View Full Version : Plumbing Forum discussions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 [64] 65
  1. Removing stems for a Kohler shower valve
  2. washer plumbing
  3. Extension of a Moen hydrolock sprayer hose
  4. 3.5" co cover leaks
  5. shaking pipes, PRV?
  6. Pex water lines
  7. 1927 Ford and Ellis Pipe cutters
  8. new sand point system losing pressure
  9. Acid Neutralizer drain/vent help needed
  10. Pressure still rising with an expansion tank...is that normal.
  11. Tying in drain connections and venting for new basement bath
  12. recirculation system issues....Too much of a good thing
  13. Very Odd Plumbing Drainage Problem
  14. New bathroom. Is this drain layout OK?
  15. Grohe Valve
  16. Another Tub Dap/Box Out Question
  17. Discovered a dummy outside air vent
  18. How should I update this supply/drain to bathroom sink?
  19. additional vent needed?
  20. aquasource 0309693
  21. Dual kitchen sinks not draining. Filling up both sinks and dishwasher.
  22. needs help in replacing angle stops
  23. Low water pressure
  24. How would YOU do this?
  25. CPVC for Dummies....
  26. Experience with Architectural - Designer Brands
  27. Sewage Pumps
  28. Moen bathroom faucet cartridge replacing
  29. Issues with hose bibb in porch?
  30. How do I attach trap to this?
  31. Urgent: lav & tub single 1/2" or dpkit from 3/4"
  32. Pex tubing test
  33. PVC p-trap leaking?
  34. Float problem with Aquafine Water Softener
  35. Closet Flange Replacement - Lead, Cast Iron and Brass
  36. Clunking from Kitchen Faucet When Turning ON (AmStand 4174.501)
  37. Bradford White or Rheem
  38. Dish Washer, is an air gap still a requirement?
  39. Underground Natural Gas Pipe run
  40. Quick Help! What tool to operate this shutoff valve?
  41. Removing Lead/Oakum from cast iron - replacing tub/sink drain line - pics
  42. Water meter couplings
  43. Shower Addition to Bathroom - Drain Tie-In Question (B.C.)
  44. pfister lav faucet water flow cuts out after 10 seconds
  45. Copper leach ?
  46. thread check valve
  47. a separate flow check valve or a circulator with a flow check valve?
  48. bronze fittings and copper fittings
  49. Newbie help requested- bent snake/auger
  50. Steam Shower Remodel
  51. Price for Black Iron Pipe?
  52. Tie pex into water pipes at water heater? Hows this look?
  53. Help, no water from new Delta multi valve
  54. Freeze Proof Hose Bib Questions
  55. How to run supply to island sink?
  56. Please help - Need advise on trap and venting
  57. Whole-house filter install soon, planning the loop.
  58. stainless screws for drop-ear-90s?
  59. Bubbling toilet
  60. pex toilet/faucet risers - good or bad?
  61. Price Pfister 910-900 cartridge problem
  62. 14 in rim height or LOWER
  63. Advice on bathroom pipes?
  64. Newb with Plumbing Issues
  65. Water supply to toilet
  66. Runaway stacking problem with water heater
  67. Can I vent two sinks with a single foot vent upstream? thanks
  68. Corroded inlet pipe to water heater and drain issues?
  69. Easy, I think: Can a regular elbow trainsition from a vertical to horizontal drain?
  70. Need help identifying faucet cartridge
  71. DWV Layout Basement Bathroom - layout review
  72. Help! What am I looking at? Two flanges?
  73. Increase main drain line bottlnecked at 2" iron
  74. Help identifying old fitting
  75. Remove Brass Fitting from Iron Pipe
  76. Use Cleanout for Drain
  77. venting required for 2 new basement floor drains?
