View Full Version : Plumbing Forum, Professional & DIY Advice, Tips & Tricks
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70 71 72 73 74 75 76 77
  1. What size PVC for kitchen sink?
  2. drain pipe for washing machine. (discovered mine has 2 -22 degree joints)
  3. Ice Maker fill valve noise
  4. Bismuth solder
  5. How to repair a washing-machine tub (plastic, possibly PVC)
  6. Sleeving a sewer line in a condo
  7. Trouble removing excess silicone from sink
  8. Please help! My FIRST rough-in for remodel and addition
  9. Do I have this kitchen sink move correct?
  10. Which coupling for 3" PVC to 4" Cast Iron
  11. Toilet fills when you pull lever and water goes down after the tank fills.
  12. plumbing in my new masterbath
  13. Valley Cartridge won't come out
  14. Toilet Flange / Elbow repair - Professional advice needed!
  15. vents
  16. extend copper line under the slab
  17. Proper fitting needed, toilet sits ontop of stack, short distance to septic
  18. CW & laundry sink connection
  19. The tale of the thumping faucet
  20. cleaning pex
  21. Radiant heat -- replace mutiple circulating pumps with single variable speed pump
  22. Disguising Pedestal Drain
  23. Double Elbow in Horizontal?
  24. Can I do this?
  25. No Hot Water Pressure...
  26. Uponor source in North Carolina ?
  27. Sink and Toilet Drain Vent Questions
  28. Proper Loop Vent?
  29. Cold water in hot water line
  30. leaking faucet stem
  31. Failing Amtrol ST 12 term expansion tank ?
  32. Special Flux for silver solder?
  33. Switching from 1/2" to 3/4" copper supply lines
  34. How to clear water lines of scale and deposits
  35. Kohler K 304 rough in help
  36. Replacing 3/8 Faucet and Toilet stops on nipples
  37. Increasing gas line size to extend length
  38. How do you seal plastic overflow drain hole on bathroom sink?
  39. Loop vs AAV (weird installation)
  40. New guy needs help!
  41. Stubborn kitchen pipe
  42. Drain Noise/Toilet Losing Bowl Water
  43. Questions about how to repair Moen 8" offset sink faucet (cold side).
  44. Wanting to move shower drain
  45. What kind of pipe transition do I need?
  46. Supply valve issue with Unifit
  47. Faucets with attached supply lines
  48. how to remove plastic pipe stuck inside copper pipe
  49. Join 3" ABS to 3" PVC
  50. Need advice forr old briggs toilet repair
  51. Cast Iron Am I crazy?
  52. I cant hear drip but there's no leak
  53. Redoing shower drain and need feedback from plumbers if it will drain properly
  54. Planning PEX Pipe/Manifold
  55. Moen faucet leak
  56. Seeking advice on connecting utility sink pump
  57. under sink seal: To use lube/sealer or not?
  58. Leaking Hot Water Heater...fixable? or replace?
  59. Banging when opening/closing faucet...
  60. Shower Mixing Valve or Tank not putting hot water through
  61. washer drain issue
  62. Laundry tub drain issue
  63. Venting Separate Shower and Tub Question/Review
  64. Best kitchen basket tool
  65. copper crimp pex tool
  66. galvanized repipe to PEX
  67. Issues, Issues, Issues oh my....
  68. Removed 50 year old toilet and the flange situation is bad....
  69. a plumber installed this for me -- was it done properly?
  70. 1980 house with black stuff around the bathtub drain. I'm putting in a new tub
  71. Bathroom Drain Problem - Please Help!
  72. Tuscany shower faucet cartridge
  73. How to install a two way Cleanout on sewer outside of house
  74. Bathroom Remodel DWV Layout
  75. 85 PSI Water Pressure
  76. Downsizing Pipe - Water Velocity, Pressure, etc....
  77. Basement Plumbing Layout
  78. Vent size two toilets
  79. clogged vent stack
  80. Washer/Condensing Dryer Combo Install
  81. Problem with Washer and Dryer Installation in Basement
  82. Kitchen sink in new location
  83. Kitchen sink rough in Plan
  84. Burnham Alpine 105 boiler
  85. well water
  86. Plumbing for a water softener and bypass
  87. White stuff clogging faucets
  88. Adding a Utility Sink next to Washer, stumped on drain and vent
  89. connecting a 2 inch drain to a 1.5" drain. Bad idea?
