View Full Version : Plumbing Forum Discussion & Blog
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 [70] 71
  1. abandoned side sewer leaking
  2. Socket Size for Kohler Simplice Faucet Remote Valve Stud Nut
  3. Vent distance to bathroom sink
  4. Kitchen Sink in a Bathroom Vanity?
  5. Need to remove solder from copper toilet drain
  6. Balancing valves for PEX manifold (NOT radiant heating!!)
  7. Price Pfiister cartridge
  8. Price Pfister Parisa faucet leaking below kitchen sink?
  9. Sealing Raised Foundation Sewer Outlet Opening
  10. Can I vent come off the back of a 2" tee?
  11. Machine-gun water hammer
  12. Bubbles in the toilet. Yukky smell in the laundry room.
  13. Copper pipe that wont solder.
  14. Water smells like soldering after softener install
  15. Utility Sink hook-up
  16. How tight do you need to tighten a compression fitting?
  17. Kenmore in door water despenser
  18. vent stack covered?
  19. Faucet manufacturer, Sumerain
  20. Pedestal Sink Installation
  21. water pressure drop with new shower and mixer
  22. Fixture Selection
  23. shower valve torque specs for 1/2" solder fittings
  24. water running sound after tap is turned off
  25. Dumb question about washing machine outlet box
  26. Closet bend? … what am I dealing with??
  27. Removing lead closet bend?
  28. changing my pressure switch on my well/trol tank
  29. PVC to Sillcock - Best Way?
  30. Second toilet line hits main one in opposite direction of flow to the ejector pumop?
  31. Bathroom sink plumbing question (very basic)
  32. Power went down and Powerful Backflush Happend
  33. India. Plumbing Fixtures, Water and Sewer in India
  34. Adding Laundry Sink... Help Needed
  35. Toilet plugging issue, need some advice on options
  36. Wet Venting Shower Trap
  37. Old Flexible Lead Pipe, HOW to attach to?
  38. Laundry Sink into Washer Drain Stand Pipe
  39. Installing a freestanding tub in a dog grooming salon
  40. Can pex be used with Moen tub/shower with handheld shower -commercial 8343
  41. Question About Water Velocity
  42. Repiping PB to PEX from slab to fixture... details?
  43. Hot water, sooner
  44. toilet in basement
  45. Will Toto Drake/septic work with no grey water in toilet line to add water?
  46. Retrofit meter with remote read
  47. Automatic Water Shutoff for Broken Pipe
  48. Laundry & Bathroom DWV layout "please help"
  49. Stubbornly clogged drain
  50. Tying into old cast iron sewage line.
  51. Stripped cast iron clean out.
  52. Looking for people in Western WA dealing with Flushmate Recall
  53. ADA bath faucet as grab bar
  54. Chipped Kohler shower pan: Acrylic over cast iron
  55. Propane Grill Regulator Problem??
  56. Drain options when replacing an existing tub with a longer one (longer trap arm)?
  57. Help rotting the main sewer pipe in my house!!!!
  58. Adding Fixed Showerhead to Kingston Brass Tub/Shower Faucet
  59. anything new in the pex vs copper debate?
