View Full Version : Plumbing Forum, Professional & DIY Advice, Tips & Tricks
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 [66] 67 68 69 70 71 72 73 74 75 76 77
  1. No water pressure at kitchen faucet.
  2. Connecting 1/2" copper to old 3/4" brass pipe
  3. When connecting 4" ABS sewer line to Cast Iron, how deep is deep enough?
  4. Question about plumbing a wet bar sink in basement
  5. Pressure spike: PRV or thermal expansion?
  6. Vent flashing
  7. ISE Evolution Disposers
  8. Does this sink drain configuration look right?
  9. Clogged pipes ..... HELP !!!!
  10. Tightening loose handle on Moen 6610 bath faucet
  11. Another DWV design question!
  12. Tips for a successful *Union* connection
  13. Did I really solve two problems with one solution?
  14. Alkaline Kangen Water Treatment. Is it real? Or a hoax?
  15. Whining/noise returns after expansion tank install on cold water line - help!!
  16. Best drain type and strainer for kitchen sink?
  17. Lavatory Drain
  18. Proper sealant for unthreaded pipes with no slip nut
  19. Digging a trench for a sewer line
  20. Double basin laundry sink -- how many traps?
  21. Bathroom sink drain
  22. What are the square cutouts in a bathroom sink drain for?
  23. how to solder copper pipes right up against sheating
  24. Tailpiece extension downstream of wall tube?
  25. Air Bleeder Valves - O Ring
  26. Plumbing with the Wirsbo ProPex Manual Tool
  27. DWV Cottage Rough In Questions
  28. Anyone know of a plug or balloon for an ex. toilet & tub during DWV water test?
  29. bathroom drain help
  30. 2 bowl sink to 1 bowl sink drain conversion
  31. 3" threaded brass wye fitting?
  32. problem tying into drain at septic tank
  33. moving or adapting pipes for a larger bathtub
  34. Quick trap prime line question
  35. Shop bathroom drain rough-in
  36. Dryer boster fan
  37. pump saver submersible pump switch
  38. Re-plumbing a 170 year old house...
  39. pump saver submersible pump switch
  40. Washer under screw for Checkvalve Cover ?
  41. brass or plastic fittings for PEX?
  42. How Do These Irrigation Valves Shut Off?
  43. Basement floor drain extender?
  44. Kraus Strainer Assembly Order?
  45. Plumbing knocks when water runs
  46. Problem - Closet Flange to Lead Bend
  47. Need help identifying faucets
  48. water main line burst questions
  49. Cast iron no hub couplings show leakage... why?
  50. Branch Pipe of Cast Iron Waste Pipe COMPLETELY clogged! HELP!!
  51. Old out faucet leak
  52. Installing new shower arm
  53. Cast Iron drain plugged, options
  54. Solid waste ejector pump piping
  55. Water Pressure now low
  56. Kitchen sink strainer sealing question.
  57. Whats wrong with this picture?
  58. Dishwasher draining question
  59. Hot Water Shutoff Valve (under bath sink)
  60. Old school cast iron pipe repair
  61. An easy question.
  62. Floppy toto toilet
  63. Unknown possible plumbing tools
  64. Help!!! Single Bathroom sink to Dual bathroom sink drain
  65. Do tubular PVC slip joints loosen over time?
  66. pex tubing bought in USA for Canadaa
  67. What has all the quality chrome tubular stuff gone
  68. Basement bath drain layout
  69. Leaky Basin Slip Joint Question
  70. wye-1/8th(combination) vs. a wye + 45
  71. I need help identifying this country kitchen faucet, circa 2002..
  72. Need help identifying faucet cartridge
  73. Vent/trap/kitchen question
  74. Davke Drain out of business?
  75. All things Washer related - for drain tubing
  76. Can someone please tell me what this is?
  77. Subfloor fix and new flange?
  78. Bathroom remodel, drain/vent questions
  79. Wiring a jet pump in conjuction with a storage tank
  80. Will this bathroom work? Please see sketches.
  81. Washing Machine Standpipe...Remedy An S-Trap
  82. Water pressure problems
  83. Any way to have a gravity recirc loop with a tankless water heater?
  84. Sink Drain Nut
  85. Changing from double to single kitchen sink
  86. Basement bathroom where does it drain
  87. Bathroom DWV Layout
  88. washer and dishwasher installation in old apartment
  89. Exterior Hose Bib question
  90. Odor in cold water NOT the hot - Whats up and How do I fix it?
  91. Holmes On Homes Question
  92. 3/4" washerless hose bib - quiet
  93. how tight/loose to hang copper pipe?