  78. New Vanity, having problems!!
  79. Saddle Valve leaking
  80. Separation between cold water line and heating ductwork
  81. Schematics for running new water supply lines
  82. Flexible ABS bath drain? WatcoFlex®
  83. Setting Americast tub in mortar with grid on bottom
  84. No sealant at base of toilet?
  85. plastic push pull water valve problem
  86. Removing dishwasher, how to cap off to allow for future reinstallation?
  87. Getting Rid of Sewer Gas Smell
  88. Water Softener Vent Question
  89. Meeting the local Kohler rep Doug Cleveland and Lisa Hurley from Sheboygan
  90. Bathroom reno piping question??
  91. Hansgrohe Solaris E Shower Valve
  92. Cherney 2 " test ball shower liner leak test
  93. New Moen Posi-Temp Cartridge - Still NO Cold Water
  94. Bathroom Remodel with PEX conversion
  95. Plastic or Copper Supply for Humidifier
  96. Pex Vanguard Manabloc manifold ... which type and diameter?
  97. I would appreciate your advice on this DIY design
  98. check valve problems
  99. water shuts off as i open valve
  100. Torquing hose clamps for poly connections
  101. Bonding question for new water supply line
  102. Where to add washing machine standpipe to stack
  103. Water leaking at and in the water meter box at the street
  104. Angled faucet mount lavatory sink repair?
  105. Ever seen this? Looking for replacement
  106. Yet another washer stand-pipe question for Chicago
  107. jacuzzi drain removal
  108. Sink drain problem
  109. Inspector wants an RPZ for residential home
  110. kitchen sink mystery leaking
  111. Removing "plug" on Oatey TKO flange
  112. Yellow cylinder recall
  113. Wind draws water from toilet bowls
  114. Moving a sink and water lines
  115. upper floor laundry room requirements
  116. Venting basement floor drain
  117. Replacing faucets on 1940's sink
  118. 2" vent pipe rusted out?
  119. Toilet bathroom vent help with pic
  120. 2" stack vent for 6 bathroom groups 2 washer machines
  121. Orange mystery water pipes
  122. Laundry Drain top and main floor tied in together?
  123. Installing washing machine drain in basement apartment, venting/stack Question
  124. Bad field lines?
  125. Pfister Avalon Shower/Tub Kit and 0X8-310A Valve - Wobbly handle when installed
  126. Un-stick PVC Joint that got a little primer in it? (Kerdi Drain)
  127. MAPP "MAP" Gas Recall
  128. Need advice on drain plumbing for new construction
  129. Basement tub drain removal/change to ABS
  130. SHARKBITE, PEX and /or copper connectors?
  131. Waterline to Sub-0
  132. Pfister question
  133. diposal overflow to second bowl
  134. Cloudy water in well now
  135. Need Advise on Drain/Vent Pipes
  136. Moen 1200 cartridge - can I just replace the rings??
  137. Unused copper gas pipe hot to the touch
  138. Pipe burst! CPVC, to prime or NOT to prime? What went wrong?
  139. Rumbling pipes
  140. Joining Dissimilar Metal Pipes - Out of New Well and Expansion Tank
  141. Knew They Would Catch Some of Ya'll
  142. PVC cracked while removing basement toilet flange
  143. Can Teflon tape (PTFE) cause leaks on compression fittings?
  144. final drawing for plumbing
  145. Remodel drain question
  146. Low Flow to Lavatories
  147. Small leak in new copper soldering.
  148. 3/4" Copper UNION - Use Teflon Tape or Pipe Dope?
  149. vinyl windows ratings
  150. Brass Plumbing - Rip out as much as one Can
  151. Buderus G115 and Tekmar 260
  152. Sewer backflow preventer
  153. hidden plumbing trap
  154. push-on valve question
  155. Bathroom remodel questions (moving a toilet)
  156. Yet another drain relocation question (P-trap stays or moves)
  157. President Seven Seas, Inc,
  158. Another DWV layout question
  159. Sudden loss of pressure from hot/cold lines inside only???
  160. Feedback on basement pipe layout
  161. Water Heater ATP discharge line - how far off ground outside
  162. will low flow toilet work on old septic system?