  60. Leaking faucet, need help
  61. American Standard kitchen faucet fixing
  62. Dishwasher Air Gap with Under-Sink Dishwasher
  63. Ceramic disc cartridge replacement
  64. Remodel Q: swapping a tub location for a vanity
  65. White, wax paper like residue in Moen cartridge
  66. Re-piping my house with copper (layout and sizing)
  67. Gas line questions
  68. LP log lighter for fire pit
  69. Yet another utility sink plumbing question
  70. 2 inch pipe to P Trap
  71. question of snaking a T intersection
  72. Terrible solution in my basement for washer. Recommendations?
  73. Connecting dwv vents in attic
  74. venting second floor bathroom
  75. Vacant three months now terrible flow to second floor.
  76. Distance of 1/2" water pipes
  77. Kitchen sink rough-in a second opinion
  78. Leak in utility room when 2nd floor tub and shower drain
  79. Automatic Water Shutoff - Tight Spot
  80. brainstorming for new laundry room
  81. Garbage disposal question
  82. Basement Shower in Preparation for Full Bath Renovation
  83. leaky stall shower
  84. 3 inch to 2 inch
  85. Protecting copper from cast iron
  86. venting issue
  87. Plumber didn't deburr, should I be worried?
  88. Leak at base of main drain stack in basement
  89. Securing a wobbly PVC stack
  90. Venting Questions
  91. Will this venting work?
  92. Water supply question, small cottage
  93. Insulating Water Pipes
  94. Septic Tank questions
  95. Will Spraying Drione Ruin My Copper Pipes?
  96. Pxl pex
  97. Installing a loop island vent from kitchen down to basment?
  98. What brand is my kitchen faucet?
  99. Is there any difference in who makes the cartridge?
  100. Having trouble connecting 3/4" copper pipe to 3/4" fittings.
  101. use a manabloc yes or no
  102. thoughts on thermal expansion tanks
  103. whose online? am stumped, but i know one look at these pics and u can help.
  104. What kind of valve do I have to buy for under the kitchen sink?
  105. Cannot remove bathtub handles
  106. Question about p-trap
  107. American Standard shower stem won't come out...
  108. Pressure relief valve to reduce pipe bursting?
  109. Copper to pex without soldering?
  110. Minimum Length Between 3/4" Copper Fittings
  111. Global water problems get a fresh approach
  112. How would you reconstruct this bypass valve?
  113. would you consider this hack work?
  114. Plumbing license
  115. Need advice on Boiler selection
  116. Standard procedure for mounting pedestal sink?
  117. Critters in the waste pipe - coming in from where?
  118. Problem with Kitchen Faucet Sprayer
  119. securing copper pipe
  120. Stuck drain valve.
  121. DWV design feedback request
  122. Diverter valve question
  123. Need Advice Before Re-piping house
  124. Odd P trap
  125. is this a right way to terminate a drain line?
