View Full Version : Remodel Forum
Pages : 1 2 [3] 4 5 6 7
  1. about hudson reed???
  2. Copper Baseboard install
  3. How can I level a concrete porch?
  4. Website URL for cracks/foundation
  5. Paint EVERYWHERE!
  6. Vapor Barrier Controversy
  7. bathroom drain and supply valves
  8. how best to cut cultured marble?
  9. Order of installation for new floor?
  10. move rough in
  11. roofers help me
  12. Foundation cracks
  13. Busting Concrete and replacing Cast Iron
  14. Kohler Pedestal Sink Install
  15. Addition to Bedroom ???
  16. Door patch product recommendation
  17. Zinsser primer better than Kilz...?
  18. Drill guide question
  19. How much labor to pour concrete?
  20. Cure time for concrete patch
  21. Siding under cantilever - want to remove
  22. ceramic tile around pool
  23. Moving natural gas lines in my kitchen
  24. dishwasher or no dishwasher
  25. Bathroom subfloor damage
  26. Door Hinges
  27. What can I expect to pay for having this paved.....
  28. sentinel wall heater fans won't turn
  29. New girl completly confused - NEED HELP!
  30. 2" drain lines and 1/2" supply lines in a 2x4 wall
  31. patching ceiling and walls
  32. Whitewash Formula
  33. Trim carpentry question
  34. Drilling Bascis
  35. Fiberglass Exterior Doors
  36. carpet issues
  37. What thins latex paint?
  38. Putty for AC lines
  39. plaster wall problems.
  40. Overhead Light-Fan-Heat in bath
  41. deck
  42. Advice on laying out recessed lights
  43. New casings\door stops or wood filler???
  44. "Wrapping" Outside of window frame
  45. Cutting a metal door
  46. Any stone masons out there?
  47. Buildng Technique Question
  48. exhaust fan grille substitution
  49. cement vs. asphalt
  50. glass block dryer vent
  51. carpet panels
  52. Window Sash Replacement
  53. Drywalling question
  54. The skinny on pellet stoves
  55. Where to find exterior decorative aluminum shutters?
  56. Roofing
  57. How not to do it right
  58. Any market for reclaimed retro fixtures?
  59. Sealing large gap around replacement vinyl windows
  60. Re-Wiring
  61. sealing around dryer vent exit
  62. Nail guns and wall plaster
  63. Raise Cast Iron Radiator due to new wood floors - HELP!!
  64. Third Floor bathroom addition - DWV issues
  65. Putting in Kitchen flooring
  66. Vent pipe in the slab
  67. Roof paint???
  68. Kids stealing freon!
  69. Anyone else used Polished Concrete
  70. Installing a tongue-and-groove ceiling
  71. Roof has a "birdbath"
  72. Finding the main drain line under a slab
  73. HVAC question for basement remodel
  74. Roof deck with access via spiral staircase
  75. Natural gas line
  76. Marble over laminate cabinet ?
  77. How to attach granite backsplash ?
  78. bathroom stack is in the wrong place!
  79. Show off - new bathroom
  80. Relocate roof support
  81. Chair Moulding
  82. subfloor question
  83. the sink and the counter top!
  84. Help finding a vanity
  85. Making holes in cocrete backerboard
  86. Concrete Demoliton Advice
  87. Bathub Reinstall
  88. proper subfloor for a bathroom
  89. Re-routing Vent Pipe
  90. good source for stock/base plans?
  91. Making L-Cuts in Ceramic and Porcelain Tile
  92. painting trim, baseboards, and kitchen cabinets.