  163. Bathroom Faucets - Looking Old is in Style!
  164. Solder brass water valves -?
  165. Help with 2" Cast Iron Hub - Part 2
  166. Air in Cold water line and BROWN water?...
  167. Dishwasher Too Far from Sink? Need backup plans.
  168. Full Bathroom Remodel, plumbing questions
  169. Oakum protruding into drain pipe - Help
  170. Riser Diagram help - NJ NSPC 2009 attic bath
  171. Stiff Kohler widespread "Revival" faucet stem
  172. Tub Trap replacement
  173. Toilet outlet pipe offset with floor opening-Need Help
  174. Advice requested: Installing a PVC water supply line above ground?
  175. Who to call for new sump liner/pit?
  176. sewage basin lid
  177. Basement bathroom rough in old house
  178. Bathroom remodel > Horizontal wet venting questions with drawings
  179. Washer valve replacement -- what type do I have here ?
  180. water line replacement
  181. Converting to double sink-drain pipe too close to stud for double fixture fitting.
  182. Pitching concrete to floor drain
  183. PLUMBERS- Your Opinion PEASE! I'm desperate
  184. Stinky bathroom!
  185. Water heaterTP valve piping, what to do??
  186. Bathroom venting question
  187. water pressure drop?
  188. Hot water issue
  189. Bathroom re-model plumbing repair possible problems with old plumbing!!!!!!
  190. Which DIY Torch Kit?
  191. replacing the old tub/shower and putting in a shower only...
  192. How to install a lavatory on plaster wall?
  193. PVC fitting question?
  194. Wet vent question
  195. joining pvc to old cast pipe....
  196. Kitchen Sink Odor
  197. Drain Question
  198. water heater shelf life question.
  199. Tapping into 4" drain
  200. Double Sanitee Vs Double Wye
  201. american standard toilet tank bolt rubber nipple washer ?
  202. 5/16 toilet tank bolt hex nut thread pitch?
  203. Slime coming up from drains?
  204. 2nd Story Bathroom Venting
  205. RO install in basement to feed kit sink,icemaker on first floor?
  206. Toilet rough in question
  207. Sewage Ejector Pump
  208. Help!! Septic trouble!
  209. Best Pratice for Plumbing Accessability.......
  210. Basement Laundry Room - Advice needed for drains... - pic
  211. Moen 3330 / 3320 valve instructions
  212. Toilet vent
  213. Under-counter water filter plumbing question
  214. Sewage alarm system
  215. diagnose this leak ?
  216. Plumbing Problems
  217. Central Air - Hot water
  218. When to switch from PVC to ABS?
  219. Toilet drain pipe issue
  220. how to clean CI baseboard and test joints
  221. New Construction - DWV Layout
  222. Cutting Cast Iron Y!
  223. drain tapping noise
  224. Need technical advice for Tee off 1-1/4" PE pipe
  225. Need help with a toilet supply line repair
  226. Bathroom sink connection to drain
  227. Transitioning DWV Thinwall to Sch. 40
  228. remodeling around cast iron toilet flange
  229. Rough basement drain/laundry
  230. Plumbers putty on plastic
  231. Hansgrohe Lavatory Faucet Leak
  232. Plumber Recommendations in Scottsdale?
  233. Wet Subflooring
  234. bathroom sink has no hot water and delay in kitchen sink
  235. best chemical root killer options in bathtub drain
  236. Laundry Gray Water to French Drain
  237. What's wrong here..
  238. main level bathroom remodel
  239. Gravity septic system
  240. Slip fit PVC DWV pipes ?
  241. parts type used with CI baseboard
  242. Toilet Flange Extension
  243. What is the drain height for a kitchen sink?
  244. Toilet drains when shower is running.
  245. Kitchen sink sprayer problem!!!
  246. Toilet Backup in condo - help
  247. Riddle me this - Low and then Not so Low Water Output
  248. Natural Gas Control Valve Leak
  249. Can't get handle off
  250. How can I fix this Galvanized steel Pipe Thread in my shower?