  126. Joist under tub drain.
  127. Bathroom group
  128. Water heater pressure valve leaking. 5 year old heater. Home Cheapo Strikes again.
  129. Cast Iron Drain Pipe: Should it stay or should it go?
  130. Is Delta ball the only single lever faucet mixing valve with multiple manufacturers?
  131. Need help with drain problem
  132. no water coming into the house from gravity fed spring
  133. Submersible pump current insreasing with time
  134. I hate my neighbors Plumber
  135. upper and lower unit condo re-plumb
  136. DWV design. New bathroom on slab. one vent pipe?
  137. How to assemble close nipples properly without a hex center?
  138. Building a Laundry Grey Water Seepage Pit - Stage 1: Indoor Plumbing
  139. Can Anyone Identify This Kitchen Faucet? (I Need A New Cartridge)
  140. Turn valve will not completely shut off water
  141. Washing Machine Drain in Basement w/ CAD Drawing
  142. Yes another wash machine, sink question
  143. Tubular offset for pedestal sinks
  144. Adding and installing a washer to a garage
  145. Cutting through a 2" brass valve?
  146. gas stove supply line replacement
  147. Main line clogging
  148. Galvanized RePipe- Tight Squeeze on Risers.
  149. Plumbing Vents and Solar Installations
  150. Notching studs?
  151. Typical Difference in Hot Water and Cold Water Pressure
  152. Shaky Water Line - GE Fridge
  153. Drip Irrigation Help!
  154. The grease/lube in Sharkbite fittings
  155. switched recirculating pump advice
  156. Kitchen sink venting height
  157. Copper and Green Stains
  158. Outdoor patio sump with decorative grate
  159. Cast Iron Hub
  160. Water service upgrade for home fire sprinkler
  161. A little help? Checkvalve?
  162. Washing machine discharge rates and standpipe specs for Condo Board, Inglis IFR42001
  163. Help with adding drain line for washer outlet box
  164. Septic line clogged
  165. Vertical Wet Venting Question
  166. Vent toilet with San-T??
  167. Is zoeller or liberty pro370 the best sewer ejector?
  168. Strange problem with Glacier Bay Kitchen faucet
  169. relocating toilet/shower on concrete slab
  170. Is there anything I should do to a cut pipe before using a push to connect connector?
  171. Running PEX for the first time in a beach cabin
  172. Basement Toilet / Sewer Connection Thoughts?
  173. Galvanized Tee for kitchen drain
  174. Bad plumber experience.....any advise will be appreciated....
  175. How to find leak
  176. Dishwasher odor questions
  177. Shower Valve Flow Rate
  178. Identify shower valve, Price Pfishter?
  179. Drain on main shutoff valve?
  180. Appliances - Dry Rot?
  181. Basic question here. leaky clawfoot tub faucet.
  182. Therm A feature?
  183. fluid dynamics - constrictions in gate valves
  184. Capping gas line.
  185. Copper Pipe Support Question
  186. Possible Drainage Issues - Beko Dishwasher
  187. Offshore Junk.....
  188. 50 gal HE vs 50 gal hi-rec water heater
  189. tightening dwv test plugs
  190. Larger ID/OD versus Smaller OD on Utility Pumps
  191. waste pipe design
  192. help identifying kitchen faucet
  193. Schedule 80 Nipples
  194. Pressure Reducing Valve: Bad?
  195. Ejector Basin venting question
  196. DWV Design
  197. tub drain does not line up with inplace drain
  198. setting dishwasher impeller height w/o gauge Kitchenaid/Hobart
  199. Direct Vent Water Heater requirements
  200. Air gap to disposal question
  201. Washing machine plumbing question
  202. PB to PEX?
  203. Is my water pressure regulator broken?
  204. Upsetting Conduct of Plumber
  205. Flowguard Gold CPVC vs PEX
  206. Please review this drain rough
  207. outdoor drain issues
  208. P-Trap Drain Not Draining Issue
  209. Vent Pipe Leak
  210. Vent for Kitchen Sink with Large Window
  211. How to stop bathroom sink leak
  212. i installed this backflow preventer. did i do it right?
  213. Gate valve under floor?
  214. 4 inch waste line stopped up with baby wipes . should I use the b***** drain cleaner?
  215. pex lines run in 2x6 wall between garage and living space
  216. Grease Trap Clean-Out
  217. Help with plumbing. Pressure relief valve needed?
  218. How to fix shower p-trap?
  219. drain has roots Pvc or ABS?
  220. Schedule 20 for Tub Drain?
  221. Can anyone help to identify this bathroom lav faucet?
  222. Septic Tank Problem
  223. Plumbing Problems washing machine hook up
  224. Does this new DWV System appear to meet IPC Florida code?
  225. Hard to find closet flange
  226. Lavatory push-up drain - need more travel
  227. How to hydrostatic test Pex install?
  228. Replaced sink supply hoses, now pipes are louder
  229. LG washing machine super loud water hammer
  230. How soon can the vent from a roof drain trap go horizontal?
  231. What's the most reliable way to go from copper to pex without soldering?
  232. Adding a 1/2 bath in basement - this rough in look ok?
  233. Basement bathroom DWV review/thoughts
  234. Water Supply to Detached Garage/Living Space
  235. Laundry box under countertop
  236. what logo is this... or what does it mean?
  237. Toilet and (2) 45's vs long 90
  238. Drainage question
  239. Please identify this water filter size
  240. Remodeling Duplex
  241. Need an advise on valve replacement
  242. No water second floor,help!
  243. Washer Supply Fittings Loose
  244. Plumbing a washer in correctly.......
  245. Adding a tub drain to a toilet branch
  246. Revision 2 of DWV System - Does this meet IPC Florida ?
  247. Does regular plumber's putty stain quartz?
  248. Old Delta Tub/Shower Fixture (Circa 88-90) Cartridge?
  249. Capping old drain lines
  250. humming motor sound in our wall
