View Full Version : Remodel Forum
Pages : 1 [2] 3 4 5 6 7
  1. Planning an addition
  2. searching out a draftsman/architect in Washington
  3. Basement bath venting
  4. cutting opening for undermount sink
  5. Kitchen sink trap on side or center.
  6. Very little hot water
  7. Best way to route pipes
  8. Used Cast Iron Radiators
  9. Need to make a access panel that looks good and is not obvious
  10. New faucet leak, tub tile panel Q
  11. Frameless shower walls and wall mounted toilet, any Help?
  12. Broken Closet Flange
  13. Sump Pump and Upflush Toilet All In One?
  14. Dishwasher plumbing
  15. Looking for Contracter/Builder in Florida ??
  16. Change tub drain pipe
  17. kitchen sink installation
  18. How to connect (wordy)
  19. single to double bathroom sink?
  20. basement cement removal
  21. moving vent stack in cement foundation
  22. Converting Tub to Shower
  23. Should I reinstall a toilet
  24. Cast Iron, Lead Drain, & Brass Ferrule How-To
  25. Small bathroom, Big problems
  26. thinset error
  27. OT: Need advice on foundation reconstruction / diagnosis
  28. Finish Basement Bathroom
  29. rough in hight of P trap for vanity?
  30. Furnace Question
  31. Flooring
  32. Laminate counter too deep
  33. flooring
  34. another bathroom rough in
  35. Suite recommendations
  36. Matching Whites
  37. Question about new modular home
  38. Rerouting Drain pipes in concrete slab: DIY or call a pro?
  39. New washer shakes floor!
  40. Revamping bathroom - AS Standard Collection??
  41. builing a home salon, need advice ....
  42. Vessel sink installation
  43. New Bath - copper supply stub covers, HQ valves?
  44. DWV size in new bath
  45. advice for drilling for 3-inch waste
  46. Fontaine Faucets
  47. Stud finders not working on hi gloss paint?
  48. routing romex cable and ABS pipes in 2x4 framing
  49. Dryer Thumping
  50. Dryer vent question
  51. Stripping Cabinets
  52. Tapping into main stack cleanout
  53. Double Lavatory drain/vent question
  54. Kohler Faucet
  55. Exposed Shower
  56. Furnace duct repair question
  57. Remodel
  58. multi supply line valve shut off doesn't!
  59. Portable dish washer conversion
  60. Attic Remodel-No Plumbing, Best Way to Add DWV
  61. Basement Sink to Sewage Pump
  62. supplemental heat - bathroom
  63. Moving washer machine drain/slab concrete foundation
  64. changing bath fixtures
  65. prep to paint cement floor.
  66. squeeky floor under carpet
  67. Dishwasher Rack
  68. Info on Trade show...?
  69. Wonderboard installation
  70. Indoor Concrete Acid Stain Flooring
  71. Brass door handle
  72. Sizing bathroom exhaust vent
  73. Labeling PEX Pipe
  74. Traction on Steps -- Skid Not
  75. Water Stain
  76. Acrylic tubs and Firewall in a condo
  77. acrylic tub (where to buy liner directly)
