- I have angered the plumbing gods....
- recessed radiator
- Addition Plumbing System. Need Advice
- Should I ad an expansion tank?
- Sweating Copper
- Humming noise in natural gas pipes in the house
- Expansion Tank - Which One?
- Little or no hot water in one bathroom
- problems with hot water in shower
- question on kitchen facuet
- draining attic a/c, dehumidifier
- Solution for low-flow city water?
- Galvanized Compression Coupler?
- A bunch of questions
- Hot water tank in bathroom
- water heater
- shower Drain?
- Sry for all the questions..heres another..
- Water Heater Explosion
- Hot Water Options
- Boiler Ignites & Pops Off -Help??
- mixing hot and cold water
- Condensate drain line as trap prime
- Replacing copper lines in slab
- How to find main cutoff valve
- water hammer at pump, Help!
- my water hammer problem better explained
- Installing a Temp/pressure Gauge
- Turning walkin shower stall into bathtub/shower combo
- Using Oatey EPOXY PUTTY Still Leaking
- Copper or PEX?
- Two recirculating lines and one pump?
- natural gas vs. electric water heater
- Help! Pipe problems
- Hot Water/Cold Water
- Natural gas regulator question
- Porcelain Sink Repair
- Need help with air hammer/knock.
- kitchen sink installation
- another sink question
- Very low domestic water volume & pressure ?
- cost to re-pipe a ranch house???????
- Looking for an attractive cold water only bar faucet
- Multiple water heaters needed
- Tap into 2in DWV to add sink drain on lower floor
- Rebuild Lateral Lines and Leach Bed
- shut off from street
- How many shut off valves do I need?
- Fell Down Laughing
- hot water tank maintence
- Main 3" Stack Location
- Kitchen Drain Question
- Shower valve
- Gas appliance pipe run and shutoff
- question on steam radiator leak
- sewer gas b/u from Kenmore Elite HE washer
- Basement Lavatory question
- Need to drill into slab, how to avoid copper pipes?
- Broken pipe flange/lip
- 1/2 Copper pipe - k? for a boiler, Several Questions
- Sewer Gas Odor
- PVC sealant
- Drain requirements
- Basement rough-in diagram
- toilets and sinks my gurlging sound
- amount of domestic hot water is reduced
- circ pump location
- hydronic zone startup question
- kitchen sprayer
- Heat Tape
- flooded gas water heater
- Stack?
- Basement Shower
- zoning
- Water Heater Woes....
- Rough-in hight of sink drain?
- Sump Pump Question
- Kitchen sink hot water pressure
- Alternative to thermal expansion tank
- Paint Vent pipe?
- noises from bathtub
- strange pressure change
- what pipe size with 5/8" meter, to replace old pipe?
- shut off valve
- PEX Question.
- Kitchen Sink vibrations and inconsistant pressure
- Another Expansion Tank Installation Question?
- Another expansion tank dilemma
- Moaning/Whine noise from Kitchen faucet
- CI Plumbing Question
- new bathroom & architectural distribution store west midland
- Problems with my one pipe system, I´m desperate
- Vanity sink trap - can I use 90's after the trap?
- Outdoor water heater (tankless)
- cleaning pipe after job is complete
- Joining chrome/copper to lead pipe
- Permanent Removal of Basement Toilet
- tankless water heater
- sewer smell when bathing???
- Street bend into no-hub coupling?
- leaking from overflow pipe
- replace a drain elbow gasket below an iron tub
- Bolier go's on & Off ? ? ?
- gas line
- Dishwasher airgap
- endless debris
- Help purchasing gas H20 heater
- PVC drain connection
- Expansion tank install
- Washer overflowing into bathtub and toilet
- Suggestions for connecting new sink to existing plumbing?
- Soil pipe depth requirement
- 15 in rough in?
- Venting for a new bathroom
- bathroom venting
- venting in a basement bathroom
- Relationship b/w hot water & low pressure?
- water main grid and shut-off valve
- Dishwasher not totally draining.....
