- In a world of hurt...drain broken under house...
- Sulfur smell from bacerial infection of pex tubing?
- PEX fitting reliability
- Trivial question about hot water supply
- 3/4" Sched40 under slab repair
- Feedback on Drain Design
- Pipe Insulation
- Moving Glued PVC P trap
- Ridgid 535 pipe threader
- baffled? water through ceiling
- Water shortages in the World and the US.
- Time To Replace Water Heater?
- Island Sink Plumbing Questions
- Barbed PE fitting in WA state (indoors)
- How would you plumb this basement bath?
- Need Help Identifying a Valve and Finding a Replacement
- Sewer gas from stack, stinking out back yard
- ABS to PVC Septic Connections
- Best way to clean out grease?
- Shower head drop ear alternative?
- No water at all!
- Couple questions for bathroom remodel
- Help with a Huge Water Bill
- Rehau PEX any good?
- Toto stuck/sticky handle
- gap for tub drain kit too big .......
- When to use Grinder vs Sewage Ejector Pump?
- How to attach to this clay pipe?
- Mayan Plumbing
- Is this bath plan up to code?
- Main vent pipe/sewer smell
- kohler shower drain installation
- Newb Needs To Move Drain and Install Vent?
- Hot Water Booster Pump & Bypass Valve System
- Can I change location of vent connection?
- Installing pvc p-trap .. how to connect to metal pipe from wall (no threads)
- Plumbing reno, is it up to code?
- DWV layout question for sunken tub
- sink not flush with granite counter
- Basement toilet bubbling up
- Help identifiying faucet brand
- Adding an additional drain waste line to an existing line.
- Plug Bathtub For Pressure Test
- Copper Supply Line Questions
- Help with PEX pipe sizing
- Loose Tank Bolts, big mess
- New Bathroom Vanity - DIY Plumbing
- PEX Supply Line Question
- new cabin bathroom - studor/oatley vents
- Oven gas line
- Washing machine suds from upstairs draining into kitchen sink
- Leak from bottom of garbage disposal
- Moen Kingsley faucet install problem
- Power Pipe Really Work?
- wax ring brand
- Designing a new house, open panels to make repairs easier?
- Cast iron pipe has rotted - best way to fix?
- Adding New Faucets Outside
- Cracked toilet flange
- How fragile is PEX?
- Cast iron pipe clogged - this is not good
- frost free hose bibs - quality brand?
- Question about shower copper piping route
- New Washer Hookup
- How do I fix this rotted wood?
- PVC Primer and cement question
- Toilet Flange - How Terrible Is This?
- Remodel install problem
- Painting or Refinishing Bathtub?
- sandy well water has toilets blocked... but a couple of different symptoms
- Methods for cleanup house drainage break water/mud from under crawlspace
- Manifold size vs Supply size
- Searched for PEX on this site and came up empty
- Kitchen Faucet Advice
- Kerdi with Noble
- What is this?????----Septic Tank Riser
- Trying to connect drain tailpipe to the trap in a bathroom sink.
- Hear water running at toilet with valve off
- Delta Kitchen Faucet Leaking
- Can I use a Fernco coupling on this angle?
- stinky pipe
- DIY Grey water toilet feed.
- Fixture Colors
- Common P trap to stubout alignment issue
- Washer P-Trap conundrum
- Connecting Hot Water Heater Drain Pan to Sewer - Will Swing Check stop sewer gas?
- Can you explain this problem!!?? No water!
- Replacement of Metal ring on closet flange and filling holes
- Tank Tee Question
- pump for hot water heater
- Low flow faucet problem with well system
- Plumbing in USA vs Europe
- Pressure pump ???
- PEX Connections
- Low water pressure after changing pressure switch.
- few questions related to vent
- Is this stack up legal?
- Wisbro Tubing - Possible Cons?
- Odd Backflow Preventer
- sump pump backup
- Best replacement for old Mansfield frost-free sillcocks?
- Dishwasher drain plumbing, again..
- Installing Drake toilets
- 3/4" copper vs 1/2" copper
- Kohler toilet has explodes waste everywhere, main line plugged.
- Is it a Gas Valve or a Water Valve?
- Is there a way to replace this gas pipe and valves? See photos.
- what's a combo?
- 1.5" vent and revent
- Add a drain line for a kitchen sink to an existing drain line for a washing machine?
- 1/2" IPS -what connector?
- Fixed Water Leak new problem
- how about this washing machine drain line?
- Shower backing up problem
- Plumbing in/under slab dilemma
- moving tub 12". Is vent needed? lots of pics
- flies on the wall!
- is this vent layout really bad?
- Solder over existing solder?
- Pressure Testing Back to Gas Meter
- Kitchen Sink... No Vent? Plus Moving Plumbing
- cant fit sink plumbing piece back together
- Single to Double vanity
- email alerts for you sump pump?
- Washer Standpipe Drain
- How to plumb a kitchen sink...
- wiring for deep water submersible pump
- cavitation
- What's the purpose of a 2nd soil stack?
- Branching to a New Gas Appliance
- Flange Ringer and concrete level question
- Capping a basement shower rough in
- Help me figure out how these rough-ins are supposed to form the bathroom
- Main Line Backup While Cleaning? How'd That Happen?