  90. PEX manifold
  91. Sewer gas smell in office?
  92. Best flush ,toto 10" rough ?????
  93. Dirty water
  94. TPRV to pan?
  95. water comming out of air gap???
  96. Vent on laundry pump discharge?
  97. Anything wrong with this?
  98. Antique Clawfoot Tub Faucet setup
  99. New Lav drain install questions
  100. Wife wants the toilet moved
  101. Capping a live water line
  102. new plumbing system DWVI
  103. Help identifying DWV pipe
  104. Basement Bath DW Runs Question
  105. What kind of Copper to CPVC fitting is this?
  106. basement plumbing
  107. Washing Machine Stand Pipe/Drop In Sink DWV stack question.
  108. Disposal p trap and wall pipe alignment
  109. Double sink / Disposal / Dishwasher - old home renovation advice needed
  110. Which fitting to connect two horizontal vents into one vertical?
  111. Room Needed for Bathtub Drain
  112. Two Lavs with one vent?
  113. An expansion tank - for water heater - California region.
  114. tuscany cartridge
  115. P-trap Options Here?
  116. Alarm for excessive water flow?
  117. Best way to fix a non-leaking connection that looks bad
  118. Pex Fittings
  119. Approximate cost of adding a drain
  120. bathtub/shower drain
  121. Toilet Vent Distance @ 6' - 9", bad idea?
  122. Connecting 3.5" IPS to ABS for sewer line extension
  123. "play" in copper pipe
  124. Fixing 2 no of 2 inch meters
  125. Nice looking lavatory / toilet supply valves
  126. Double Sink double dishwasher garbage disposal dilemma
  127. Problem with whole house pressure relief valve? Need advice from a pro. :)
  128. connecting faucet without using braided supply hoses?