- location of new shut-off
- water sofener overflow to wash tub drain?
- PRV Pressure
- Dielectric action question
- a surprise under the concrete
- pressure test
- Copper Pipe Branching Size
- Continuous hammering noise
- Recirculation pump removed.
- Leak Check
- No Expansion Tank for Water Heater
- Vent question
- Smell in water
- rumble in the pipes
- Water Pressure Question/Problem?
- pressure value blowing water again !
- How to install tee
- Perpetual Drain Problem
- Sanishower for basement shower - advice please
- Sleuthing Idiot Needs Help
- Hot water not as hot. Now what?
- Using an offset for Bathroom Sink
- mucky basement floor drain
- Theremocouple Installation Question
- Want to make sure I get the right water heater
- removing lav strainer sleeve?
- P-Trap Lower than Drain Pipe
- DV Water Heater Recommendation.
- Duel trap required
- Gas Meter - Outlet Pipe Size Change
- pre soldered copper joints
- Dishwasher Models
- Common Venting
- DWV vent questions...
- Rough in dims
- we hear continuous dripping noise
- Outside spigot - possible freezing problem?
- additional trap
- PEX Expansion Tool
- Leaking main water valve
- whistling gas hot water heater
- Soldering around existing fittings
- Line clogs every 3-4 months, HELP!
- How To Remove a CLog
- Sewer smell when laundry tub fills
- Does this meet code? (sink trap)
- Wastewater/ Sewer pipe break - Ireland
- Plumbing survey needed for me to get into trade school
- does Drain order matter?
- piping for shower help please
- Basement Floor Drain - Purpose?
- Bad day
- p traps
- Saddle Valve Question
- hot water tank overflow
- Washing mashine drain
- Portable dishwasher faucet adaptors
- No water from bathroom faucet
- a good day--my personal best
- Is foam insulation needed on PEX?
- sind and washer are backing up into my bathtub!
- Never saw this B4
- Question about hot water delivery system?
- Relocating washing machine in basement
- DWV Help
- septic to sewer
- Can washer drain be used for tub
- water softner
- water softener drain
- Sweating Shut-Off Valves
- Cut down sewer cleanout... possible?
- Banging heater pipes
- Awful sewer gas smell in the baby's room
- Basement bathroom- tub or framing first?
- air conditioning drain
- noisy pipes
- T&P relief valve installation
- High water pressure-spanaway water
- Hammering...please help!
- Adding a fixture to a wet vent
- Sump pits
- Vessel sink installation - rigid?
- Hole through poured concrete foundation
- Not Enough Hot Water
- Bang or Ping in water heater
- Any reason to have hot/cold pies run into one?
- New water heater question
- Pex Rodents Problem, Please Read!
- Compression, Sweat, and Threaded Fitttings: The Pros and Cons
- Replacing galvanized waste pipe going into slab
- water heater setup for my home???
- Copper L vs M
- Problems with rust on pipe
- How to plumb basement sink drain?
- Where to install a pressure regulator
- Problems with a plunger type trip lever assembly
- Water Heater Selection
- Sink basket sizing?
- Water heater relief valve leaking...a lot.
- Soldering vs. Brazing
- Tapping into main stack cleanout
- Sewer gas in brand new restaurant
- low hot water pressure
- Supply extensions
- Question on high copper and lead levels.
- Uneven hot and cold flow after valve replacement
- sewer smell in house
- Pre-soldered fitting
- Electric baseboard heat over forced hot air.
- Low water pressure
- Solder?
- Septic System
- Water back up into sink
- Water piping for a marina
- water pressure
- Ventalation
- Quick question on temp setting for boilermate classic
- ball valve leak
- Dishwasher Air Gap
- RO System Question
- Replacing Bathroom Sink
- question about a tankless heater?
- Vent stack height, color
- Cannot Plug Open Pipe
- leaking heat system
- Clicking noises in steam heat pipes??
- Quick Q about old lead and brass ferrules?
- HW tanks
- Abs ?
- wet carpet
- hammer arrestor
