View Full Version : Remodel Forum
Pages : 1 2 3 [4] 5 6 7
  1. Jackhammer anyone?
  2. Ceiling support when putting in a header
  3. Replacing staircase handrail
  4. Toilet Too Far From Wall
  5. Wood floor buckling
  6. Bathroom Reno Gone Terribly Wrong
  7. Sealing Tile Grout
  8. How to build an Archway?
  9. anchoring dishwasher to granite counter?
  10. going thru the roof (power, that is)
  11. Stainless Sink on Granite, with no brackets - HELP!!!
  12. Ceramic floor tiles
  13. Building Home
  14. How to clean attic mold?
  15. drains for new bathroom
  16. Possible to replace hot-water baseboards? With what?
  17. tiling floor in new bathroom
  18. Shower Stem/ Can't Remove It / It Is Stuck
  19. Another double check re: ceramic floor tile install
  20. Epoxy Floor Covering
  21. Basement Bathroom
  22. Remodel Bill Gates bathroom
  23. Concrete slab & sink vent problem!
  24. black mold
  25. Front door with sidelights
  26. The last step finally,but i want to use the right sealer on this ceramic tile floor
  27. Mahogany door stain problem
  28. Plan review question....
  29. Are ther alternative to Wooden Post on Deck Foundation
  30. Replumbing drain for my A/C condensate line
  31. Examine my Bathroom Remodel Plans
  32. remodel vent size issue
  33. What is the Best Sound Isolation underlayment for ceramic tiles?
  34. Is there a Disadvantage to Underfloor Heating?
  35. Flush-cutting a 4x4
  36. New bathroom in Game room with no PLumbing
  37. Replacing cast DWV with PVC
  38. Rolled Roofing Over Rolled Roofing
  39. Roof Vents
  40. How much room makes sense around a toilet?
  41. Roof Leaks Downslope of Penetrations
  42. Hello there!
  43. Can ceramic sinks explode??? =D
  44. soundproof existing room
  45. Concrete Spalling
  46. Adapt a bar sink as a bathroom sink
  47. Help! - New Dishwasher Styles
  48. Saniflo & 2" Drain...
  49. Breakfast counter kick board???
  50. Cutting large hole through brick
  51. Replacing a drywall ceiling
  52. Lack of Good Info. Water Level
  53. Some marble tile advice, please!
  54. anatomy of a project
  55. moving toilet and sink drains
  56. venting a new bathroom (toilet)
  57. Diagnal Framing Structure Question
  58. Cost Estimate for Bathroom Rough-in
  59. Framing, notching, boring and related information
  60. harmon pellet stove
  61. Wallboarding - 24" on center studs x 33"
  62. Undermount Sink
  63. Kitchen Faucets
  64. Removing shelves from built-on-site cabinets
  65. Tilers, need your advice...
  66. DIYing is a craft that can be learned!
  67. Replacing carpet in hall and stairway
  68. starting gel for pellet stove
  69. Tough Joist - resists new screws for new subfloor
  70. burn in vanity top
  71. GAS stubs everywhere!!
  72. New Sub Floor Squeaks
  73. Door Vent for HW Tank Room
  74. Missouri Drywall Code
  75. Basement plumbing
  76. No current dishwasher/disposal - want to install
  77. Installing Subfloor for Vinyl Tile
  78. Tile Countertop
  79. Tile Color variation????
  80. Kitchen Aid Dishwasher clogged...
  81. Cinder block vs. wood
  82. Dishwasher plumbing
  83. Kitchen aid Superba side by side fridg...
  84. Adding window to exterior door.
  85. Trying to fix a major mess in the kitchen.
  86. Powder room plumbing
  87. Cutting Sink Cut-Out in Granite
  88. Moldy Closets
  89. Repairing Large Hole In Adobe
  90. Garage Conversion-Tax Consequences?
  91. Replacing bathroom floor
  92. Removing Latex Paint From Wood Floor
  93. Basement Drainage
  94. La Toscana a good brand?
  95. Batn reno venting question
  96. attaching stud
  97. drainage video
  98. Stud Finder
  99. New House PVC Plumbing
  100. Tapcon Problems
  101. Insulateing My House
  102. Lesson Realized
  103. Replacing Glass in 100 Y.O. Window
  104. Remodeling Basement
  105. Flat Roof Question
  106. Water wicking through basement slab
  107. Concrete Storm Room Removal
  108. Help with Demo
  109. moving ice maker supply line
  110. bitter about contractor
  111. It Never Fails
  112. framing out replacement windows
  113. weatherstripping an uneven entry door
  114. Walls made of nothing!
  115. Replacement window balancer?
  116. Painting Yellow board Sheetrock?
  117. Ideas for boiler room walls...
  118. Mold
  119. Framing question
  120. our brand new cast iron kitchen sink just... self destructed... help!
