- Joe the Plumber
- In floor heat not working
- Rough In Vent Stack
- need help identifying faucet
- Replace iron fittings with brass?
- four way valve or best way to get three outlets from one supply?
- Help on DWV Diagram
- Bending Pex
- At wits end with plumbing.
- Insulating 1/4 Copper
- what are fittings made from?
- old house adding drains looks ok?
- Access to tub plumbing
- Sewer gas issues
- Washing machine hoses - has anyone heard of PEX
- Have you seen this type of pipe before!?
- Suken tub remodel questions
- Water Softener Recommendation
- Sewer line embedded or below slab? (1950's house - St. Paul, MN)
- vibrating pipes - How to figure out root cause and fix it?
- TRV Radiator Valves
- Horizontal Washer Drain AFTER Standpipe 3 iinch??????
- Hot Water Pressure Problem
- Patching LARGE hole around Sewer pipe in Foundation.
- using 24vdc to open a 24vac gas valve on a low pressure steam system
- Did my contractor screw up? how to fix?
- Drain and vent re-route
- sink & dishwasher DILEMMA...
- How to plumb septic where drop is > 1/4" per foot
- Basement Ejector Pump Choice and Best Basement Toilet to pick
- Dishwasher soap dispenser does not open during cycle
- Pressure Regulator Question
- Is my DWV Design OK ?
- Do they make a double combo fitting that can be used vertically and horizontally?
- Roughing in small job in shop
- Delta Monitor Shower handle removal
- paper inside ABS pipe??
- Nibco Valves
- Swapping Toilet and Shower locations
- Downsizing inlet/outlet on baseboard
- How far down should bush be inserted into shower drain
- Water Softener Pressure
- Condo repipe
- Bathroom faucet leak, Grohe 21184 Classic
- Leaking ABS to PVC fitting
- Advice on updating old drain plumbing to current code.
- How do I remove this Grohe part
- Rotted gas pipe in fireplace - any suggestions ?
- Want to know best way to tie in new utlity sink drain into washer drain
- Advice on Clawfoot Tub Bathroom Wall mount faucet plumbing
- Low water pressure at the garden hose
- How to go from 1/2" copper to 1/4" compression fitting, with a ball valve inbetween
- sewage ejector pump and uphill drain
- floor drain vent problem in pole barn
- low hot water pressure at kitchen sink....
- Dry Floor Drain
- utility sink hookup
- Size of neoprene gasket on CI drain
- PPP Trap Primers
- Laundry room gate valves messed up
- Options in replacing a drum trap under tub
- Dishwasher Air Gap Required
- Recommendation for residential gas water heater
- residential water pump problem
- What tool do I need??
- Replacing anode rod, what can go wrong?
- Outdoor water softener in Arizona?
- DIY sewer line replacement (partial) ?
- Lowboy under countertop
- Bathroom sink: Connecting plastic pop-up to metal trap
- Valley tub cartridge drips
- Toilet Cleanout setup.
- Copper pipes contacting each other
- Cutting Black Iron Pipe
- What do I do about a floor drain in my basement before adding carpet?
- Acknowledging Expertise
- Question about sewer cleanout pipe cover
- advice on PEX system valve and hammer arrestor details
- I think the plumber screwed up.... What is my best fix option?
- Tankless propane water heater
- Basement bath rough-in help needed
- Differences between these hydronic devices
- Replace Flowguard Gold on a remodel?
- Hot and cold reversed on Moen single handle faucet
- siphon jet
- Question - Is there anything wrong with this pic?
- Tankless RO? What is everyones opinion? Reverse osmosis
- Getting ready to replace all the DWV, am I on the right track?
- Wirsbo / Pex Newbie - Getting Clean Straight Cuts
- Moving Drain (& supply lines in the way) for shower
- Adding a utility sink
- Can I apply a little torch to pex to help it bend......
- Is this unsafe???
- Do I need cleanout?
- Rough-In for wall mount shower panel?
- Venting
- Septic with drain: outside smells when cold, gurlging in toilet and sink
- Not sure what is wrong with hot water in my house..
- Meter running with no water running in the house!
- Using old cleanout for new bathroom addition
- Garbage Disposers - Plumbing Contractor Grade vs. Orange Depot?
- Garbage disposal just put in, smells bad. Help please.
- Duplicating an old toilet supply line
- Is Soft Copper in an enclosed wall OK?
- Kitchen faucet replacement
- Leaking Oatey washing Machine Shutoff Valve
- Nearly punctured a 1 1/4" copper line
- What is the brand of this shower valve?
- Best way to replace this shutoff valve? (See photo.)
- Unneeded natural gas stub
- Can I do this? Double waste system ?
- Looking for a bi-directional electrically actuated valve
- Faucet starts dripping on its own?
- repipe hous and now hot water heater leaks
- How do I remove a leaded in drain?
- Kohler Plumber Experience Trip 2011
- Grohe faucet supply line installation issue
- Hot water recirculation - valve problem
- Noritz NR98-OD Gas Tankless Water Heater
- Basement Plumbing rough in help
- Gas shutoff valve
- someday I'll be a plumber but for now still need advice on venting
- How does this look
- remodelling and used Sharkbite/equivalent push fit but should I keep them??
- we have a 16 inch rough-in andcannot find a tolet ith a 16 inch roughin anywhere
- American Standard Americast tub and drain installation question
- Ice- line[ have plastic]its old!!