  94. New floor drain - vent questions
  95. Pedicure Spa Faucet
  96. Barrier free drain code question
  97. pex or copper for water main line??
  98. advice on new kitchen sink drain
  99. Is this cost estimate Reasonable? Repipe waste in crawlspace
  100. Supply line to ice maker and shut off valve
  101. 3.5" cast iron pipe to pvc
  102. Washer/sink/dishwasher draining outside
  103. Shower diverter pops up by itself. Also, a bonus physics/pressure question.
  104. 2.75 " basket assembly
  105. Need to replace 2 story vertical Galvanized run
  106. Correcting show drain under slab?
  107. Help Identifying
  108. wall tube broken flush to tee
  109. Need review of a rough plumbing diagram
  110. ONTARIO 1 1/2" shower drain??
  111. Symmons Temptrol still leaks!
  112. Cleanout locations?
  113. DWV through crawl space passage?
  114. Sillcock Stem packing - how to replace? FU SAN frost-proof sillcocks
  115. Utility Sink plugs up - bad design?
  116. plastic closet bolt caps won't snap on
  117. rainbird
  118. Piping/sizing question
  119. 2nd floor powder room directly over exist. basement full bath
  120. Connecting branch lines to building drain
  121. New Drain Install: 4" To Toilet?
  122. dumb question about under sink plumbing
  123. in-slab drains for washer/sink leaks
  124. Vessel Sink drain problem
  125. Matching Delta's "Venetian" Bronze finish and water filter systems....
  126. Quick check of toilet drain connection before I pour concrete?
  127. Help Identify faucet?
  128. Trap Adapter Cap Leak
  129. Avoided a near disaster - Is there a solution so it doesn't happen again?
  130. can anyone id the make of this single handle kitchen faucet?
  131. How Tight is Tight
  132. Mystery Pipe DWV cap
  133. Residents of drought areas are being urged to conserve water
  134. Replace toilet flange
  135. Leaking copper union
  136. stuck foot valve
  137. Need to tie in washer drain to main line
  138. Sanitary tee on back for venting toilet
  139. Maximum distance for horizontal bathroom DWV?
  140. BIGWALL Cast Iron Plumbing?
  141. 1/2 inch to 3/4 main lines?
  142. Sewage pump
  143. Offset Sink Drains Slow
  144. 1 1/2 x 1 1/4 in p-trap adapter question
  145. sweating copper pipe - flux shelf life
  146. Rough drain PVC wall opening heights - slope
  147. Is my expansion tank dead?
  148. Condensation Leaking From Furnace Overflow Tube
  149. Yet another Single Sink to Double Sink Vanity
  150. soldering giving me problems ...
  151. Chicago faucet tool
  152. portable dishwasher water supply
  153. Gas line-connecting different metals - Need guidance
  154. PEX & Mice
  155. Leaking Moen gooseneck faucet
  156. Re-plumbing the house with Uponor Aquapex, have a couple of questions
  157. increasing water pressure
  158. What Type Of Drain Pipe Is This & What 90 to Use
  159. garage sink questions
  160. Copper Threaded Adapter Leaking
  161. Best angle stop for cpvc
  162. Mystery bathtub fixture
  163. Tricks of the trade on removing caulk
  164. 80% humidity in Crawlspace
  165. dryer venting and washer pan
  166. Mystery flushes
  167. Venting basement DWV system
  168. I was a skeptic when I saw plastic on my Grohe
  169. Delta pull down tub diverter
  170. 1-1/2" vs 2" for bar sink?