  121. Neighbor wants me to help tile his floor
  122. Follow-up: how to remove cast iron sink without damaging laminate counter?
  123. Spray Foam Insulation Kits
  124. Insulating a remodel
  125. Another Framing Question
  126. Dishwasher Installation / Cabinets
  127. wall/ceiling bathroom vent
  128. Best way to drill a circular hole on culture marble.
  129. opinions on plumbing cost for bathroom remodel
  130. NOVA tile contractor recommendations
  131. removing old bathroom ceiling fan housing
  132. How long of a wait with ceramic tile?
  133. Does this roofing material look okay?
  134. Hello to all of you
  135. combining fan and dryer vent?
  136. Bathroom remodel questions
  137. Adding a full bath to basement
  138. Under cabinet fixture positioning tips
  139. replacing entire subfloor
  140. tile underlayment over subfloor
  141. Floor truss question
  142. Gutter Slope
  143. roof baffles/cellulose insulation
  144. Crackle/Faux finish paints: Any advise or websites with tips?
  145. Reinforcing silestone countertop
  146. Sewer main under concrete slab foundation
  147. Finishing Cement Board
  148. Using all my glass tiles as a border/decoration
  149. Another Gutter Question
  150. Mission Impossible: Table Saw
  151. Broken Concrete Step
  152. Dishwasher Rough In
  153. log chinking
  154. Bathroom Sealing and Grouting
  155. Carpet to tile transition thingie
  156. Granite Countertop
  157. Red clay tile floor
  158. Will this work !!
  159. floor drain in bathroom
  160. 2X3 Lumber?
  161. Need flooring advice FAST
  162. Insulation question
  163. basement cleanout used for sink drain
  164. Drywall Technique Question
  165. installing linoleum flooring directly on conrete
  166. Level cure and bigger tiles
  167. Silicone caulk leeching through granite countertop
  168. Adding a shower to a 1/2 bath
  169. ADA construction guidlines
  170. Moving a Lolly/Lally Column
  171. Patio Door, Low E glass vs Clear glass
  172. Waterproof windowsills
  173. Egress Window Question.
  174. Shed Dormer Framing Question
  175. Leaking dual paned windows
  176. Baseboard rules of thumb?
  177. Need help dealing with old sewer vent
  178. Acid wash?
  179. Insulation in a tight space
  180. Dry marble cutting
  181. New Ensuite
  182. Wiring through a header?
  183. subfloor advice
  184. splotchy grout? What did I do wrong?
  185. hanging a tv over a fireplace
  186. Floor Plans - What do you think?
  187. different tile thickness' what to do?
  188. Outdoor Douglas Fir, need help with...
  189. Load bearing wall?
  190. Insulating interior bath walls...
  191. air compressor question
  192. bathroom ceiling fan
  193. Furring out rafters
  194. can a door swing outwards?
  195. Tile subfloor
  196. Attaching 4x4 posts to concrete
  197. Cleaning broadloom carpets
  198. Bathroom vent flapper noise from wind
  199. Can't get satin or eggshell oil paint in CA
  200. Vapor Barrier
  201. Miracle 511 sealer?
  202. Rough Opening for Door
  203. Bathroom countertop backsplash
  204. sister a joist with steel?
  205. Bathroom Vent Question
  206. Anchoring Into Metal Studs
  207. Doro casing design/style question
  208. how to remove the black gunk...
  209. Arietta draft hood Dekor glass
  210. Looking for stylish articles for home renovation
  211. wall texturing - tips/tricks??
  212. E-Z drywall tape?
  213. Radiators painting
  214. New Exterior Doors Leaking
  215. Ryobi One + tool kit
  216. Steel entry door weatherstripping - where to find?
  217. New basement rough in advice
  218. Paint Sprayers
  219. House Prices
  220. Digging a basement deeper?
  221. Bathroom Vent Fan - NuTone vs. Panasonic
  222. HVLP Paint Sprayers - outdoors
  223. New propane installation + lines
  224. In Wall TV Wiring
  225. bid sheet
  226. What type of concrete/mortar to use?
  227. drywall seams showing through primer
  228. What do you make of this?
  229. Dryer Outlet - no power when completely seated
  230. Cracked plaster finish coat - causes?
  231. height of border in tub surround?
  232. roof leak...
  233. Trouble with porcelain
  234. Installing a Complex Balustrade System.
  235. renovating unisulated attic
  236. Addition Foundation question
  237. Installing new soap dish into existing ceramic tile
  238. Adding outlets to an existing wall
  239. How do you refinish hardwood stairs?
  240. Lighting The Brick Freestanding Fireplace
  241. Height of stairway Hand rail
  242. Joint compound didn't stick to corner bead
  243. flooring under vanity
  244. installing a pre set/hung interior door..
  245. Cedar Closet
  246. what to set first - floor stone or wall tile??
  247. splitting speakers
  248. Hole patching.
  249. Kitchen Cabinets
  250. Problem with slab!
