette
- Jog in Vent Stack?
- Kitchen Sink Vent Question
- How times change.
- Sound deadening
- Replacing Double Garage Doors With A Single?
- New Bathroom Review - Toto, Swanstone, Moen, Keystone
- expansion gap for floating floor
- Installing attic ladder - joists are overlapping
- Plasterboard walls
- Did I pay too much for vinyl siding?
- removing wall
- Moisture protection beneath CBU floor?
- Can a 1 piece fiberglass shower enclosure be cut in two and repaired?
- Wall Support for Pedestal Sink
- Black sticky stuff remover
- Leak - bad seal under sink
- Which panasonic bathroom fan?
- Closet flange issues
- Removing Thinset from Subfloor
- Front door question
- Partial Interior Perimeter Drain?
- Be ready for the next kitchen remodel craze!
- pine board for ceiling - diagonally
- Help about remodeling Condo. Need to know the Posible order things need to be done in
- Wainscoting on bathroom walls?
- Reparing Subflooring 101
- Can't shut off water main
- Don't you just hate it when...........
- Difference between "thinset" and "dryset" mortar...?
- Sealing grout
- Reset porcelain towel rack
- which air finish nailer to buy?
- Exterior tile and grout failing.
- Combining shower, tub, and toilet drains...
- Light Green Sink
- old style garage doors?
- Vapor barrier under carpet pad
- house paint and spray guns
- Instant on Water heater? or 80 gallon or both?
- Composite granite sink in granite tile top
- What brand is the best for kitchen faucets?
- Red jacuzzi!
- Which is better???
- Countertops, flush edges
- Painting Tile
- Underlayment for Tile Floor