  78. Direct Buy company?
  79. The Green Thing OP/ED
  80. Basement Bathroom - Overhead Plumbing
  81. What is this and what to do with old fireplace?
  82. drywall and insulation codes requirements
  83. Roof cap for exhaust fan
  84. Glass Shelves
  85. Carol's Bath: from one popped tile to major makeover :D
  86. What is it?????
  87. Tiling around bathroom light switches
  88. Cleaning Tile Kitchen Counters
  89. Removing old grout tile surface
  90. Help to identify wood flooring (pics)
  91. Greenboard/vapor barrier/etc questions
  92. Old Baseboard grey pipe/alu fins?
  93. Drain location problem-- need creative solution
  94. Fixture Finishes
  95. Basement Wet-Bar Sink Install/Plumbing in ceiling/What to do?
  96. easy way to remove tape from trim & base boards
  97. Need Shop Vac help
  98. Schlage deadbolt-flush screws
  99. Flooring material for bathroom.
  100. Need help finding bypass door hardware
  101. Adding Bathroom in Attic-Wet Vent?
  102. Corner Sink Install
  103. Tile cleaning disaster
  104. Muriatic Acid-Removing mineral deposits from glass
  105. U.S. Green Building Council
  106. stripper on tile
  107. Laundry room remodel
  108. Screened porch
  109. Staining a deck...
  110. tub to shower remodel
  111. New P trap - Help Please
  112. Bathroom Floor material
  113. Tying concrete sidewalk into foundation
  114. access panel
  115. Tub/Shower Valve Replacement
  116. Attic Remodel-No Plumbing-Where oh where to run 3" sewer
  117. 1 1/2" wide x 3/8" oak flooring
  118. Stainless Steel Custom Fabricated Sink
  119. sink install
  120. Gonna pour my own sidewalk *goulp*
  121. Moving toilet waste line through floor joists
  122. tying into a basement stack
  123. shower faucet
  124. House-hunting: what signs can I look for to know if a second bath is possible?
  125. Just brought an older home. Need Help with small bathroom remodel
  126. Vapor Barrior on floor?
  127. Stackable washer /dryer rough-in
  128. Dremel or Rotozip..
  129. Butterflyj
  130. Need forum recommendatio-- building a fence
  131. heater/air conditioner unit
  132. Help adding a foot control for kitchen sink
  133. Tyvek and other House Wrap Options
  134. Where do you buy Tools/Hardware?-Survey
  135. bedroom window
  136. Ducting exhaust fans in bathroom remodel
  137. Attaching new wall to existing house
  138. Roofing Edge
  139. Radiant light heated Floor
  140. Attic Insulation
  141. Shower Valve Recommendations
  142. Exterior Corner Moulding
  143. Putting a false floor over basement concrete
  144. Location of Bathroom Vent outlet
  145. Roughed In Basement Bathroom Q:
  146. Two clothes dryers sharing a common vent??!
  147. Need roof access
  148. Help new shower in old house
  149. Bathroom Counter Support Frame
  150. rough framing for a bathtub
  151. RV Remodel: Ceilings
  152. how do I install Grohe faceplate in shower?
  153. you won't believe this...
  154. fireplace smell when AC runs
  155. Inspections - How to plug?
  156. Advice for relocating sink fixtures
  157. Pellet Stove/Fuel
  158. baseboard trim
  159. Oversizing PEX runs
  160. Need advice mounting a 50" Plasma HDTV
  161. countertop price
  162. Sewage ejector system
  163. Placing a steel beam
  164. Bathroom Vanities?
  165. Old floor furnaces with grates
  166. Stuccoing over painted cinderblocks?
  167. Pipe replacement
  168. venting multiple fixtures...
  169. Advice on Wood Flooring
  170. Underlayment Fasteners
  171. Tips for Decorating a Room In a Day or Less..It's Easier than you Think
  172. Cutting out drywall, siding, subflooring, etc
  173. Soffit
  174. extending ductwork from crawl to slab
  175. Cabinets over tile, or tile around cabinets???
  176. Laminate wood
  177. what's the smallest half-bath space?
  178. Pneumatic Nailers?
  179. Utility room drain design
  180. How do you make professional looking hinge cuts in a new door slab?
  181. Locate support for beam in floor
  182. Another one for the style police: Exterior hardware
  183. how to remove tack strips from concrete?
  184. Deck sealing
  185. Cut in Vinyl siding
  186. Toilet flange too high
  187. Little bugs
  188. Multi Zone HVAC
  189. house wrap for unfinished space
  190. cost for drywalling...
  191. Remodeling Rash! Skin Irritant (Dermatitis )
  192. Plywood underlayments
  193. Electrical Work, Dryer Outlet
  194. Shower drain placement
  195. kitchen sink
  196. Advice on Concrete acid stain
  197. How do you clean paint brushes - oil based paint?
  198. Repairing a pre-fab home that was cut in half.
  199. Airless Paint Sprayer
  200. Seamless/Removable Laminate floor?
  201. Replacing Doorknobs
  202. Utility lines
  203. Floor Joists 1/2" drop/sag at main beam
  204. Dishwasher Rough In
  205. How to refinish a wood entry door?
  206. sidewalk
  207. sound proof interior doors
  208. decent framing nailer
  209. More Deck Cleaning Questions
  210. Mudding drywall screws (tricky little suckers got you screwed)
  211. Finish Nailers for Light to Medium Use
  212. Fixing a wall
  213. Good Door Place, San Diego, CA
  214. bathroom additions
  215. Tree dirt on new roof
  216. What's best for anchoring in cement walls?
  217. Fence options
  218. Elect. range install codes
  219. Bathroom Re-model Layout Advice
  220. Under Counter Washer and Dryer
  221. Marble entry way
  222. Bathroom Re-model Layout Advice #2
  223. Bathroom Re-model Layout Advice #2a
  224. Are There Any Good Electric Nailers?
  225. Shaw Flooring products
  226. Vapor barrier repair
  227. Laminate Countertop DIY
  228. mating a vent with ABS
  229. Rock Splicers
  230. Opinion on article
  231. Wood Laminate Flooring reconsidered
  232. A/C intake question...
  233. Insulation
  234. Need Cabinet door hardware
  235. best replacement windows
  236. Kilz2 Primer
  237. PEX Directional Fittings vs Flow Volume
  238. Hammer Arrestors
  239. Hot water recirc pump
  240. Solution to P-trap gas from self siphoning?
  241. Bathroom Remodel - Toilet Relocation
  242. Air Pressure Test
  243. Side Panel for Dishwasher
  244. PVC pipe cover
  245. Kinking dryer vent hose
  246. Front Load Washer
  247. Blue painters tape??
  248. Old bolts from an old sink.
  249. Tile Floors
  250. Commercial contruction question...