  171. Mystery Leak. I'm stumped.
  172. sears pump 390.2518 long running time to reach 60PSI
  173. Help identifying outdoor hydrant
  174. Lowering a Kitchen Sink Drain Line
  175. Blocked off clean out?
  176. venting questions
  177. struggle to replace bidet faucet and drain
  178. I can't find this plumbing fitting anywhere!
  179. Removing 4" cast iron waste line
  180. Frost-Free question
  181. Laundry Room Remodel - Drain Trouble
  182. Fridge water filter union
  183. Moving a Toilet 3 inches sideways.
  184. Strange oversized kitchen sink drain basket
  185. Does Soft Rolled Copper get harder over time
  186. Water pressure problem with well pump system
  187. Water Pump hesitates when starting
  188. Island sink and DW venting
  189. When you have a beveled metal washer intergrated into a faucet supply hose.....
  190. Reasonable cost of installing new water pressure bladder tank from well
  191. Dishwasher drain
  192. what type of fitting am I talking about?
  193. Toilet issues... using a closet auger
  194. Help with new toilet flange
  195. Is It OK (For My Pipes In The Crawl Space) If I Disinfect The Crawl Space With Bleach
  196. Sign of the times. HE washing machine odor
  197. 1954 Rehab [tile redi] full bath relo - Need feedback to get off the ground, please..
  198. Old Delta single lever shower faucet issue
  199. Bill gates reinventing the toilet?!?
  200. Automatic syphon
  201. Replacing DWV for bathroom reno - wet venting questions
  202. basement issues
  203. Zone Valve Question
  204. Professional rough-in
  205. Looking for advice on tying in washer to septic drain
  206. Radiant Heat, Pex Supplier, Parts, Outdoor Boiler Insulated Line
  207. Can't find BernzOmatic Fat Boy yellow cylinders anywhere (16.9 oz)
  208. tricky drain location - MN
  209. How to fix leaking widespread faucet t-connector?
  210. Rheem Marathon water heaters - limited lifetime warranty?
  211. Question about 3 compartment sink installation and mop sink
  212. A good septic pumper-person?
  213. Can I put laundry valves and hose behind a stacked washer/dryer?
  214. 21,000 Plumming Code
  215. Goodbye PB hello PEX + manabloc
  216. Capped off drain50 gal. On w.h. ??????? I catch you i kill you
  217. Draining/Venting Tips Needed
  218. Concrete Pipe 90 bend flush with basement floor. How to connect new pipe?
  219. Mounting a water meter ?
  220. Used hydronic circulator pump to transfer pump ??
  221. Shower - hot to cold
  222. Questions about finding/diagnosing a leak
  223. What brand of shower faucet is this?
  224. Help! Replace wall hung toilet in a 50 years old condo...
  225. Faucet leaking down the drain lever
  226. Metal roof flashing--best one?
  227. Chicks & Dicks Softball 2012 Season
  228. Possible sink vent?
  229. where to find parts for old old faucet?
  230. Faucet was loose and moved a bit...Are my compression fittings OK?
  231. Thank you
  232. What kind of fitting for this tubing? (fun plumbing photos attached!)
  233. Plumber reversed the hot and cold faucet placement, can it be fixed?
  234. Laundry Standpipe and Venting
  235. Lift station installation
  236. Can anyone identify this old strange valve stem and washer (?)
  237. basement shower drain
  238. Cleanout and underslab bath drains
  239. How does this shower roughout look?
  240. Hansgrohe Single Handle "Slack" Adjustment
  241. Taco pump 006-BC4
  242. strange size tub drain
  243. Clear Tubing For T&P Relief Valve?
  244. ABS Trap Arm to ABS or PVC P-Trap?
  245. need help identifying valve stem for outdoor faucet
  246. Help with old UV unit!
  247. Backflow Valve Advice
  248. Plumbing Clean out
  249. my sink spits
  250. Waste System Questions