- Identify faucet brand, Price Pfister
- Shower drain installation plywood subfloor
- Higher pressure than before.
- Need help identifying manufacturer (need plastic parts)
- Hey from a NC Licensed Plumber
- Question on dual direction clean-out installation....
- clicking on ads?
- Minumum distance between pex fittings?
- Trying to find a part - tapped wall bar
- Clean water down the toilet:
- Another way to promote sanitation in developing countries
- Dishwasher Installations - Air Gaps
- Galvanized springing leaks.
- Changing bath tub drain cover plate
- Kitchen Faucet Replacement...problems with leak and cold water valve won't shut off
- Pedestal and Sink Not Properly Fitting
- Sump and drainage problems
- Sump installation and tweaking
- Water Supply Connection for House and Irrigation
- Deadlegs acceptable in residential water systems?
- septic smell in my home
- changing house supply connection
- Master bath slight replumb
- Utility Sink drain to Washer Standpipe-How to do?
- Need help with kitchen sink disaster.
- FRV Information required??
- How to install a Kohler K-7030 valve stem
- water backup in sewage line
- Deco Lav vanity sink drain issue....?
- Adding a Bathroom to a bungalow attic - Toilet Venting Question
- Water pressure drop after remodel?
- Optimal location for water heater?
- Gas line through a flue
- Back up in shower, toilet, and sink only in one bathroom of the house???
- Vent Pipe location question ..
- Water Supply line from Street to House
- No cold water coming from my single handle Pfister lavatory faucet
- Disposal too heavy to hold up and screw in at the same time.
- What type of pipe?
- how to remove abs shower drain ?
- Pipe Nipples bought at HD
- Basement bathroom vent - is this right?
- New bathroom, new toilet, water in bowl dissapears - bad toilet or vent problem?
- Leaks only when hot water tank is on - fatigued joint?
- Height of rough-in for a lav drain.
- compression fitting keeps dripping
- 1" Copper Union..Stuck Cannot Loosen to Remove?
- Pipes humming/whining
- Ball Valves, Angle Stops & those pesky deee-ziner angle stops
- Ball Valves - Forged Brass vs Forged Bronze
- Blue stains in the bathtub... confused as to why.
- Can Anyone tell Me who makes this kitchen faucet?
- Badger 5 Plus
- DWV Advice Please...Bathroom + Laundry Room
- Soldered Pipework - Threaded or Soldered Valve
- Service water line entrance "Split entrance" house, slab floor...
- ABS Drain Pipe, replacing cast iron drain pipe
- Proper drain connection?
- Gravity Fed Garden Hose - How High Should The Water Tower Be?
- Bathroom drain problem - sharing with garage floor drain
- A Little Help: Toilet Leaking?
- Can I use threaded pvc adapter for future modification?
- Peerless kitchen faucet leaking at base of spout!!!
- Plumbers putty for tub drain, or...?
- Cleanouts/Test Tees
- Are the markups on these plumbing parts charged by my plumber normal or high?
- Air Leakage from Sump
- Broken ABS shower drain... fix suggestions?
- can I add a branch here
- Kitchen Sink Drain Leak
- rolled vs. cut threads
- Odor under kitchen sink
- Some kind of build up on the outside of the external pipes on my hot water tank.
- Tub overflow issue .. legal? Picture included
- Leaking outdoor faucet; or worse?
- washington state exam
- Help! Kitchen sink lock nut on drain flange won't tighten!
- Injector Pump Running Continuously (not switching off)
- Machine Gun Shower
- 1/2 vs 3/4 outdoor frost free sillcock
- Redo cold water lines for water softener
- Critique this layout...
- Waste Pipe Leaking
- Bathtub Drain
- Access panel required?
- $1,200 Estimate for bathtub fixtures replacement?
- Should water stream from unconnected fridge line when faucet is on?
- Nowhere to fasten my closet flange...Help!
- Mike Holmes
- PEX installation with multiple 90s
- Moving WC ... stack thru roof location
- 1 final vent termination size?
- Clearing a fused Cast Iron Clean Out
- fire sprinkler main and backflow devise.
- P-trap for washer box
- Second floor plumbing plans and pics....please help.
- Major softener & pressure tank sweat issue
- Sewer Smells from Washing machine Drain
- How Many Clean Out Valves are needed in a 1400 sq ft home?
- Tankless water heater or tank? How about for this particular use?
- Any suggestions to design a house so frozen pipes are less frequent?
- What can you tell me about this vintage faucet?
- Septic sytem used for 5 weeks out of the year- is this a problem?
- Plumbing for new gray water washer/dryer
- Sump Pump help...please
- Rotting horizontal CI pipe between floors: how much to cut out?
- New sink install, not draining, garburator blows water up the 2nd sink
- Annoying, Slow leak from Compression Nut on new Sink Supply valve
- Need help identifying part - faucet quick-connect hose
- Kitchen Sink Water Feed
- Google Plus 1
- Does cast iron p-trap sweat?
- Good quality 3 handle tub/shower valve
- Effective Sound management
- tub install
- For Expert Plumbers: Drain Flies