- need advice on washer hookup & drain extensions?
- Stainless to copper connection
- water pressure loss
- how about this hookup...
- Gerry Rigged Toilet Misses Drain Pipe by 2 Inches
- Toliet leaking.. tried flapper, etc...
- Sink drains slow
- Converting single sink vanity to double vanity
- Kitchen sink faucet - plastic --- did I fall asleep
- Shower and lav sharing a vent?
- Help with CPVC Joints
- Does Barclay bisque match Kohler biscuit?
- BrassCraft valves reliable?
- Shopping
- Questions about wyes in new bathroom drain configuration
- Proposed Wet Vent for new three piece washroom.
- black specks in water filter
- Elbow, Closet Elbow, or Long Turn Elbow for closet flange connection
- intro & rough plumbing question
- dishwasher drains water but not suds- please help
- Plumbing Work Ethic/Employer Standards
- Would this be a hard drain pipe removal
- Different type of spigot leak
- heat problems
- jig jog in drain pipe?
- main 1/4" copper line done ice-maker
- Kitchen Drain Pipe Needs to be Lowered
- Capping Pex stub temporarily
- Polyethylene sizing for general watering needs
- Key to Shut Off Water at Street?
- Tankless Water Heater Relocation
- Hot Water recirculate
- Trap placement question for washer standpipe
- Pleaes critique my DWV plan - Bathroom Addition
- loop plumbing
- Soldering copper fitting with teflon tape on the thread end of it
- Replacing Kitchen Faucet Pull-out Hose
- flux safty
- Looking for a layout review
- Water Coming out of Shower head Cold But just right at tub before pulling diverter
- Basement toilet rough-in...cast iron
- Garbage disposal - what's the very best?
- Please look at my washing machine/utility sink drain setup...need advice.
- Brown water in tub and toilets
- R10000 Solder Spout
- Replacing main water line in Arkansas
- Monoflow vs. Strait loop
- Refrigerator (ice maker/door water) connection advice wanted
- Where the HECK is my sewer line?
- Hot water re-circulation: two questions
- Well pump pressure fluctuation
- PEX Manifold System Request
- Venting question
- New water and waste pipings (Help)
- Vent question, no room to do it right, lesser of 2 evils?
- Plumber or bust! I think I can do this! Advice please!
- How to wire emergency well pump turn off?
- Sand to protect underground drain pipes? Also, two way cleanout question...
- leak in water softener internal valving
- toilet flange too high
- Steam Boiler Repair pricing. how much do you guys charge per hour for labor?
- Over drilled (>60%) thru non-load bearing stud and need options to meet code
- Sealing holes in sub floor
- New Campbell Mfg 2" Silent Sewage Check Valve slow to open
- Strange plumbing setup
- Why am I getting no water whatsoever from all of my hot water faucets in the house?
- Extending copper lines under slab
- Distance from fixture to roof vent stack layout review (not distance from p-trap)
- outdoor faucet drip
- Fitting wye in existing PVC drain line
- rerouting 2" galvanized steel vent pipe
- Can I roll a Wye to 45 degrees?
- Washing machine standpipe leaking
- CONFUSED! - Bathtub Overflow Installation - Does anyone know what this is?
- septic tank problem, or not?
- No Hot water in part of house
- Odor in Bathroom
- Roof Vent Pipe
- Huge spike in water usage with no lifestyle changes or leak detected by water co.
- Raised Shower
- Toto Drake squeaking and filling up to much
- WHat can I use to bond PVC to brass/copper?
- how to fix a simple drip in an old 3 handle tub/shower tap set
- Kitchen faucet filter placement
- question to recitfy a stupid mistake!
- Passport Ensemble Jacuzzi won't turn off
- Oatey flux
- Shower and Tub P-Trap Before Inspection?
- DWV setup Q
- Would you reuse old copper pipes and fittings?
- Plumbing in toilet flange
- replacing lead pipes and drum trap with PVC
- How long to wait to use vinegar and baking soda in sink after using drain cleaner ?
- Basement Plumbing rough in....
- Small bathroom DWV
- ...yet another kitchen sink drain line routing question.
- PEX for replumbing radiator supply lines?
- Don't want to lose this shrub plumbing a trench underneath PICS...
- Garbage disposal install in double sink w/dishwasher... why do I have two drain pipes
- Bath Tub Drain
- Kitchen sink drain modification from angled to straight
- Ejector Pit inlet pipe problems
- storm drain
- Is my kitchen sink vented correctly? Intermittent back ups and noises.
- Dishwasher drain lines.
- basement drain question for adding wall hung toilet
- Price Pfister shower diverter
- Moving washer and dryer to basement
- Hose bib seasonal leak?
- DWV for new basement bath and laundry
- Kitec plumbing
- Worm clamps on PEX?
- Plumber installing a loop for a water softener... questions about freezing
- Indentifying faucet brand / model
- Disassembling Oatey Single Handle Washing Machine Shut Off
- Silicone or plumbers putty?
- water spraying up through drain by washing machine when shower is on
- Controller needed for On Demand Recirculating
- No cold water in bathtub faucet
- Am I going to loose a water pressure in the shower head? iBox
- A Wetland, sump pump NIGHTMARE...HELP!
- Pex questions
- Pipe dies