  129. Really dumb pipe questions...
  130. Help me turn these pipes! - Waste line for sink no longer needed
  131. Dishwasher drainage problem
  132. Washer Drainage in Basement
  133. Roughing in kitchen sink
  134. purging warm water from cold line
  135. Need advice on grinder pumps, I don't have a clue
  136. Electric Water Heater installation questions
  137. Install Electric WH in series with existing tankless
  138. Designing basement stack for water test
  139. Fittings made in China
  140. Copper Diameter and Pressure
  141. pipe insulation for cold water
  142. Water softener drain in basement
  143. Help with slow leak
  144. Help with leak in living room ceiling (which is below bathroom)
  145. Swanstone sinks - staining?
  146. (Another) Utility Sink and Washing Machine question
  147. Tempering Valve Installation Question
  148. fork stuck in kitchen garbage disposal and unjammable
  149. Replacing Tub/Shower with Shower
  150. disposal backup in to other sink
  151. Hiding a dishwasher air gap?
  152. Upstairs Kitchen sink draining into basement kitchen sink
  153. Kitchen Sink Shutoff Valves
  154. Repair Leaking Pull Out Kitchen Faucet
  155. Dishwasher Repair and 2 Licensed Plumbers Opinions - Need a third.
  156. DW drain routing
  157. Concrete in toilet drain
  158. Vent Pipe corrosion and FULL of Green Stuff??? Photo
  159. Toilet Gurgling in Shower Drain + marital debate
  160. When to say when on replacing old drain pipes
  161. DIY Winter Plumbing Tips
  162. Natural Gas-line upgrade and Maxitrol Regulators
  163. Replacing rotted drain under the floor with a pit.
  164. Caulking around toilet?
  165. Snow melt system
  166. Adding bathroom on second floor, questions
  167. Water Supply Line Problem
  168. Leaking at the basket...
  169. Viega Fitting Dealer in NC
  170. Help with yet another bath drain configuration please and thank you.
  171. Advice on proposed double vanity plumbing
  172. Question on 2" sewage check valve
  173. I know I should prolly cut this, but thought I'd ask first
  174. Switch location for Disposal
  175. Frod compression fittings concerns
  176. Help! Difference between Toto's Carlyle II & Soiree toilets?
  177. Slope of 4 PVC sewer line under slab
  178. Shower drip
  179. Water supply and distribution plans - Seattle home
  180. Toilet venting for Reno
  181. Radiant Heating
  182. Temporary dishwasher installation with no sink possible?
  183. Noisy wastepipe in wall
  184. Collar for single wall 6" exaust pipe
  185. Shower missing vent, or circuit venting?
  186. how to extend a male threaded pipe?
  187. Can you join 2 p-trap arms (horizontally) before the vent?
  188. 1 inch brass union compression fitting?
  189. Washer drain/toilet drain
  190. A few questions during replumbing an old house
  191. Bathtub overflow plate gasket. Is this a problem?
  192. Basement Plumbing Layout Review
  193. Bathtub drain help needed
  194. Temporary fix of a very small leak in a kitchen sink drain pipe attached to the jbend
  195. 2" Stack Vent
  196. Sewage pump basin patch or replace?
  197. Waterworks, Sigma, Can't identify faulty shower mixing valve?
  198. Fernco and Mission fittings? Questions?
  199. Questions for Terry and hj ref. a past post.
  200. Elger 2 valve tub and shower faucet repair
  201. dwv layout review
  202. Natural gas supply pipe size general theory.
  203. Running Vents through finished walls
  204. Tie Bar Sink to Existing Bathroom Sink Plumbing
  205. 1'' branch off 3/4'' main
  206. Capp off galvanized water line under slab
  207. Can you tie lav drain into a toilet vent (wet vent)? W/SKETCH
  208. Is there a quality shower base out there that does not cost $1700.00?
  209. DWV Layout Bath & Laundry
  210. new dishwasher not draining?
  211. Garage Floor Drain
  212. Water backing up into basement toilet sewer line.
  213. Plumber in Phoenix AZ area experienced in home run plumbing?
  214. Slow bathroom sink drain in a two family building
  215. Acetylene questions?
  216. Who runs more plastic than copper nowadays?
  217. Dishwasher Drain Hose
  218. plumbing 3 new toilets from 1st and second floors
  219. left scratching my head!
  220. leaking copper fitting
  221. Main Shutoff Valve, Good Choice?
  222. Clear solder from brass fitting
  223. Kitchen faucet problem?
  224. Hole in Copper
  225. about to do a repipe - best method for fittings?
  226. Leak under slab...PVC and copper
  227. Kohler bathroom faucet leak
  228. adding shower to 1/2 bath - questions around drains
  229. Need help on new vanity install, metal to PVC help needed
  230. When will my sweat joints leak?
  231. Water heater blower not working
  232. Shower Diverter Problem
  233. How to connect my reno drains?
  234. Pull out Kitchen Faucets
  235. Red & White 1/4 Turn Ball Valves STILL OK to use?
  236. Attaching ferrule to plastic tubing
  237. Please help with new basement bathroom DWV piping layout.
  238. How difficult should it be to add air to bladder tank?
  239. Ants coming in via plumbing pipe opening
  240. Removing stems for a Kohler shower valve
  241. washer plumbing
  242. Extension of a Moen hydrolock sprayer hose
  243. 3.5" co cover leaks
  244. shaking pipes, PRV?
  245. Pex water lines
  246. 1927 Ford and Ellis Pipe cutters
  247. new sand point system losing pressure
  248. Acid Neutralizer drain/vent help needed
  249. Pressure still rising with an expansion tank...is that normal.
  250. Tying in drain connections and venting for new basement bath