  93. Bathroom remodel - Adding Whirpool bath
  94. Venetian Plaster assistance
  95. Vessel sinks and plumbing
  96. Panasonic Whisper Warm?
  97. Combining Vents
  98. New Kitchen Floor
  99. Plumbing Issue in Kitchen Remodel
  100. Drywall finishing on steel studs
  101. Vanity Backsplash
  102. Lusterstone-Stonecarpet
  103. Drywall help and instructions
  104. Preferred vinyl tile brands/methods
  105. Basement Shower on Kitchen Drain?
  106. Bathroom Vent Leaving Building
  107. Moving a Kitchen Sink about 3 feet
  108. Tough Antique sink question...
  109. Hole in granite counter top ???
  110. Bath-tub tile issue
  111. Mirror removal
  112. Subfloor delaminating?
  113. Vertical slab repair??
  114. Basement Bathroom Rough ins?
  115. Help! Glued down laminate tiles
  116. 2500 sq foot of concrete slab
  117. 3/4 bath remodel in basement
  118. Modern Masters Metallics & Special FX Finishes
  119. Wallboard Question
  120. Cutting a new vanity top
  121. How much light and where?
  122. Roof pincushion
  123. Tub surround question
  124. what way would be best to install a marble threshold at this point
  125. subfloor stackup
  126. How should I prepare old tiles for new floor coverings?
  127. half bath renovation
  128. The best way to add water service
  129. Laminate Flooring on Enclosed Deck
  130. Hanging or anchoring copper tubing
  131. Bathroom Vent Question
  132. Vapor barrier behind pre -fab shower surround?
  133. What would be the best rock solid glue/adhesion for this application
  134. Andersen Frenchwood Slider Question...
  135. New bathroom floor and flange help
  136. Door / Glass Block Combination
  137. Thanks Everyone Here! Remodeling FINISHED!
  138. Overflow protection for sinks without overflow?
  139. Update existing Whirlpool Drop-in Tub
  140. Are my recessed lights IC (insulation contact) rated?
  141. Which recessed lighting over pool table?
  142. Wierd drains and bathroom reno
  143. 3" recessed lights
  144. Adding sink in in utility room
  145. Ceiling Height for New Bathroom
  146. Plumbing a shower and tub drain together?
  147. Tile replacing vinyl floor on concrete
  148. Moisture Project
  149. new floor in bedroom...ever use this stuff?
  150. Cutting into DWV Stack
  151. Where to see/purhcase Bathroom Fixtures: Tub
  152. Lennox furnace filter/ducting question
  153. screen door
  154. Still have black spots
  155. Wet Basement being fixed (pics)
  156. What's in a faucet?
  157. Concrete floor
  158. Roof Penetrations
  159. 28 inches wide enough for 5 foot walkway?
  160. Old Homes without Vents
  161. Removing Broken Windows
  162. gut rehab - fixtures
  163. radiant floor heat??? Yes No Maybe So???
  164. Slipjoint stuck
  165. Siding spots
  166. basement bathroom
  167. GE Monogram oven
  168. Bathroom vent into a chimney?
  169. small clearance to install granite in floor
  170. Soundproofing
  171. Rotozip kaput, poor customer service
  172. PVC into Cast Iron DWV Pipes
  173. more radiant heat questions.
  174. Pop-up drain plug required in bathroom sink?
  175. Offset Toilet Flange
  176. Backerboard issue
  177. painting with primer
  178. bathroom floor leaking at seams
  179. Need free blueprint software??
  180. New basement bathroom - Bad concrete pour?
  181. Plumbing for a remodel/new
  182. Help with rough-in and dwv plan
  183. GFCI and lighting in bathroom
  184. Off-grade Home / Enclosing Under Space
  185. Deck railing optios
  186. Odd PVC cementing question
  187. painting melamine surfaces with glidden gripper
  188. Stone wall advise
  189. Strange House-sinking problem
  190. Bathroom fan vent type
  191. Lil' help....
  192. floor deflection
  193. How can you tell if a wall is load-bearing?
  194. bath fan exhaust
  195. Cutting Granite Tile
  196. Rough plumbing / electrical inspections
  197. insulating around recessed lighting
  198. Driveway
  199. Roofing Question
  200. Need to move toilet,, & hire a pro,, ,but...
  201. Crack in island cabinet
  202. converting from 1.5" to 2"
  203. Getting a tub up to a third floor.
  204. Tile bathroom floor before or after bathtub installation?
  205. Vinyl siding for mobile home?
  206. Do we set the tub and then put up wall?
  207. Plumb W/D
  208. drywalling a ceiling
  209. Add on Bathroom?
  210. Help with vent design.
  211. Venting sizes in Ontario Canada
  212. Granite support for island
  213. Putting in NEW KITCHEN myself NEED HELP with question
  214. How to remove this... glue?
  215. Best Vacuum for Laminate floor?
  216. Choosing an attic ladder
  217. Pocket door Question
  218. How big a water heater?
  219. Hot water problems during Remodel of Kitchen/Bath
  220. cracks in thinset with floor heat
  221. bathroom fan exhaust
  222. pedestal leg
  223. spray on foam insulation
  224. How to true old wall before hanging drywall?
  225. Innovations in Roofing?
  226. mobile home wall removal...
  227. Garage Conversion
  228. River Rock Countertop
  229. Insulation & siding
  230. puckering drywall question
  231. Want to add new insulation to basement
  232. Best way to drywall 8'2" ceiling
  233. Bathroom Reno
  234. Bathroom remodel subfloor question
  235. Adding an ice maker run
  236. Salvage yard for homes?
  237. Subfloor membrane questions
  238. height of drywall and finished floor
  239. Thickset (mudset) tile removal
  240. add 2nd water heater?
  241. hanging drywall on ceiling
  242. tongue and groove ceiling
  243. straight stop with long "handle?"
  244. Bathroom wall treatment around tub
  245. Subfloor thickness
  246. New Gas & Water
  247. Safe Pressure Treated Lumber...
  248. proper use of greenboard
  249. Concerning codes, permits, licenses, inspections, ad infinitum
  250. Concrete Filling
